04-03-2015, 20:08 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. In order to connect the phone via UART, You need to block highlighted pin with a tape/paper and use Samsung C3300k/C3303k micro UART cable with 525-530kOm resistor for connection. Also, try to reinstall FTDI drivers: http://octoplusbox.com/files/drivers...rs_2.08.24.zip |
04-04-2015, 19:22 | #5 (permalink) |
Freak Poster Join Date: May 2010
Member: 1295465 Status: Offline Thanks Meter: 6 | ok i got the phone to take the new imei which is off another tmobile note 3 that is not blacklisted however it shows the new imei everything looks correct but now says not registered on network it shows bars but will not make a call, also why does my box not let me chose from the Service imei??? im using version 1.65 |
04-05-2015, 07:04 | #6 (permalink) |
Freak Poster Join Date: Apr 2015 Location: IN INDIA
Member: 2372600 Status: Offline Sonork: 100.1663659,ICQ-670897523 Thanks Meter: 49 | Hi, allways use letest ver do next--- 1. Root your mobile 2. Wipe security 3.write cert if no network problem again 4.write qcn |
