06-22-2013, 04:37 | #1 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 683463 Status: Offline Thanks Meter: 188 | SGH-I497 UNLOCK please help ----------------------------------------------------------------------------------- To connect SGH-I497 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to Calculator application. 6. Enter "(+30012012732+" number, to get phone dial window. 7. Enter "*#1575#" number. 8. On phone keybord press "Menu" button, and select "Back". 9. Set "Diag config" to "USB" value. 10. Go to dial window. 11. Enter "*#7284#" number. 12. Set "USB" radio button to "Modem" value. 13. Go to "Qualcomm USB Settings". 14. Select "DM+MODEM+ADB". 15. Close window. 16. Press "Read Info" in software. ----------------------------------------------------------------------------------- |
The Following User Says Thank You to yunaced For This Useful Post: |
06-24-2013, 07:41 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,422 | Hello. Quote:
09-17-2013, 13:42 | #5 (permalink) |
No Life Poster Join Date: Feb 2007 Location: india Age: 47
Member: 446363 Status: Offline Sonork: 1577571:rajtelecom Thanks Meter: 216 | were is the "Menu" button on 8. On phone keybord press "Menu" button, and select "Back". 9. Set "Diag config" to "USB" value. |
09-18-2013, 08:24 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,422 | 5. Go to Calculator application. 6. Enter "(+30012012732+" number, to get phone dial window. 7. Enter "*#1575#" number. 8. On device keybord press "Menu" button, and select "Back". Please perform "Enter "(+30012012732+" number, to get phone dial window", make photo of the device screen after this combination and post it here. |
09-20-2013, 11:19 | #10 (permalink) |
Member: 446363 Status: Offline Sonork: 1577571:rajtelecom Thanks Meter: 216 | Welcome to Octoplus/Octopus Box Samsung software version 1.3.3 --------------------------------------------------------------------------- To connect SGH-I497 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to Calculator application. 6. Enter "(+30012012732+" number, to get phone dial window. 7. Enter "*#1575#" number. 8. On phone keybord press "Menu" button, and select "Back". 9. Set "Diag config" to "USB" value. 10. Go to dial window. 11. Enter "*#7284#" number. 12. Set "USB" radio button to "Modem" value. 13. Go to "Qualcomm USB Settings". 14. Select "DM+MODEM+ADB". 15. Close window. 16. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SGH-I497 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM8 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: SGH-I497 Mode: Emergency Unlock for SGH-I497 phone in emergency mode can’t be done ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: SGH-I497 Mode: Emergency Codes for SGH-I497 phone in emergency mode can’t be read |
09-20-2013, 13:24 | #12 (permalink) |
Member: 446363 Status: Offline Sonork: 1577571:rajtelecom Thanks Meter: 216 | When I Go In Andriod/EFS Managar Than Give Info Welcome to Octoplus/Octopus Box Samsung software version 1.3.3 ----------------------------------------------------------------------------------- To connect SC-01C phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When the message appears press "Yes". 5. Connect USB cable to the phone. 6. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SGH-I497 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to Calculator application. 6. Enter "(+30012012732+" number, to get phone dial window. 7. Enter "*#1575#" number. 8. On phone keybord press "Menu" button, and select "Back". 9. Set "Diag config" to "USB" value. 10. Go to dial window. 11. Enter "*#7284#" number. 12. Set "USB" radio button to "Modem" value. 13. Go to "Qualcomm USB Settings". 14. Select "DM+MODEM+ADB". 15. Close window. 16. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SGH-I497 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM43 Port is busy ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM151 Selected model: SGH-I497 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM151 Selected model: SGH-I497 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM151 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM151 Selected model: SGH-I497 Warning: Selected model (SGH-I497) differs from the detected one (SAMSUNG-SGH-I497)! If you want select (SAMSUNG-SGH-I497) as (SGH-I497) model, please check "manual select". Reading Security failed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM151 Selected model: SGH-I497 Warning: Selected model (SGH-I497) differs from the detected one (SAMSUNG-SGH-I497)! If you want select (SAMSUNG-SGH-I497) as (SGH-I497) model, please check "manual select". Reading EFS was canceled. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM151 Selected model: SGH-I497 Reading info, please wait... Warning: Selected model (SGH-I497) differs from the detected one (SAMSUNG-SGH-I497)! If you want select (SAMSUNG-SGH-I497) as (SGH-I497) model, please check "manual select". ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM151 Selected model: SGH-I497 Reading info, please wait... Detected phone model: SAMSUNG-SGH-I497 Firmware compiled date: Wed Oct 10 12:16:46 KST 2012 Phone SN: R21CC00GY9X Android version: 4.0.4 (IMM76D) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM151 Selected model: SGH-I497 Phone was not found on the selected port! Selected action cant be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM151 Selected model: SGH-I497 Reading info, please wait... Detected phone model: SAMSUNG-SGH-I497 Firmware compiled date: Wed Oct 10 12:16:46 KST 2012 Phone SN: R21CC00GY9X Android version: 4.0.4 (IMM76D) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM151 Selected model: SGH-I497 Operation was canceled Reading EFS was canceled. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM151 Selected model: SGH-I497 Detected phone model: SAMSUNG-SGH-I497 Firmware compiled date: Wed Oct 10 12:16:46 KST 2012 Phone SN: R21CC00GY9X Android version: 4.0.4 (IMM76D) Reading EFS, please wait... EFS read successfully. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM151 Selected model: SGH-I497 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM151 Selected model: SGH-I497 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM151 Selected model: SGH-I497 Detected phone model: SAMSUNG-SGH-I497 Firmware compiled date: Wed Oct 10 12:16:46 KST 2012 Phone SN: R21CC00GY9X Android version: 4.0.4 (IMM76D) Reading Security, please wait... Security read successfully. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM151 Selected model: SGH-I497 Phone was not found on the selected port! Selected action cant be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM151 Selected model: SGH-I497 Phone was not found on the selected port! Selected action cant be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM151 Selected model: SGH-I497 Phone was not found on the selected port! Selected action cant be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM151 Selected model: SGH-I497 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM151 Selected model: SGH-I497 Phone was not found on the selected port! Selected action cant be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM151 Selected model: SGH-I497 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM151 Selected model: SGH-I497 Reading info, please wait... Detected phone model: SAMSUNG-SGH-I497 Firmware compiled date: Wed Oct 10 12:16:46 KST 2012 Phone SN: R21CC00GY9X Android version: 4.0.4 (IMM76D) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM151 Selected model: SGH-I497 Reading info, please wait... Detected phone model: SAMSUNG-SGH-I497 Firmware compiled date: Wed Oct 10 12:16:46 KST 2012 Phone SN: R21CC00GY9X Android version: 4.0.4 (IMM76D) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM151 Selected model: SGH-I497 Reading info, please wait... Warning: Selected model (SGH-I497) differs from the detected one (SAMSUNG-SGH-I497)! If you want select (SAMSUNG-SGH-I497) as (SGH-I497) model, please check "manual select". ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM152 Selected model: SGH-I497 Reading info, please wait... Warning: Selected model (SGH-I497) differs from the detected one (SAMSUNG-SGH-I497)! If you want select (SAMSUNG-SGH-I497) as (SGH-I497) model, please check "manual select". ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM152 Selected model: SGH-I497 Reading info, please wait... Detected phone model: SAMSUNG-SGH-I497 Firmware compiled date: Wed Oct 10 12:16:46 KST 2012 Phone SN: R21CC00GY9X Android version: 4.0.4 (IMM76D) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM152 Selected model: SGH-I497 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM152 Selected model: SGH-I497 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM152 Selected model: SGH-I497 Reading info, please wait... Detected phone model: SAMSUNG-SGH-I497 Firmware compiled date: Wed Oct 10 12:16:46 KST 2012 Phone SN: R21CC00GY9X Android version: 4.0.4 (IMM76D) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM152 Selected model: SGH-I497 Mode: Emergency NVM cant be repaired for SGH-I497 phone in emergency mode ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM152 Selected model: SGH-I497 Mode: Emergency Unlock for SGH-I497 phone in emergency mode cant be done |
09-20-2013, 17:22 | #15 (permalink) |
Member: 446363 Status: Offline Sonork: 1577571:rajtelecom Thanks Meter: 216 | To connect SGH-I497 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to Calculator application. 6. Enter "(+30012012732+" number, to get phone dial window. 7. Skip 8. Skip 9. Skip 10. Go to dial window. 11. Enter "*#7284#" number. 12. Set "USB" radio button to "Pda" value. 13. Go to "Qualcomm USB Settings". 14. Select "DM+MODEM+ADB". 15. Close window. 16. Press "Read Info" in software. |
