04-28-2015, 15:47 | #1 (permalink) |
No Life Poster Join Date: Sep 2005
Member: 185255 Status: Offline Thanks Meter: 42 | Sm g368t not unlocked [Answered] ----------------------------------------------------------------------------------- To connect GT-I9100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G386T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: SM-G386T_modem_for_direct_unlock.oct Please put the phone into Download Mode and connect USB cable. To put SM-G386T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Firmware writing successfully completed. Please put the phone into Download Mode and connect USB cable. To put SM-G386T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Firmware writing successfully completed. Please put the phone into Download Mode and connect USB cable. To put SM-G386T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SM-G386T Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Writing EFS failed. Platform: Samsung Android Selected port: COM12 Selected model: SM-G386T Reading info... Mode: Normal Firmware compiled date: Aug 07 2014 Firmware compiled time: 22:00:00 Firmware released date: Nov 26 2014 Firmware released time: 09:43:25 SW Version: MPSS.DI.2.0.c8-00076-M8926DAAAANAZM-1 Detected phone model: SM-G386T Firmware compiled date: Wed Nov 26 17:55:35 KST 2014 PDA version: G386TUVU1ANK3 CSC version: G386TTMB1ANK3 SW version: G386TUVU1ANK3 Phone IMEI: 358928061185732 Phone SN: R28F70AZKYF Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as Security-SM-G386T-28-04-2015_07-34-27 file Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) AFTER UNLOCKING BUT PHONE STILL LOCKED HELPPP Last edited by Octopus box; 04-29-2015 at 06:08. |
04-28-2015, 18:30 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Jr Telecom™
Member: 409725 Status: Offline Sonork: 100.1581478 Thanks Meter: 797 | Few steps ll b helpfull for u.. 1) Reflash with G386T1UVU1ANK3_G386T1TMB1ANK3_G386T1UVU1ANK3_HOME. tar 2) Root the phone 3) Select s a model 7102 @octopus 4) wife Efs 5) write certificate-attached network signal nd phone ll b unlocked successfully. |
The Following 2 Users Say Thank You to Jr Telecom For This Useful Post: |
