08-19-2018, 13:19 | #1 (permalink) |
Major Poster Join Date: Mar 2014 Location: Algeria
Member: 2156008 Status: Offline Thanks Meter: 2 | SM-G930T1 FRP Reset question [Answered] Last edited by Octopus box; 08-19-2018 at 19:10. |
08-19-2018, 14:02 | #4 (permalink) |
Freak Poster Join Date: Jan 2014
Member: 2110911 Status: Offline Thanks Meter: 22 | As far as i know all s7 variants from USA has firmware compatibility, you can flash an eng root to enable adb, also can downgrade if root doesnt works. This combination file is in support: COMBINATION_FA60_G930TUCU4AQB1_CL7396841_QB1270377 8_REV02.oct I use to flash G930VVZW4API3 on s7 bit 4, this is android 6.0 and allows enable usb debugging when power up the phone while press volume down and power at same time. BTW you need connect to a wifi network to bypass frp by adb., otherwise you'll e stucked on initial configuration from verizon wireless devices. |
08-19-2018, 19:16 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Yes, try to do as suggested mr. mexiquense in the previous post. If You don't want to risk to damage your device using incompatible Combination firmware, You can reset FRP via Octoplus Factory Reset FRP / Reactivation Service. Operation is not free and require Octoplus Server Credits, please look here: http://forum.gsmhosting.com/vbb/f684...018-a-2263590/. |
08-20-2018, 01:59 | #6 (permalink) | |
Freak Poster Join Date: Oct 2010 Location: USA
Member: 1420095 Status: Offline Thanks Meter: 216 | Quote:
Try Flash this: Samsung G930x QC Eng Boot https://www.androidfilehost.com/?fid=457095661767142259 If it doesn’t work, downgrade to 7.0 first before flashing Eng Boot.. Let me know! Good luck! Sent from my iPhone using Tapatalk | |
