05-28-2003, 02:07 | #47 (permalink) |
Insane Poster Join Date: Nov 2001 Location: indonesia
Member: 7441 Status: Offline Thanks Meter: 1 | @daniel. i have try simemu 6.00 but find a bug. (i use siemens m50). 1. in simemu 5.00 i can have 250 adn but in simemu 6.00 although i set to 250 the phone report 178 in capacity. 2. sms# only 50, but i think this because my phone can only read 50. 3. fdn no problem, 222. thanks |
05-28-2003, 19:04 | #48 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Spain Age: 62
Member: 10582 Status: Offline Thanks Meter: 99 | There is no BUG in SIM-EMU about that. That model of Siemens has a limitation of 400 entries between FDN and ADN giving priority to FDN. You have left the default value of 222 FDN's. The remainder from 400 is 178 that are left to ADN's. If you want more ADN's than FDN's, reconfigure the flash with, for example, 150 FDN's and 250 ADN's, and you should obtain efectively 250 ADN's. The limitation in SMS's in that model is 50 SMS's. Regards |
05-29-2003, 14:55 | #52 (permalink) |
Member: 10582 Status: Offline Thanks Meter: 99 | @hares14 Read the top of the post, please. @yaren The ADN is the normal phonebook. The FDN (Fixed Dialling Number) is a restricted phonebook that is activated using PIN2 in the corresponding phone menu. Once activated, only it is possible to makes calls to number of this list. Regards |
05-30-2003, 10:05 | #56 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Portugal Age: 49
Member: 6156 Status: Offline Thanks Meter: 3 | An .hex file is a text format that represents binary data (with checksums). If you open it in a programming software it should open correctly. If your programming software has "dual" display of the buffer (most have) showing on the left the binary data, on the right it's ASCII representation, on the right side you should *NOT* have "10000" ... |
05-31-2003, 12:18 | #57 (permalink) |
Freak Poster Join Date: Aug 2001 Location: RO
Member: 5992 Status: Offline Thanks Meter: 1 | I used in the past Dejan interface & sw to prog Gold and Silvercards with SE sw with succes, but now after I try to update my Silver SE4 to SE6.0s I get a lot of prog error... finally I succed to prog without error Silver-card but still not work... card rejected in any phone.... is there any other sw (for prog silv -SE6) that can vork with dejan interace ? any link available ? I have also an MQP prog PM48 but I have no idea if this support Silver card Thank you L. |
06-01-2003, 22:31 | #60 (permalink) |
Member: 10582 Status: Offline Thanks Meter: 99 | @nony_don Please, don't use versions put in another sites. Download from my page, because there, always will be the last and correct version. The ID2 version is the bad version of SIM-EMU. Regards |
New version SIM-EMU 6.00 for GreenCard 2 | simemu | Sim Cloning and Scaning | 140 | 04-27-2012 07:27 |
Special version SIM-EMU 5.00s for SilverCard - AVAILABLE | simemu | Sim Cloning and Scaning | 84 | 10-06-2007 23:39 |
New version SIM-EMU 5.00 for GreenCard | simemu | Sim Cloning and Scaning | 45 | 04-06-2003 22:39 |
SIM-EMU 5.00 for GreenCard (AVAILABLE) | simemu | Sim Cloning and Scaning | 7 | 09-13-2002 19:06 |
New version Sim-emu 4.00 | simemu | Sim Cloning and Scaning | 48 | 04-18-2002 09:26 |
