Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > Sim Cloning and Scaning
Old 11-20-2008, 20:18   #1 (permalink)
simemu's Avatar
Member: 10582
Thumbs up Revision SIM-EMU 6.02 (AVAILABLE)
It is possible to download exclusively from the following page:
http://simemu.cjb.net
News
Added compatibility for iPhone 3G of Movistar Spain
Although the iPhone 2G is full compatible with SIM-EMU 6.01, the Movistar Spain iPhone 3G (and perhaps others providers), check the existence of an unavailable record in SIM-EMU .
Notes
For this revision, it is necessary to reprogram the Flash and the external EEPROM, and introduce again all our phone numbers data by using the phone SIM-EMU menu or through the new SIM_EMU_6.02_CFG.exe v2.2 configurator program.
Regards
Old 11-22-2008, 17:05   #2 (permalink)
Member: 19644
Great Work - Thank You SIMEMU
The Following 3 Users Say Thank You to eurka For This Useful Post:
Old 11-23-2008, 01:55   #3 (permalink)
Member: 19644
Is this ver can run even on iphone 3g locked on AT&T
The Following 2 Users Say Thank You to eurka For This Useful Post:
Old 11-25-2008, 20:30   #4 (permalink)
crux's Avatar
Member: 30192
thread sticky
I will try this version
The Following 2 Users Say Thank You to crux For This Useful Post:
Old 11-25-2008, 21:01   #5 (permalink)
Member: 900132
Please advise what this software is used to take advantage of, and will it work for uk networks.
Thanking you indeed.
The Following 2 Users Say Thank You to RandyDandy For This Useful Post:
Old 11-27-2008, 18:30   #6 (permalink)
Member: 6358
While trying to use 6.02 configurator, this error appears on opening eeprom file SIM_EMU_EP_6.02.hex:
The Following 3 Users Say Thank You to fontelense For This Useful Post:
Old 11-28-2008, 01:51   #7 (permalink)
Member: 911152
same problem here, can anyone explain about it?
thanks
The Following User Says Thank You to atomikramp For This Useful Post:
Old 11-28-2008, 23:21   #8 (permalink)
wizz25's Avatar
Member: 209093
plzzz help same problem........
Old 11-29-2008, 11:10   #9 (permalink)
Member: 447709
help...... same problem..
Old 11-30-2008, 15:34   #10 (permalink)
simemu's Avatar
Member: 10582
@all
Today I have repaired the configurator. Download it again and try it.
Sorry for the incovenience.
Best regards
The Following User Says Thank You to simemu For This Useful Post:
Old 11-30-2008, 17:56   #11 (permalink)
Member: 447709
Ok, now work!!! thanks
The Following User Says Thank You to bgdance For This Useful Post:
Old 12-01-2008, 16:11   #12 (permalink)
Member: 911152
here comes another error
this happens when i click on "write to disk".
i just opened the files and removed all entries except the 0 number.
Old 12-01-2008, 18:03   #13 (permalink)
simemu's Avatar
Member: 10582
@atomikramp
To solve this problem, before "write to disk", enter a 0 in the Group ID1 field of the deleted positions.
I will fix it, sorry.
Old 12-01-2008, 19:45   #14 (permalink)
simemu's Avatar
Member: 10582
@all
Second fix is done. Download it again and try it.
Best regards
The Following 2 Users Say Thank You to simemu For This Useful Post:
Old 12-02-2008, 08:27   #15 (permalink)
Member: 911152
@simemu
you are the best
thnx a lot
Revision SIM-EMU 6.01 (AVAILABLE) simemu Sim Cloning and Scaning 171 05-18-2013 19:38
sim emu 6.xx and sim master III Gambosino Sim Cloning and Scaning 3 07-15-2003 11:55
@simemu when sim-emu 6.00 out. jsompis Sim Cloning and Scaning 17 01-24-2003 01:46
New revision Sim-Emu 4.10 (Available in a few days) simemu Sim Cloning and Scaning 59 07-18-2002 21:07
New revision SIM-EMU 4.01 simemu Sim Cloning and Scaning 54 06-20-2002 06:49
Page generated in 2.40993 seconds with 12 queries
