Miracle Box GSMCampus |
10-18-2013, 12:10 | #1 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Nigeria Age: 42
Member: 68752 Status: Offline Thanks Meter: 88 | New miracle box help Welcome to use miracle box(World's First Fuzzy Logic Based Tool) SoftWare Version 1.61 Update:13-10-10 Detection current driver version is low, you need to install the new drive. Drivers directory(..\BOX_Data\Drivers\Box Driver\xxx(1.8.0)) S/N: >>>>>About Firmware Version:1.10 Connected OK. Connecting Internet... You use Latest Miracte Software 1.61 >>Fuzzy Logic Method is very safe and reliable ! Any solution????????? Thanks in advance |
The Following 3 Users Say Thank You to hummy For This Useful Post: |
10-21-2013, 08:40 | #2 (permalink) |
Freak Poster Join Date: Jul 2006 Location: india Age: 43
Member: 307820 Status: Offline Thanks Meter: 17 | sir me miracle box user hu mere pass bahut sare mobile aaye hai rda/coolsand cpu wale lekin ek bhi mobile cholu nahi huwa jab ki mene un mobile ko format or write flash bhi karkr dekh liya hpir bhi mobile on nahi huawa agar aapke pass koi solution ho to batao |
10-21-2013, 08:45 | #3 (permalink) |
Member: 307820 Status: Offline Thanks Meter: 17 | sir mere pass miracle box hai lekin mene bahut se mobile rda/coolsand mobile sekhe hai jo format karne par chalu nahi hota or jo on hote hai vo band ho jate hai please gide me |
01-10-2014, 10:44 | #7 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1390082 Status: Offline Sonork: arfaat Thanks Meter: 1 | After installing my new miracle box, i tried running the software but it refused to connect. Welcome to use miracle box(World's First Fuzzy Logic Based Tool) SoftWare Version 1.72 Update:14-01-07 Detection current driver version is low, you need to install the new drive. Drivers directory(..\BOX_Data\Drivers\Box Driver\xxx(1.8.0)) Firmware Version:1.10 Connected OK. Connecting Internet... network connected error >>Fuzzy Logic Method is very safe and reliable ! Any solution????????? |
01-10-2014, 15:29 | #8 (permalink) |
No Life Poster Join Date: Jun 2011 Location: India Age: 37
Member: 1750704 Status: Offline Thanks Meter: 12,171 | first of all instal or update driver again if not work chnge drive or loctaion of set up like d or e Last edited by Harish Gulati; 01-13-2014 at 06:55. |
01-15-2014, 20:26 | #10 (permalink) |
No Life Poster Join Date: Oct 2009 Location: srilanka Age: 39
Member: 1133072 Status: Offline Thanks Meter: 505 | |
01-16-2014, 07:17 | #11 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1550639 Status: Offline Sonork: fordz Thanks Meter: 1 | i think your box is connected that error just tells you that your driver is not the latest one go to device manager update your driver browse to my computer....program files.......miracle box (..\BOX_Data\Drivers\Box Driver\xxx(1.8.0)) and your done hope it helps |
01-16-2014, 10:10 | #12 (permalink) |
Member: 1390082 Status: Offline Sonork: arfaat Thanks Meter: 1 | my problem is solved by the gsm srilanka thankyou very much but now icant connect to internet it says network connected error plz solve my problem sir Last edited by arfaat; 01-16-2014 at 10:17. |
01-17-2014, 08:40 | #15 (permalink) |
Member: 1133072 Status: Offline Thanks Meter: 505 | @ALL network conect eroor is normal, miracle old server changed, wait for new server address add for new update. dont care it and for ur job it not effect. |
The Following User Says Thank You to .::Gsm_Srilanka::. For This Useful Post: |
