HUA GOLD Old BY HUA TEAM |
12-01-2013, 10:31 | #211 (permalink) | |
Product Supporter Join Date: Jul 2008 Location: iran-shiraz
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | all box z3x bst Octoplus spt Quote:
Phone Found on COM4 Reading Phone Information ... Build No : M9615ACEHWMAZD179599 IMEI : 353575050531585 Reading Security ...OK Calculating Security ...OK Rebuilding Security... OK Resetting ...OK Operation Completed Operation Time: 00:00:23 | |
The Following 7 Users Say Thank You to dr_moosavi For This Useful Post: |
12-03-2013, 13:12 | #212 (permalink) |
Junior Member Join Date: Mar 2012 Location: Belarus/ Minsk
Member: 1736186 Status: Offline Thanks Meter: 23 | n7100 android 4.3 imei repair done. Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-N7100 Android Version : 4.3 PDA Version : N7100XXUEMK4 CS Version : N7100OXAEMI6 Phone Version : N7100DDEMJ9 IMEI : NULL Checking Root ...OK Phone Root OK. Continue.. Disabling Security ...Done! Rebooting... OK! Now Remove USB Cable and Wait Phone Powering Up Completely (Media Scanners Passed) Then insert UART cable to Phone to Continue Delay 60 Seconds... Searching for phone on COM4 ... Phone Found Reading Data from phone... Model : GT-N7100 S/W Version : N7100XXUEMK4 Unique ID : CVTF7F0A1206B21 Memory ID : - IMEI : none Verifying MSL ... OK Bypassing MSL ... OK Writing IMEI ... OK Reset Done! Operation Completed Operation Time: 00:01:41 |
12-04-2013, 18:21 | #213 (permalink) |
No Life Poster Join Date: Sep 2006 Location: India
Member: 350719 Status: Offline Sonork: 100.1623850 Thanks Meter: 158 | I9500 succesfully done imei null null ----------------------------------------------------------------------------------------------- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-I9500 Android Version : 4.3 PDA Version : I9500XXUEMJ5 CS Version : I9500OJVEMJ5 Phone Version : I9500XXUEMJ5 IMEI : NULL Checking Root ...OK Phone Root OK. Continue.. Disabling Security ...Done! Rebooting... OK! Now Remove USB Cable and Wait Phone Powering Up Completely (Media Scanners Passed) Then insert UART cable to Phone to Continue Delay 60 Seconds... Searching for phone on COM6 ... Phone Found Reading Data from phone... Model : GT-I9500 S/W Version : I9500XXUEMJ5 Unique ID : CV3001B1C72D740 Memory ID : - IMEI : none Verifying MSL ... OK Bypassing MSL ... OK Writing IMEI ... OK Reset Done! Operation Completed Operation Time: 00:01:16 download File1 or File2(you can download in support too) Open asansam select model press flash select file and press write flash(you can use odin for flash too) wait for phone reboot enter *#06# and check imei now(imei back now) select new/orginal imei and write on phone now |
The Following 2 Users Say Thank You to .::intel32::. For This Useful Post: |
12-16-2013, 14:08 | #214 (permalink) |
Freak Poster Join Date: May 2004 Location: TURKEY Age: 41
Member: 67431 Status: Offline Thanks Meter: 16 | i9505 4.3 imei repair succesfully done !! Searching for phone ... Phone Found On COM21 Reading Data from phone... Build No : M9615A-CEFWTAZM-4.0.17062 Writing IMEI ...OK Operation Completed Operation Time: 00:00:03 |
12-18-2013, 20:52 | #215 (permalink) |
Freak Poster Join Date: Jun 2013 Location: Dubai UAE
Member: 1951379 Status: Offline Sonork: 100.1647567 Thanks Meter: 149 | Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-I9300 Android Version : 4.1.2 PDA Version : I9300XXEMA2 CS Version : I9300OJVEMA1 Phone Version : I9300XXELLA IMEI : NULL Checking Root ...OK Phone Root OK. Continue.. Disabling Security ...Done! Rebooting... OK! Now Remove USB Cable then Insert Micro UART Cable to Phone to Continue.. Delay 40 Seconds... Searching for phone on COM5 ... Phone Found Reading Data from phone... Model : GT-I9300 S/W Version : I9300XXEMA2 Unique ID : CVTF1DA67356A6F Memory ID : - IMEI : none MSL Addr : 0000000000 Verifying MSL ... OK Bypassing MSL ... OK Writing IMEI ... OK Reset Done! Operation Completed Operation Time: 00:01:29 |
12-20-2013, 13:52 | #216 (permalink) | |
No Life Poster Join Date: Jan 2010 Location: IRAN
Member: 1222839 Status: Offline Sonork: 100.1603618 Thanks Meter: 3,944 | I927R IMEI repair Done . Quote:
BEHBOODI | |
The Following User Says Thank You to BEHBOODI For This Useful Post: |
12-21-2013, 01:01 | #217 (permalink) | ||||
No Life Poster Join Date: Oct 2004 Location: Budapest Age: 54
Member: 87188 Status: Online Thanks Meter: 229 | other box: Quote:
other box again Quote:
Asansam: Quote:
Only the Asansam could only do! info after repair::: Quote:
The Following 5 Users Say Thank You to Pufi164 For This Useful Post: |
12-27-2013, 13:30 | #218 (permalink) |
No Life Poster Join Date: Jan 2012 Location: prAy for nEpal
Member: 1710706 Status: Offline Sonork: 100.1645371 Thanks Meter: 61 | c2005 xperia M Dual flashing done...... Code: ----------------------------------------------------------------------------------------- Operation : Flash Model : C200X_Xperia M Dual ----------------------------------------------------------------------------------------- Comunication Pipeline Created ... OK ----------------------------------------------------------------------------------------- S1-MSM8230 BasePhone Detected. Continue... Uploading Applicable Loader...OK ----------------------------------------------------------------------------------------- Phone info: IMEI : 3580990 EROM Version : S1_Boot_MSM_8227_5 EROM ID : 1271-1024 AID Info| | ____ Loader : "0001" | ____ EROM : "" | ____ Software : "" | ____ Custom : "" | ____ SimLock : "" Rooting State : "ROOTABLE" Loader Version : loader_MSM8X30_10 Loader ID : 1269-1287 Unique Dev ID1 : 05834C97 ----------------------------------------------------------------------------------------- Setting Partitions... OK Uploading "cache_S1-SW-LIVE-DBE9-PID1-0002-MMC.sin"... OK Uploading "fotakernel_S1-SW-LIVE-DBE9-PID1-0002-MMC.sin"... OK Uploading "kernel_S1-SW-LIVE-DBE9-PID1-0002-MMC.sin"... OK Uploading "modem_fs1_S1-MODEMSW-LIVE-DBE9-PID1-0002-MMC.sin"... OK Uploading "modem_fs2_S1-MODEMSW-LIVE-DBE9-PID1-0002-MMC.sin"... OK Uploading "modem_S1-MODEMSW-LIVE-DBE9-PID1-0002-MMC.sin"... OK Uploading "rpm_S1-RPMFW-LIVE-DBE9-PID1-0002-MMC.sin"... OK Uploading "userdata_S1-SW-LIVE-DBE9-PID1-0002-MMC.sin"... OK Uploading "system_S1-SW-LIVE-DBE9-PID1-0002-MMC.sin"... OK Processing "simlock.ta" ... OK SimLock Data Detected. SKIPPED... Uploading "elabel-C2005-row_2013010151530.1_15.2.A.2.5_S1-CUST-LIVE-DBE9-PID1-0001-MMC.sin"... OK Phone Detached ----------------------------------------------------------------------------------------- Operation Completed Operation Time: 00:25:48 -------------------------------------------------------------- |
The Following User Says Thank You to myHWK For This Useful Post: |
12-30-2013, 09:45 | #219 (permalink) |
Crazy Poster Join Date: Nov 2007
Member: 632859 Status: Offline Thanks Meter: 9 | samsung I917R successfully read Unlock code... earching For Phone [SAMSUNG USB PORT]... Fail! Nothing Found any Samsung USB Port! Operation Completed Operation Time: 00:02:20 Searching For Phone [SAMSUNG USB PORT]... OK Phone Found on COM133 Reading Phone Information ... MSL Addr : R3WZB94916 Build No : 8650B-SDCAOWZM-2250 IMEI : 355169xxxxxxxxxx PDA/CSC Version : i917RUXKI4/i917RRWCKI4 Phone Version : i917RUXKI3 HW Version : REV1.3 Cal Date : 2010.11.19 Not Found any Record! Searching Database for Bypass MSL... Not Found any Record! Prepairing Phone for Finding Needed Data... Reading Security Area... OK External Database Updated. Bypass MSL... OK Reading Codes ... MCK : 80484168 NCK : 85184060 NSCK : 00000000 SPCK : 00000000 CPCK : 00000000 Finalizing ...OK Operation Completed Operation Time: 00:20:43 |
01-06-2014, 15:48 | #220 (permalink) |
No Life Poster Join Date: Nov 2008 Location: saudi arabia
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | i9100 imei changed with asan sam[ANSWERED] many time tried with z3x ,always ..error. now tried with ASAN SAM SUCCESFULLY CHANGED WITH THIS, Device Found! Reading Phone Informations ... Model : GT-I9100 Android Version : 2.3.3 PDA Version : I9100JPKG2 CS Version : I9100OJPKG1 Phone Version : I9100XXKF1 IMEI : 004999010640000 Checking Root ...OK Phone Root OK. Continue.. Disabling Security ...Done! Rebooting... OK! Now Remove USB Cable and Wait Phone Powering Up Completely (Media Scanners Passed) Then insert UART cable to Phone to Continue Delay 60 Seconds... Searching for phone on COM6 ... Phone Found Reading Data from phone... Model : GT-I9100 S/W Version : I9100JPKG2 Unique ID : CVY19914829D38E Memory ID : - IMEI : none Verifying MSL ... OK Bypassing MSL ... OK Writing IMEI ... OK Reset Done! Operation Completed Operation Time: 00:01:19 |
01-06-2014, 17:54 | #221 (permalink) |
Freak Poster Join Date: Aug 2013 Location: SomeWhere Over The Rainbow
Member: 2002163 Status: Offline Thanks Meter: 24 | GT-I9300 after Recovery dead boot via sdcrad method imei repair by ASB.. Remove Safemode ok..!! ----------------------------------------------------------------------------------------------- 2014/01/06 - 18:51:44 : Turn-on the Phone Goto 'Settings > Application > Development' 2014/01/06 - 18:51:44 : And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. 2014/01/06 - 18:51:44 : ----------------------------------------------------------------------------------------------- 2014/01/06 - 18:51:44 : Prepairing ... 2014/01/06 - 18:51:48 : OK 2014/01/06 - 18:51:48 : Device Found! 2014/01/06 - 18:51:52 : Cleaning... 2014/01/06 - 18:51:52 : OK 2014/01/06 - 18:51:52 : OK 2014/01/06 - 18:51:52 : Repairing... 2014/01/06 - 18:51:52 : OK 2014/01/06 - 18:51:52 : OK 2014/01/06 - 18:51:52 : Setting OwnerShips... 2014/01/06 - 18:51:52 : OK 2014/01/06 - 18:51:52 : OK 2014/01/06 - 18:51:52 : Setting Permissions... 2014/01/06 - 18:51:52 : OK 2014/01/06 - 18:51:52 : OK 2014/01/06 - 18:51:52 : Rebooting... 2014/01/06 - 18:51:53 : OK! 2014/01/06 - 18:51:53 : Operation Completed 2014/01/06 - 18:51:53 : Operation Time: 00:00:08 2014/01/06 - 18:51:53 : Imei Repair ..ok!! ----------------------------------------------------------------------------------------------- 2014/01/06 - 19:33:15 : ----------------------------------------------------------------------------------------------- 2014/01/06 - 19:33:15 : Turn-on the Phone Goto 'Settings > Application > Development' 2014/01/06 - 19:33:15 : And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. 2014/01/06 - 19:33:15 : ----------------------------------------------------------------------------------------------- 2014/01/06 - 19:33:15 : Prepairing ... 2014/01/06 - 19:33:20 : OK 2014/01/06 - 19:33:20 : Device Found! 2014/01/06 - 19:33:20 : Reading Phone Informations ... 2014/01/06 - 19:33:20 : 2014/01/06 - 19:33:20 : Model : GT-I9300 2014/01/06 - 19:33:20 : Android Version : 4.1.1 2014/01/06 - 19:33:20 : PDA Version : I9300XXDLJ4 2014/01/06 - 19:33:20 : CS Version : I9300OXADLJ4 2014/01/06 - 19:33:20 : Phone Version : I9300XXDLID 2014/01/06 - 19:33:20 : IMEI : NULL 2014/01/06 - 19:33:20 : Checking Root ... 2014/01/06 - 19:33:20 : OK 2014/01/06 - 19:33:20 : Phone Root OK. Continue.. 2014/01/06 - 19:33:21 : Disabling Security ... 2014/01/06 - 19:33:24 : Done! 2014/01/06 - 19:33:24 : Rebooting... 2014/01/06 - 19:33:24 : OK! 2014/01/06 - 19:33:24 : 2014/01/06 - 19:33:24 : Now Remove USB Cable then Insert Micro UART Cable to Phone to Continue.. 2014/01/06 - 19:33:24 : 2014/01/06 - 19:33:24 : Delay 40 Seconds... 2014/01/06 - 19:34:05 : Searching for phone on COM6 ... 2014/01/06 - 19:34:05 : Phone Found 2014/01/06 - 19:34:05 : Reading Data from phone... 2014/01/06 - 19:34:06 : Model : GT-I9300 2014/01/06 - 19:34:06 : S/W Version : I9300XXDLJ4 2014/01/06 - 19:34:06 : Unique ID : CVTF14AA22E157F 2014/01/06 - 19:34:06 : Memory ID : - 2014/01/06 - 19:34:06 : IMEI : none 2014/01/06 - 19:34:06 : MSL Addr : 0000000000 2014/01/06 - 19:34:06 : 2014/01/06 - 19:34:06 : Verifying MSL ... 2014/01/06 - 19:34:06 : OK 2014/01/06 - 19:34:06 : Bypassing MSL ... 2014/01/06 - 19:34:06 : OK 2014/01/06 - 19:34:06 : Writing IMEI ... 2014/01/06 - 19:34:06 : OK 2014/01/06 - 19:34:06 : Reset Done! 2014/01/06 - 19:34:07 : Operation Completed Phone ok..Network..OK... |
01-11-2014, 13:02 | #222 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: tr
Member: 539148 Status: Offline Thanks Meter: 2,174 | E1207T İMEİ Repair Dual Sim !!!! Quote:
01-11-2014, 17:56 | #223 (permalink) | ||
Freak Poster Join Date: Jul 2009 Location: paraguay
Member: 1086987 Status: Offline Sonork: 1617504 Thanks Meter: 109 | where all the other tools failed. asansan win! imei null unknow baseband solved!!! model i9500 S4 write ub file Quote:
repair imei Quote:
The Following 5 Users Say Thank You to miguelcpm22 For This Useful Post: |
01-12-2014, 18:37 | #224 (permalink) |
Member: 2002163 Status: Offline Thanks Meter: 24 | I9003 Movistar Direct unlock succes....!!! ----------------------------------------------------------------------------------------------- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Reading NVM ... OK Prepairing NVM ... OK Prepairing Cooking NVM STEP 1 ... OK Prepairing Cooking NVM STEP 2 ... OK Prepairing Cooking NVM STEP 3 ... OK Prepairing Cooking NVM STEP 4 ... OK Prepairing Cooking NVM STEP 5 ... OK Prepairing Cooking NVM STEP 6 ... OK Prepairing Cooking NVM STEP 7 ... OK Phone Reset Done! Operation Completed Operation Time: 00:00:21 ----------------------------------------------------------------------------------------------- |
The Following User Says Thank You to chupest For This Useful Post: |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
