HUA GOLD Old BY HUA TEAM |
02-05-2012, 14:52 | #3 (permalink) |
Product Supporter Join Date: Jul 2008 Location: iran-shiraz
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | i9000 unknown baseband done i9000 unknown baseband done root log Code: ------------------------------------------------------------------------------------------------ Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------------------------ Prepairing ...OK Device Found! Root Procedure Started! Prepairing ROOTFILE ... OK Rebooting To Recovery ... OK When Your Phone Enter in Recovery Mode Following This Steps: ------------------------------------------------------------------------------------------------ 1) Press The Volume Down until 'reinstall packages' is highlighted 2) After That Press Power Down to Packages Downloded to Your Phone When it Complete Your Phone Will Reboot and Rooted ------------------------------------------------------------------------------------------------ Root Procedure Finished! Operation Completed Operation Time: 00:00:14 Code: ------------------------------------------------------------------------------------------------ Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------------------------ Prepairing ...OK Device Found! Step1 ... OK Step2 ... OK Step3 ... OK Phone Reset Done! ------------------------------------------------------------------------------------------------ Operation Completed Operation Time: 00:00:12 |
The Following User Says Thank You to dr_moosavi For This Useful Post: |
02-05-2012, 15:05 | #4 (permalink) |
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | Next i9000 i9000 unknown baseband done Root Log Code: ------------------------------------------------------------------------------------------------ Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------------------------ Prepairing ...OK Device Found! Root Procedure Started! Prepairing ROOTFILE ... OK Rebooting To Recovery ... OK When Your Phone Enter in Recovery Mode Following This Steps: ------------------------------------------------------------------------------------------------ 1) Press The Volume Down until 'reinstall packages' is highlighted 2) After That Press Power Down to Packages Downloded to Your Phone When it Complete Your Phone Will Reboot and Rooted ------------------------------------------------------------------------------------------------ Root Procedure Finished! Operation Completed Operation Time: 00:00:12 Code: ------------------------------------------------------------------------------------------------ Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------------------------ Prepairing ...OK Device Found! Step1 ... OK Step2 ... OK Step3 ... OK Phone Reset Done! ------------------------------------------------------------------------------------------------ Operation Completed Operation Time: 00:00:16 |
02-08-2012, 15:05 | #5 (permalink) |
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | Read EFS Code: ------------------------------------------------------------------------------------- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------------------------ Prepairing ...OK Device Found! Model : GT-I9000 IMEI : 354795040487537 su: not found remote object '/sdcard/efs1.img' does not exist rm failed for /sdcard/efs1.img, No such file or directory Phone Reset Done! ------------------------------------------------------------------------------------------------ EFS Backed Up and saved in "C:/ASANSAM2/BACKUP/GT-I9000/354795040487537/EFS/IMG" DON'T RENAME OR MANIPULATING BACKUP FILES Operation Completed Operation Time: 00:00:06 |
02-22-2012, 16:27 | #13 (permalink) |
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | Arc lt15 repair ARC LT15 REPAIR Code: SEMC Android Phone 0% Fix Tool By ASANSAM TEAM For More Information Contact with (Sonork: 100.1590245) Hold Menu Button Then Connect USB Cable to Phone Prepairing ... OK Supported Version Detected. Continue. Unlocking Boot Loader ... OK Phone Boot Unlocked Successfully. Flashing Boot ... OK Phone Boot Flashed Successfully. Operation Completed. |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
