12-06-2014, 07:23 | #1 (permalink) |
Major Poster Join Date: Apr 2012
Member: 1746720 Status: Offline Sonork: captianjamil Thanks Meter: 4 | Volcano Box Team I need your Help and if i want to stop the command it doesn't stop, i have to use ctl + alt+ del then close the Volcano tool from the task manager, so i thought is the version then i downloaded VolcanoUtility_v2.8.3_Volcano Yellowstone the copy VolcanoUtility_v2.8.9_Volcano Module inside and run it, its doing the same thing whenever i send command and i want to stop it it doesn't stop, But without connecting any phone it work, So i want to know if its normal because other box work normal for me whenever i want to stop command it stop but Volcano it doesn't i have to restart my system or use ctl alt + del to close which is stressfull, or is there any thing that im missing or is there any volcano tool that work perfect? please help me , i tested it on window xp sp3 on window 7 32bit and window 8.1 64bit the same problem, thanks in advance |
12-06-2014, 07:32 | #2 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | seems driver issue reinstall latest drivers this happen to me but not always but sometime , sometime this heppend too if connectivity cable is loose. |
12-06-2014, 07:52 | #3 (permalink) | |
Member: 1746720 Status: Offline Sonork: captianjamil Thanks Meter: 4 | Quote:
Profilic_Win8_x64_x86, i will appreciate if u can provide me the driver u use it always show like this Internal version: SPRD3 Boot downloaded. >>Start boot please wait a moment.... | |
12-11-2014, 08:57 | #6 (permalink) |
Freak Poster Join Date: Sep 2012 Location: BANGLADESH
Member: 1813575 Status: Online Thanks Meter: 90 | after set pinout right click mouse -clear all tips-go to mtk tab and do operation. you must press boot key. |
The Following User Says Thank You to ..:ALAK:.. For This Useful Post: |
12-11-2014, 12:13 | #8 (permalink) |
Member: 355782 Status: Offline Thanks Meter: 1,265 | if you are using P05B jig set pins as below; 1 (VCC) 2 (D-) 3 (D+ 4 (GND) 5 (GND) |
The Following User Says Thank You to Nasir Mobiles For This Useful Post: |
12-11-2014, 16:30 | #9 (permalink) |
Member: 1746720 Status: Offline Sonork: captianjamil Thanks Meter: 4 | thank you all the i just installed the box in my brother system voila it work for the first time and also i don't know that im not pressing the boot key, i thought the on button is the boot key button the boot key is a combination of keys like vol - or vol + and vol - |
