10-21-2014, 13:54 | #1 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2277168 Status: Offline Thanks Meter: 1 | problem with unlocking Plug USB cable holding "Volume Down" button Conexión establecida al puerto USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Chip:MSM7225A Model:ST21i IMEI:35587505-58xxxx AID:0002 Color:RED DEVICE_ID: CE6702E8C1193C8E6697ECD43A2282A72F8AB086 EROM: 1257-7605 R10D030 Enviando logic MSM7225A: Enviando LoaderLIVE...OK Detectando tipo de flash...OK ID: SSD Size: 3728 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Prcessing SIMLock signature... Failed to sign, code: 0000 Proceso abortado. Tiempo total [8 seg] i have update card but still have this problem |
10-22-2014, 18:02 | #3 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Ukraine Age: 44
Member: 13611 Status: Offline Sonork: 1 Thanks Meter: 368 | Hi, please attach full log next time (from the very first line) Make sure you are using the latest 4SE version 2.0.4 and correct card-reader drivers BR |
10-23-2014, 13:33 | #4 (permalink) |
Member: 2277168 Status: Offline Thanks Meter: 1 | 4SE - tool 2.0.4 (S/N:00000xxxxxx V2.0) Selected model: Xperia™ tipo dual (ST21) Selected operation: Desbloqueo Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Checking ADB drivers status...FAILED Install ADB drivers before starting Unlock operation Remove battery, wait a few seconds and insert it back Plug USB cable holding "Volume Down" button Conexión establecida al puerto USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Chip:MSM7225A Model:ST21i IMEI:35587505-585xxxx-x AID:0002 Color:RED DEVICE_ID: CE6702E8C1193C8E6697ECD43A2282A72F8AB086 EROM: 1257-7605 R10D030 Enviando logic MSM7225A: Enviando LoaderLIVE...OK Detectando tipo de flash...OK ID: SSD Size: 3728 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Prcessing SIMLock signature... Failed to sign, code: 6B77 Proceso abortado. Tiempo total [8 seg] here is complete log again i tried Darkmen |
10-25-2014, 16:21 | #8 (permalink) |
Member: 13611 Status: Offline Sonork: 1 Thanks Meter: 368 | Hi, unfortunately i cant repeat this kind of error. But i suspect its about DEFAULT reader drivers. Please PM me your TeamViewer details for remote help BR |
10-27-2014, 11:57 | #12 (permalink) |
Member: 2277168 Status: Offline Thanks Meter: 1 | card has updated successfully card drivers installed correctly..goes oll well but in final it said error very strange brother..because before update it was working well i did unlocked oll these modelos without problem!!! |
