10-09-2013, 13:20 | #556 (permalink) |
No Life Poster Join Date: Feb 2009 Location: https://jabaunlock.com/
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks Meter: 221 | Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding "C" button Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:NEPTUNE Model:W302 IMEI:35653502-440134-6 AID:0002 Color:RED DEVICE_ID: 120200102F030E140000000067280000 EROM: 1207-7713 R7A021 Uploading logic NEPTUNE: Reading TA security data...OK Authenticating with key KIDP96_S1_PRODUCTION_R1G...OK Searching for SIMLock check...FOUND Removing SIMlock...OK Resetting phone lock...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [18sec] |
10-10-2013, 10:03 | #557 (permalink) |
Freak Poster Join Date: Feb 2012 Location: pakistan Age: 30
Member: 1724706 Status: Offline Sonork: 100.1622356 Thanks Meter: 63 | 4SE - tool 1.9.1 (S/N:00000000119D V1.1) Selected model: T303 Selected operation: Phone lock reset Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding "C" button Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:LOCOSTO Model:T303 IMEI:35778802-032139-3 AID:0002 Color:RED DEVICE_ID: 0F023032C2006F6800000000434E0000 EROM: CXC1250616 R5A036 Uploading logic LOCOSTO: Sending LoaderLIVE...OK Detecting flash type...OK ID: 0089/8904 (Intel) Chip: Intel 256 Mbit NOR (top boot) Logical address: 0x06000000 Size: 32 Mb OTP: LOCKED Reading TA security data...OK Resetting phone lock...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [10sec] |
10-16-2013, 09:50 | #558 (permalink) |
No Life Poster Join Date: Jan 2010 Location: fontecno
Member: 1201378 Status: Offline Sonork: 100.1594717 Thanks Meter: 303 | 4SE - tool 1.9.1 Selected model: W910 Selected operation: Desbloqueo Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Conexión establecida al puerto USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Enviando Preloader...OK Enviando IDloader...OK ChipSetB3150 Modelo:W910i IMEI:35832302-217526-3 CID:52 Dominio/Color:RED OTP LOCKED:1 CID:52 PAF:1 Enviando logic DB3150: Detectando tipo de flash...OK ID: 20A1 (ST) Chip: ST 1024 Mbit NAND (large page) Logical address: 0x80000000 Size: 132 Mb Reading TA security data...OK Enviando CSLoader...OK Autenticando con KEY KIDP96_EMP_DUMP_R1A...OK Leyendo CLAVE UNICA del terminal...OK CLAVE UNICA del dispositivo:90854508DF1CE36D2C67972440BF8BDD Reiniciando terminal...OK Conexión establecida al puerto USB1 Identificando terminal...OK Enviando Preloader...OK Enviando ResetLoader...OK Autenticando con KEY KIDP96315035...OK Reseteando a los valores de fábrica...OK Reiniciando terminal...OK Conexión establecida al puerto USB1 Identificando terminal...OK Enviando Preloader...OK Enviando ProductionLoader...OK Escribiendo SEMCBOOT...OK Cambiando Certificado/CID a RED...OK Recompilando área de seguridad...OK Apagando terminal...OK Operation completed successfully. You can disconnect the phone now Proceso finalizado. Tiempo total [33 seg] |
10-16-2013, 10:36 | #559 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | Sonyericsson Xperia x10i remove pattern lock done Code: 4SE - tool 1.8.9 Selected model: Xperia™ X10 mini (E10) Selected operation: Phone lock reset Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227 Model:E10i IMEI:01240300-011419-1 AID:0001 Color:RED DEVICE_ID: 5C395E01C6403126DC42291ABD0CE4005D2F3253 EROM: 1229-3593 R8A029 Uploading logic MSM7227: Sending LoaderLIVE...OK Detecting flash type...OK ID: 20BC (ST) Chip: ST 4096 Mbit NAND (large page) Logical address: 0x08000000 Size: 528 Mb OTP: LOCKED Reading TA security data...OK Resetting phone lock...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [3sec] |
10-16-2013, 10:37 | #560 (permalink) |
Member: 637351 Status: Offline Thanks Meter: 167 | X10i mini unloked successfully Code: Selected model: Xperia™ X10 mini (E10) Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Checking ADB drivers status...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227 Model:E10i IMEI:01240300-011419-1 AID:0001 Color:RED DEVICE_ID: 5C395E01C6403126DC42291ABD0CE4005D2F3253 EROM: 1229-3593 R8A029 Uploading logic MSM7227: Sending LoaderLIVE...OK Detecting flash type...OK ID: 20BC (ST) Chip: ST 4096 Mbit NAND (large page) Logical address: 0x08000000 Size: 528 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Disconnect USB cable, power on the phone and boot Android OS Enable USB Debug in Applications menu, make sure ADB drivers installed. Connect USB cable Starting ADB server...OK(v1.0.29) Waiting for CB511M2EQ9...OK Disabling security...OK Waiting for CB511M2EQ9...OK Removing NAND restrictions...OK Waiting for CB511M2EQ9...OK Disabling security...OK Waiting for CB511M2EQ9...OK Installing required module...OK Writing S1boot image...OK Rebooting device...OK Operation completed successfully. You can disconnect the phone now FINISHED [677sec] |
10-21-2013, 12:03 | #561 (permalink) |
Member: 637351 Status: Offline Thanks Meter: 167 | E15i unlocked successfully.. Code: Selected model: Xperia™ X8 (E15) Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Checking ADB drivers status...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227 Model:E15i IMEI:35845204-668905-6 AID:0001 Color:RED DEVICE_ID: BAB659B8274D55A04012C476BAFBA2BD4712700F EROM: 1229-3593 R8A029 Uploading logic MSM7227: Sending LoaderLIVE...OK Detecting flash type...OK ID: 2CBC (Micron) Chip: Micron 4096 Mbit NAND (large page) x16 Logical address: 0x08000000 Size: 528 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Disconnect USB cable, power on the phone and boot Android OS Enable USB Debug in Applications menu, make sure ADB drivers installed. Connect USB cable Starting ADB server...OK(v1.0.29) Waiting for BX902N2CCC...OK Disabling security...OK Waiting for BX902N2CCC...OK Removing NAND restrictions...OK Waiting for BX902N2CCC...OK Disabling security...OK Waiting for BX902N2CCC...OK Installing required module...OK Writing S1boot image...OK Rebooting device...OK Operation completed successfully. You can disconnect the phone now FINISHED [421sec] |
10-22-2013, 14:21 | #563 (permalink) |
No Life Poster Join Date: Dec 2008 Location: MANSEHRA
Member: 921094 Status: Offline Sonork: 100.1603246 Thanks Meter: 326 | Lt26 patteren unlock done 4SE - tool 1.9.1 Selected model: Xperia™ S (LT26) Selected operation: Phone lock reset Selected interface: USB (EROM) Checking USB driver status...FAILED (Device record missing) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Volume Down" button Connected to USB3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM8x60 Model:LT26w IMEI:35337505-528075-3 AID:0001 Color:RED DEVICE_ID: 03461104 EROM: 1247-3874 R10C008 Uploading logic MSM8x60: Sending LoaderLIVE...OK Detecting flash type...OK ID: SSD Size: 14910 Mb OTP: LOCKED Reading TA security data...OK Resetting phone lock...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [5sec] |
10-31-2013, 11:06 | #564 (permalink) |
No Life Poster Join Date: Sep 2011 Location: a
Member: 1647504 Status: Offline Thanks Meter: 236 | SO-01B unlock OK 4SE - tool 1.9.1 Selected model: Xperia™ X10 (SO-01B) Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Checking ADB drivers status...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB9 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:QSD8250 Model:SO-01B IMEI:35949603-487074-8 AID:0001 Color:RED DEVICE_ID: 2AB6C2F1B42B8A7D3738E91EEDC1B6A9C96C81C1 EROM: 1226-2253 R8A013 Uploading logic QSD8250: Sending LoaderLIVE...OK Detecting flash type...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x08000000 Size: 1056 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Disconnect USB cable, power on the phone and boot Android OS Enable USB Debug in Applications menu, make sure ADB drivers installed. Connect USB cable Starting ADB server...OK(v1.0.29) Waiting for CB511L83Z0...OK Disabling security...OK Waiting for CB511L83Z0...OK Installing required module...OK Writing S1boot image...OK Rebooting device...OK Operation completed successfully. You can disconnect the phone now FINISHED [119sec] |
11-01-2013, 11:00 | #565 (permalink) |
Member: 1724706 Status: Offline Sonork: 100.1622356 Thanks Meter: 63 | K750 Successfuly Unlocked 4SE - tool 1.9.1 (S/N:00000000119D V1.1) Selected model: K750 Selected operation: Unlock Selected interface: UART (BOOTROM) Remove battery, wait a few seconds and insert it back Connect cable and press "Power" button shortly Connected to COM4 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Starting GDFS service...OK Reading GDFS security data...OK ChipB2010 Model:K750i IMEI:35255701-397479-8 CID:49 Domain:RED OTP LOCKED:1 CID:49 PAF:1 Uploading logic DB2010: Detecting flash type...OK ID: 200D (ST) Chip: ST Tyax 256 Mbit NOR (top boot) Logical address: 0x44000000 Size: 32 Mb Shutting down device...OK Remove battery, wait a few seconds and insert it back Connect cable and press "Power" button shortly Connected to COM4 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2010: Sending ResetLoader...OK Authenticating with key KIDP96201233...OK Reseting to factory defaults...OK Shutting down device...OK Remove battery, wait a few seconds and insert it back Connect cable and press "Power" button shortly Connected to COM4 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Uploading logic DB2010: Sending ProductionLoader...OK Writing EROM...OK Writing SIMLock data...OK Changing certificate to A1_DB2010_49_RED...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [73sec] |
11-02-2013, 11:32 | #566 (permalink) |
Freak Poster Join Date: Nov 2005 Location: italy vicenza
Member: 196627 Status: Offline Sonork: 1608298 Thanks Meter: 6 | Password google ok Modello selezionato: Xperia™ U (ST25) Operazione selezionata: Phone lock reset Interfaccia selezionata: USB (EROM) Verifica dello stato del driver USB...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Rimuovere la batteria, attendere alcuni secondi ed inserirlo nuovamente Collegare il cavo USB tenendo premuto il tasto "Volume Down" Connesso a USB1 Ora č possibile rilasciare i tasti e consentire il processo per l'esecuzione. Non scollegare il telefono Identificazione del dispositivo...OK Chip:STE U8500 Modello:ST25i IMEI:35445705-949503-0 AID:0001 Colore: RED DEVICE_ID: E08DCFA59E31F581BB25DE1E9E2755A8E7D51F2D EROM: 1240-4128 R10E013 Caricamento della logica STE U8500: Invio di LoaderLIVE...OK Rilevamento tipo di flash...OK ID: SSD Dimensione: 7576 Mb OTP: LOCKED Leggere TA dati di sicurezza...OK Resetting phone lock...OK Spegnimento del dispositivo...OK Operazione completata. Č possibile scollegare il telefono ora FINITO [3sec] |
11-08-2013, 07:45 | #567 (permalink) |
No Life Poster Join Date: Jul 2009 Location: chandigarh INDIA
Member: 1066865 Status: Offline Thanks Meter: 593 | 4SE - tool 1.9.0 (S/N:00000000042B V1.1) Selected model: Xperia™ ray (ST18) Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...FAILED (Device record missing) Remove battery. Link the TestPoint to GND and then plug USB cable Connected to USB7 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification... Connecting DLOAD...OK (PBL_DownloaderVER1.0) Sending Preloader...OK Connected to USB7 Sending LoaderTEST...OK Chip:MSM8x55 Model:ST18a IMEI:35834404-044462-2 AID:0001 Color:BROWN DEVICE_ID: 2BA3C690D0D70243F78CFFE9DD61CB7B8B86E50E Uploading logic MSM8x55: Detecting flash type...OK ID: ECB3 (Samsung) Chip: Samsung 8192 Mbit NAND (large page) x16 Logical address: 0x00000000 Size: 1056 Mb Logical block size: 0x40000 Logical blocks count: 0x1000 OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Writing S1boot image...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [62sec] |
11-13-2013, 11:53 | #569 (permalink) |
Registered User Join Date: Jan 2008 Location: on gsm heart Age: 36
Member: 685523 Status: Offline Sonork: 100.1603487 Thanks Meter: 381 | c510 unlock secssses fully 4SE - tool 1.9.1 (S/N:0000000000C3 V1.1) Selected model: C510 Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding both "2" and "5" buttons Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Sending Preloader...OK Sending IDloader...OK ChipB3210 Model:C510 IMEI:35204503-957443-8 CID:52 Domain:RED OTP LOCKED:1 CID:52 PAF:1 Uploading logic DB3210: Detecting flash type...OK ID: ECAA (Samsung) Chip: Samsung 2048 Mbit NAND (large page) x08 Logical address: 0x80000000 Size: 264 Mb Reading TA security data...OK Sending CSLoader...OK Authenticating with key KIDP96_EMP_DUMP_R1A...OK Reading unique device key...OK Device key:6996E747090AB0E1A538D27917E7E4C3 Restarting device...OK Connected to USB1 Device identification...OK Sending Preloader...OK Sending ResetLoader...OK Authenticating with key KIDP96321035...OK Reseting to factory defaults...OK Restarting device...OK Connected to USB1 Device identification...OK Sending Preloader...OK Sending ProductionLoader...OK Writing SEMCBOOT...OK Changing certificate to RED...OK Recompiling security area...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [22sec] |
