06-22-2013, 18:34 | #511 (permalink) |
No Life Poster Join Date: Feb 2009 Location: https://jabaunlock.com/
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks Meter: 221 | 4SE - tool 1.9.0 Warning: You must update the smart card. Required software available at http://www.4se.com/downloads Selected model: Xperia™ X10 (X10) Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Checking ADB drivers status...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:QSD8250 Model:X10a IMEI:01249600-065341-6 AID:0001 Color:RED DEVICE_ID: C38948F52EBBC595266B8012F3DFF1C769851D0C EROM: 1226-2253 R8A031 Uploading logic QSD8250: Sending LoaderLIVE...OK Detecting flash type...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x08000000 Size: 1056 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Disconnect USB cable, power on the phone and boot Android OS Enable USB Debug in Applications menu, make sure ADB drivers installed. Connect USB cable Starting ADB server...OK(v1.0.29) Waiting for CB511TGFZJ...OK Disabling security...OK Waiting for CB511TGFZJ...OK Installing required module...OK Writing S1boot image...OK Rebooting device...OK Operation completed successfully. You can disconnect the phone now FINISHED [166sec] |
06-22-2013, 18:35 | #512 (permalink) |
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks Meter: 221 | Sony Ericson X10a unlocked 4SE - tool 1.9.0 Warning: You must update the smart card. Required software available at http://www.4se.com/downloads Selected model: Xperia™ X10 (X10) Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Checking ADB drivers status...OK Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:QSD8250 Model:X10a IMEI:01249600-065341-6 AID:0001 Color:RED DEVICE_ID: C38948F52EBBC595266B8012F3DFF1C769851D0C EROM: 1226-2253 R8A031 Uploading logic QSD8250: Sending LoaderLIVE...OK Detecting flash type...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x08000000 Size: 1056 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Disconnect USB cable, power on the phone and boot Android OS Enable USB Debug in Applications menu, make sure ADB drivers installed. Connect USB cable Starting ADB server...OK(v1.0.29) Waiting for CB511TGFZJ...OK Disabling security...OK Waiting for CB511TGFZJ...OK Installing required module...OK Writing S1boot image...OK Rebooting device...OK Operation completed successfully. You can disconnect the phone now FINISHED [166sec] |
06-23-2013, 13:22 | #513 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1965404 Status: Offline Thanks Meter: 0 | iam to lazy to get logs, but want to say few words about 4se. Well iam killed my phone by OCTOPUS suite, in real crashed my TA, after all flashmode and fastboot didnt worked anymore and coz guys from Octopus stupid abit, to make TA recovery from testpoint, they made it by flashmode (but how, if TA broken and vol- and vol+ stopped to work in this way) ... anyway iam tried Omnius, adb commands ... iam tried lots of things and nothing helped. Well about 4se .. somewhere, after 24h of googling i found one post at some forum, where guy had around same problem with me. Ok iam bought 1day license for 15$ ... then installed program and ? its didnt worked for me, something was wrong with testpoint capture, but all other programs like octopus, omnius, s1tool worked with testpoint perfectly. Then i found support contacts and thanks ***, they really cares about *******rs. I just forgot to checkout drivers for 4SE, we did that and everything worked fine. Installed new TA from 4SE, after installed new OS and just after that used Octopus TA backup file what i got from it. For now everything working like it should be. Thanks to 4SE community for everything |
06-26-2013, 11:22 | #514 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Paris Age: 48
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | 4SE - tool 1.9.0 (S/N:000000000Nad V1.1) Modèle choisi: Xperia™ X10 (X10) Sélectionner l’opération: Déblocage Interface sélectionnée: USB (EROM) Vérification de l'état du pilote USB...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Vérification du pilote ADB...OK Retirez la batterie, attendez quelques secondes et réinsérez Branchez le câble USB en tenant le bouton "Retour" Connecté à l'USB1 Vous pouvez maintenant relâcher les touches et continuer à l'exécution du processus. Ne déconnectez pas le téléphone Identification de l'appareil...OK Chip:QSD8250 Modèle:X10i IMEI:01259000-196644-5 AID:0001 Couleur:RED DEVICE_ID: E131D199909D399DF0AEE045286EC58BBDE62084 EROM: 1226-2253 R8A031 Téléchargement logique QSD8250: Envoi LoaderLIVE...OK Détection du type de flash...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Adresse logique: 0x08000000 Taille: 1056 Mb OTP: LOCKED Lecture des données de sécurité TA...OK Ouverture TA ...OK La lecture des données du SimLock...OK Réinitialisation de verrouillage du téléphone...OK Certificat d'origine HwConf détecté Traitement SimLock la signature...OK Ouverture TA ...OK Ecriture des données SimLock...OK Débranchez le câble USB, allumez le téléphone et démarrage d’ Android Activer le Debugage USB dans le menu Applications, assurez-vous que les pilotes de la ADB soit installée. Rebrancher le câble USB Lancement serveur ADB...OK(v1.0.29) Patience CB511RRU50...OK Désactivation de la sécurité...OK Patience CB511RRU50...OK Installation du module nécessaire...OK Ecriture d'une image S1boot...OK Redémarrage du dispositif...OK L'opération s'est terminée avec succès. Vous pouvez déconnecter le téléphone maintenant FINI [222sec] |
06-26-2013, 11:25 | #515 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | 4SE - tool 1.9.0 (S/N:000000000Nad V1.1) Modèle choisi: Xperia™ X8 (E15) Sélectionner l’opération: Déblocage Interface sélectionnée: USB (EROM) Vérification de l'état du pilote USB...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Vérification du pilote ADB...FAILED Installez les pilotes ADB avant de commencer le déblocage Retirez la batterie, attendez quelques secondes et réinsérez Branchez le câble USB en tenant le bouton "Retour" Connecté à l'USB1 Vous pouvez maintenant relâcher les touches et continuer à l'exécution du processus. Ne déconnectez pas le téléphone Identification de l'appareil...OK Chip:MSM7227 Modèle:E15i IMEI:01268500-744568-1 AID:0001 Couleur:RED DEVICE_ID: 94FD671A7A9EF0C4D1A20FB188F78CAB5CCD481E EROM: 1229-3593 R8A029 Téléchargement logique MSM7227: Envoi LoaderLIVE...OK Détection du type de flash...OK ID: 20BC (ST) Chip: ST 4096 Mbit NAND (large page) Adresse logique: 0x08000000 Taille: 528 Mb OTP: LOCKED Lecture des données de sécurité TA...OK Ouverture TA ...OK La lecture des données du SimLock...OK Réinitialisation de verrouillage du téléphone...OK Certificat d'origine HwConf détecté Traitement SimLock la signature...OK Ouverture TA ...OK Ecriture des données SimLock...OK Débranchez le câble USB, allumez le téléphone et démarrage d’ Android Activer le Debugage USB dans le menu Applications, assurez-vous que les pilotes de la ADB soit installée. Rebrancher le câble USB Lancement serveur ADB...OK(v1.0.29) Patience BX902FNB5G...OK Désactivation de la sécurité...OK Patience BX902FNB5G...OK Suppression des restrictions NAND...OK Patience BX902FNB5G...OK Désactivation de la sécurité...OK Patience BX902FNB5G...OK Installation du module nécessaire...OK Ecriture d'une image S1boot...OK Redémarrage du dispositif...OK L'opération s'est terminée avec succès. Vous pouvez déconnecter le téléphone maintenant FINI [228sec] |
06-26-2013, 11:27 | #516 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | 4SE - tool 1.9.0 (S/N:000000000Nad V1.1) Modèle choisi: Xperia™ ray (ST18) Sélectionner l’opération: Déblocage Interface sélectionnée: USB (BOOTROM) Vérification de l'état du pilote USB...ÉCHEC (Enregistrement de périphérique manquant) Retirez la batterie. Lier le TestPoint à GND, puis branchez le câble USB Connecté à l'USB1 Vous pouvez maintenant relâcher les touches et continuer à l'exécution du processus. Ne déconnectez pas le téléphone Identification de l'appareil... Connexion DLOAD...OK (PBL_DownloaderVER1.0) Envoi Preloader...OK Connecté à l'USB1 Envoi LoaderTEST...OK Chip:MSM8x55 Modèle:ST18i IMEI:35834304-335900-1 AID:0001 Couleur:BROWN DEVICE_ID: 3119F680D26B4C648A8EEBEE7844871AB7E1822C Téléchargement logique MSM8x55: Détection du type de flash...OK ID: ECB3 (Samsung) Chip: Samsung 8192 Mbit NAND (large page) x16 Adresse logique: 0x00000000 Taille: 1056 Mb Taille de bloc logique: 0x40000 Compte blocs logique: 0x1000 OTP: LOCKED Lecture des données de sécurité TA...OK Ouverture TA ...OK La lecture des données du SimLock...OK Réinitialisation de verrouillage du téléphone...OK Certificat d'origine HwConf détecté Traitement SimLock la signature...OK Ouverture TA ...OK Ecriture des données SimLock...OK Ecriture d'une image S1boot...OK Arrêt dispositif de...OK L'opération s'est terminée avec succès. Vous pouvez déconnecter le téléphone maintenant FINI [35sec] |
06-29-2013, 10:39 | #517 (permalink) |
No Life Poster Join Date: Dec 2008 Location: MANSEHRA
Member: 921094 Status: Offline Sonork: 100.1603246 Thanks Meter: 326 | unlock done so-02c LOG Code: 4SE - tool 1.9.0 Selected model: Xperia™ acro (SO-02C) Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery. Link the TestPoint to GND and then plug USB cable Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification... Connecting DLOAD...OK (PBL_DownloaderVER1.0) Sending Preloader...OK Connected to USB1 Sending LoaderTEST...OK Chip:MSM8x55 Model:SO-02C IMEI:35798504-463929-3 AID:0001 Color:BROWN DEVICE_ID: FC9A56D838FFCC2E267AD3AF3027E277F705225F Uploading logic MSM8x55: Detecting flash type...OK ID: 98B3 (Toshiba) Chip: Toshiba 8192 Mbit NAND (large page) x16 Logical address: 0x00000000 Size: 1056 Mb Logical block size: 0x20000 Logical blocks count: 0x2000 OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Writing S1boot image...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [39sec] |
07-04-2013, 22:06 | #518 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Poland Pruszków-Warszawa-Warka
Member: 290272 Status: Offline Thanks Meter: 431 | 4SE - tool 1.9.0 (S/N:132F00949B66 V1.0) Wybrany model: Xperia™ tipo (ST21) Wybrana operacja: Flash Wybrany interfejs: USB (EROM) Sprawdzanie sterowników USB...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Wyciągnij baterię, odczekaj kilka sekund i włóż ponownie Podłącz kabel USB trzymając przycisk "Głośność -" Podłączony przez USB1 Możesz teraz puścić przyciski. Nie odłączaj telefonu. Identyfikacja telefonu...OK Chip:MSM7225A Model:ST21i IMEI:353XXXXX-XXXXXX-X AID:0002 Kolor:RED DEVICE_ID: FA753248C0316FC2FCF2E89D5F125190A68CDFBD EROM: 1257-7605 R10D030 Wgrywanie MSM7225A: Wysyłanie LoaderLIVE...OK Wykrywanie typu flasha...OK ID: SSD Rozmiar: 3728 Mb OTP: LOCKED Odczyt obszaru zabezpieczeń TA...OK ST21i 0002 Red (11.0.A.0.16 | 1264-4803/R7D) ST21I/MOBILE PHONE/T-MOBILE PL (POLAND)/(SS)CLASSI Programowanie obrazu partition-image_S1-SW-LIVE-A8A4-PID1-0002-MBR.sinOK Przetwarzanie.... Programowanie obrazu cache_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sinOK Programowanie obrazu kernel_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sinOK Programowanie obrazu fota0_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sinOK Programowanie obrazu fota1_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sinOK Programowanie obrazu amss_S1-MODEMSW-LIVE-A8A4-PID1-0002-S1-PARTITION.sinOK Przetwarzanie.... Programowanie obrazu system_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sinOK Programowanie obrazu userdata_S1-SW-LIVE-A8A4-PID1-0002-S1-PARTITION.sinOK Programowanie obrazu amss_fsg_S1-MODEMSW-LIVE-A8A4-PID1-0002-S1-PARTITION.sinOK Programowanie obrazu modem_fs1_S1-MODEMSW-LIVE-A8A4-PID1-0002-S1-PARTITION.sinOK Programowanie obrazu modem_fs2_S1-MODEMSW-LIVE-A8A4-PID1-0002-S1-PARTITION.sinOK Odłączanie telefonu...OK Operacja zakończona pomyślnie. Możesz odłączyć telefon. Zakończono [132sec] |
07-16-2013, 16:49 | #519 (permalink) |
No Life Poster Join Date: Jan 2010 Location: fontecno
Member: 1201378 Status: Offline Sonork: 100.1594717 Thanks Meter: 303 | 4SE - tool 1.9.0 Selected model: Xperia™ neo (MT15) Selected operation: Desbloqueo Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery. Link the TestPoint to GND and then plug USB cable Conexión establecida al puerto USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal... Connecting DLOAD...OK (PBL_DownloaderVER1.0) Enviando Preloader...OK Conexión establecida al puerto USB1 Enviando LoaderTEST...OK Chip:MSM8x55 Model:MT15i IMEI:01270300-804597-8 AID:0001 Color:BROWN DEVICE_ID: F8F3D801619B497FF2C414801608C35FAB0EA737 Enviando logic MSM8x55: Detectando tipo de flash...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x00000000 Size: 1056 Mb Logical block size: 0x20000 Logical blocks count: 0x2000 OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Prcessing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Writing S1boot image...OK Apagando terminal...OK Operation completed successfully. You can disconnect the phone now Proceso finalizado. Tiempo total [19 seg] |
07-17-2013, 12:32 | #520 (permalink) |
Member: 1201378 Status: Offline Sonork: 100.1594717 Thanks Meter: 303 | 4SE - tool 1.9.0 Selected model: Xperia™ X8 (E15) Selected operation: Flasheo Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Conexión establecida al puerto USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Chip:MSM7227 Model:E15i IMEI:35845204-492444-8 AID:0001 Color:RED DEVICE_ID: 1A5A20CB8806080D5C3891A7EF7608C9B36C235C EROM: 1229-3593 R8A029 Enviando logic MSM7227: Enviando LoaderLIVE...OK Detectando tipo de flash...OK ID: 2CBC (Micron) Chip: Micron 4096 Mbit NAND (large page) x16 Logical address: 0x08000000 Size: 528 Mb OTP: LOCKED Reading TA security data...OK E15i 0001 Red (2.1.1.A.0.16 | 1246-0694/R11B) ORANGE FR/BLACK Processing 277563214_012E37EE0488.SIN_FILE_SET... Flashing image fota0_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flashing image fota1_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flashing image kernel_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flashing image amss_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flashing image cache_S1-SW-LIVE-3EDC-0001-S1-PARTITION-WITH-SPARE.sin...OK Processing 277710358_012E6CA9ED18.SIN_FILE_SET... Flashing image amss_fs_shakira_BC18_ORANGE_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin...OK Flashing image userdata_S1-SW-LIVE-3EDC-0001-S1-PARTITION-WITH-SPARE.sin...OK Flashing image system_S1-SW-LIVE-3EDC-0001-S1-PARTITION-WITH-SPARE.sin...OK Apagando terminal...OK Operation completed successfully. You can disconnect the phone now Proceso finalizado. Tiempo total [100 seg] |
07-18-2013, 11:24 | #521 (permalink) |
Member: 1201378 Status: Offline Sonork: 100.1594717 Thanks Meter: 303 | 4SE - tool 1.9.0 Selected model: Xperia™ neo V (MT11) Selected operation: Desbloqueo Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery. Link the TestPoint to GND and then plug USB cable Conexión establecida al puerto USB2 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal... Connecting DLOAD...OK (PBL_DownloaderVER1.0) Enviando Preloader...OK Conexión establecida al puerto USB2 Enviando LoaderTEST...OK Chip:MSM8x55 Model:MT11i IMEI:35851704-568044-5 AID:0001 Color:BROWN DEVICE_ID: 80A57CE6A8C2CFED4D555459DF5B4B90DD8F3151 Enviando logic MSM8x55: Detectando tipo de flash...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x00000000 Size: 1056 Mb Logical block size: 0x20000 Logical blocks count: 0x2000 OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Prcessing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Writing S1boot image...OK Apagando terminal...OK Operation completed successfully. You can disconnect the phone now Proceso finalizado. Tiempo total [27 seg] |
07-18-2013, 11:26 | #522 (permalink) |
Member: 1201378 Status: Offline Sonork: 100.1594717 Thanks Meter: 303 | 4SE - tool 1.9.0 Selected model: R306 Selected operation: Desbloqueo Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding "C" button Conexión establecida al puerto USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Chip:LOCOSTO Model:R306 IMEI:35587602-168779-7 AID:0002 Color:RED DEVICE_ID: 11018020C146A8FF0000000002820000 EROM: CXC1250616 R5A031 Enviando logic LOCOSTO: Enviando LoaderLIVE...OK Detectando tipo de flash...OK ID: 0089/8904 (Intel) Chip: Intel 256 Mbit NOR (top boot) Logical address: 0x06000000 Size: 32 Mb OTP: LOCKED Reading TA security data...OK Autenticando con KEY KIDP96_S1_PRODUCTION_R1F...OK Searching for SIMLock check...NOT FOUND Resetting phone lock...OK Apagando terminal...OK Operation completed successfully. You can disconnect the phone now Proceso finalizado. Tiempo total [14 seg] |
07-18-2013, 11:29 | #523 (permalink) |
Member: 1201378 Status: Offline Sonork: 100.1594717 Thanks Meter: 303 | 4SE - tool 1.9.0 Selected model: W205 Selected operation: Desbloqueo Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding "C" button Conexión establecida al puerto USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Chip:LOCOSTO Model:W205 IMEI:35809203-851955-4 AID:0002 Color:RED DEVICE_ID: 08015027C200882F0000000026920000 EROM: CXC1250616 R5A038 Enviando logic LOCOSTO: Enviando LoaderLIVE...OK Detectando tipo de flash...OK ID: 0089/8904 (Intel) Chip: Intel 256 Mbit NOR (top boot) Logical address: 0x06000000 Size: 32 Mb OTP: LOCKED Reading TA security data...OK Autenticando con KEY KIDP96_S1_PRODUCTION_R1F...OK Searching for SIMLock check...NOT FOUND Resetting phone lock...OK Apagando terminal...OK Operation completed successfully. You can disconnect the phone now Proceso finalizado. Tiempo total [14 seg] |
07-23-2013, 16:20 | #524 (permalink) |
Member: 1201378 Status: Offline Sonork: 100.1594717 Thanks Meter: 303 | 4SE - tool 1.9.0 Selected model: Xperia™ neo V (MT11) Selected operation: Phone lock reset Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Conexión establecida al puerto USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Chip:MSM8x55 Model:MT11i IMEI:35188005-599450-3 AID:0001 Color:RED DEVICE_ID: 8A2B2D8B1D6A24F8CDC23BB6A1F4BFBB468AE3B3 EROM: 1241-3656 R9A021 Enviando logic MSM8x55: Enviando LoaderLIVE...OK Detectando tipo de flash...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x00000000 Size: 1056 Mb Logical block size: 0x20000 Logical blocks count: 0x2000 OTP: LOCKED Reading TA security data...OK Resetting phone lock...OK Apagando terminal...OK Operation completed successfully. You can disconnect the phone now Proceso finalizado. Tiempo total [5 seg] |
07-31-2013, 10:46 | #525 (permalink) |
Member: 1201378 Status: Offline Sonork: 100.1594717 Thanks Meter: 303 | 4SE - tool 1.9.0 Selected model: Xperia™ neo V (MT11) Selected operation: Desbloqueo Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery. Link the TestPoint to GND and then plug USB cable Conexión establecida al puerto USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal... Connecting DLOAD...OK (PBL_DownloaderVER1.0) Enviando Preloader...OK Conexión establecida al puerto USB1 Enviando LoaderTEST...OK Chip:MSM8x55 Model:MT11i IMEI:35851704-124510-2 AID:0001 Color:BROWN DEVICE_ID: 6DDFB3844AA28FE9D7AFEFBA5143BB226A3BE1F9 Enviando logic MSM8x55: Detectando tipo de flash...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x00000000 Size: 1056 Mb Logical block size: 0x20000 Logical blocks count: 0x2000 OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Prcessing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Writing S1boot image...OK Apagando terminal...OK Operation completed successfully. You can disconnect the phone now Proceso finalizado. Tiempo total [37 seg] |
