Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 11-20-2012, 23:23   #1 (permalink)
Member: 1723302
blackberry 9300 joystick problem
dear sir or madam
could you give me information about blackberry 9300joystick's
if it's possible could you send me workout steps by pictures.
our blackberry joystick from 9300 doesnt moves.
thank you and kind regards.
Old 11-21-2012, 20:23   #2 (permalink)
Member: 1824591
Sonork: 100.1637969
Thanks Meter: 3
Your will need to replace your joystick you can buy them cheap 1 or 2 pound.
First you will need too remove the 2 screws of the back of your phone.
After this remove the casing faceplate and keypad.
After remove the 2 screws from on top of the lcd screen and also the other 4 below on the motherboard.
Now it should be loose u can pry your motherboard out
Once its out you will see the connection from the trackpad to the motherboard take out old trackpad and replace with new. Yoi can now assembke phone back togethet.
If you would like phone fixed i fix phones please message mr.
Old 11-22-2012, 02:39   #3 (permalink)
d-Artigo's Avatar
Member: 1573913
Sonork: hardware illustration
Thanks Meter: 7,629
Originally Posted by uygar56 View Post
dear sir or madam
Blackberry 9300 trackpad solution..???
try trick image below
good luck
The Following User Says Thank You to d-Artigo For This Useful Post:
Old 11-24-2012, 09:40   #4 (permalink)
Crazy Poster
Member: 958720
Thanks Meter: 60
Wink 9300 trackpad
good luck
Red Points are Gnd...!!
Good Luck...
Old 01-18-2013, 23:50   #5 (permalink)
Registered User
Member: 143939
Thanks Meter: 264
http://forum.gsmhosting.com/vbb/f733...100-a-1595241/
Page generated in 0.17981 seconds with 9 queries
