Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
03-04-2014, 00:50 | #137 (permalink) |
Registered User Join Date: Aug 2010 Location: turkey
Member: 1361365 Status: Offline Sonork: 100.1670394 Thanks Meter: 15 | thx its work with me.... after flash the phone the imei becomes 0049999..... then i do factory reset and root the phone and finally repair imei on z3x box..thx 4 sharing!!! Last edited by waddaho; 03-04-2014 at 00:59. |
The Following User Says Thank You to waddaho For This Useful Post: |
03-11-2014, 03:42 | #139 (permalink) | |
Junior Member Join Date: Aug 2013
Member: 1999490 Status: Offline Thanks Meter: 0 | i9505 Quote:
I need i9505 imei null file plz | |
03-13-2014, 06:52 | #140 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2146555 Status: Offline Thanks Meter: 0 | Need help! I follow all the steps on this post, i used ODIN to apply this file and all its ok, but when my phone complete the installation it reboot then it got STUCK on the SAMSUNG LOADING SCREEN and nothing happen. I waited for around 20 up to 30 minutes but the phone is TOTALLY STUCK on the SAMSUNG LOADING SCREEN. I delete/wipe the cache and used a fresh rom but still not working: IMEI null/null and BASEBAND VERSION: UNKNOWN. Is there any other options that i could use to solve this problem? all the solutions that i found redirect me to this same post and i dont know if im doing something wrong or what... PLEASE HELP! |
03-26-2014, 10:44 | #145 (permalink) | ||
Freak Poster Join Date: Dec 2002 Age: 50
Member: 19126 Status: Offline Thanks Meter: 35 | Quote:
1. After flash mine phone stuck on SAMSUNG - solution, volume up + home + power and reset/wipe full factory 2. After that I got imei 0449xxxx , first root it, grant rights with Super SU, enable Development & Debugging USB 3. make backup of your efs (just in case), tehn in repair: restore EFS + test mode and fix imei Quote:
The Following User Says Thank You to siewa26 For This Useful Post: |
04-22-2014, 01:46 | #147 (permalink) |
Insane Poster Join Date: Jun 2010
Member: 1325841 Status: Offline Thanks Meter: 1 | samsung galaxy gt-i9500 4.2.2 imei null/null and baseband unknow my samsung galaxy gt-i9500 ver 4.2.2 imei null/null .. baseband unknow after flash odin this file GT-I9500_XcachorroX®.tar.gz software currepted plz help me bro again software install same problem thanks advance |
04-27-2014, 09:16 | #148 (permalink) | |
Junior Member Join Date: Apr 2014
Member: 2175776 Status: Offline Thanks Meter: 0 | Quote:
05-13-2014, 12:26 | #150 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Born in Syria,Live In Turkey
Member: 1834175 Status: Offline Thanks Meter: 52 | The Best Reply My Brothers follow the next steps: 1) To fix imei null try to flash any modem >>this will fix your imei null >>then reset efs by spt box >>then write any imei by UART Cable (TESTED) 2) to repair imei with Availability Network do this steps(Imei you will): a) Downgrade your phone version to 4.2.2 b) root your phone with Su version 1.94 c) Disable your Knox Security d) Do Spt Mode with (Debug USB Cable) e) If CP phone available in the dialed menu (*1234#) then your phone can be repaired with Availability Network f) If CP not found Then try to write Any Super IMEI with SPT BOX |
