Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 05-13-2019, 18:25   #1 (permalink)
Member: 2808721
Galaxy S7 Overheating after screen replacement?
Done a Samsung S7 replacement amoled screen for a friend about 3 weeks ago, phone worked fine for 7 - 10 days after, it is now beginning to randomly overheat and reboot, seems to also be a fair bit of battery drain.
Anyone know what the issue would be before i open it back up? I doubt it's the screen as it was a Samsung service pack and I've used the same supplier for years and never had a faulty screen yet.
Old 05-14-2019, 15:25   #2 (permalink)
Member: 172136
Sonork: 100.1574973
Thanks Meter: 777
Does the battery get hot? sounds like a short in the battery itself (or the connector).
Display replacement is a fairly simple process, that is if the whole lcd+digital was replaced. If that is the case then all I can think of is that the new display for whatever reason is hotter than normal and adding the heat to the logic board causing overheat.
Page generated in 0.10487 seconds with 8 queries
