Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
08-06-2013, 20:07 | #16 (permalink) |
Junior Member Join Date: May 2013 Location: Ontario, Canada
Member: 1949187 Status: Offline Thanks Meter: 0 | |
08-29-2013, 14:26 | #18 (permalink) |
No Life Poster Join Date: May 2006 Location: I Love Walking In The Rain Bec
Member: 276151 Status: Offline Sonork: 100.1577032 Thanks Meter: 234 | |
08-31-2013, 10:28 | #19 (permalink) | |
Freak Poster Join Date: Jun 2005 Location: indonesia
Member: 154427 Status: Offline Thanks Meter: 61 | Quote:
i cannot find vold.fstab with adb>>> where the location the vold.fstab in device? thks.. | |
09-19-2013, 15:05 | #21 (permalink) | |
No Life Poster Join Date: Oct 2010 Location: Abidjan Age: 38
Member: 1418143 Status: Offline Thanks Meter: 353 | I got this with Heimdall Quote:
09-26-2013, 09:18 | #23 (permalink) |
No Life Poster Join Date: May 2013 Location: TkinterPy,Hex Cal,Ext2,Ext4,
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | hello masters.i have p1000 tablet on same condition.i done know what to do.can please some one explain it from biggining and easy words.thanks. |
10-27-2013, 06:58 | #25 (permalink) |
Major Poster Join Date: Jun 2009 Location: Malawi
Member: 1064767 Status: Offline Thanks Meter: 7 | Make the partitions primary and learn how use push and pull in adb, because all you need to do is exactly what the guide says and when it reaches the point where you have to edit vold.fstab then you need to pull this file from /system/etc/ and after you have edited the file ( you can use notepad++ for this task), then you will need to push the file back to /system/etc/, but please, please make sure you know what you are doing or your may brick your p1000 for good, and oh i almost forgot, you can only pull the vold.fstab in recovery mood something like that. i hope this will help someone. Last edited by nmpeka; 10-27-2013 at 06:59. Reason: adding more meet to the bone |
11-07-2013, 12:27 | #26 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2060781 Status: Offline Thanks Meter: 0 | Many thanks, I followed this guide and my tab is working after a long time. However, the phone restarted when I install any application. Also I can’t view the SD space. Any idea how to recover this. |
11-22-2013, 01:45 | #27 (permalink) |
Member: 2070348 Status: Offline Thanks Meter: 0 | Is it possible to adapt this guide to recover a GT-I9300 S3? I have the same error in internal card emmc with my GT-I9300: "mmc0: error -110 whilst initialising MMC " Has anyone succesfuly adapted this guide to recover a S3? I think that cloud be possible but I don't know how. Thank you! |
11-22-2013, 07:42 | #28 (permalink) |
Member: 2070473 Status: Offline Thanks Meter: 0 | problem with first step - is this error ok ? I ran the first heimdal and got Initialising connection... Detecting device... Claiming interface... Setting up interface... Checking if protocol is initialised... Protocol is not initialised. Initialising protocol... Handshaking with Loke... Beginning session... Session begun with device of type: 0 Uploading PIT PIT upload successful Uploading KERNEL 100% ERROR: Failed to confirm end of file transfer sequence! KERNEL upload failed! Ending session... Rebooting device... is this ok ? |
05-09-2014, 19:34 | #29 (permalink) | |
Freak Poster Join Date: Oct 2008
Member: 887350 Status: Offline Thanks Meter: 12 | thank you Quote:
07-27-2014, 00:40 | #30 (permalink) |
Freak Poster Join Date: Jan 2005 Location: Romania Age: 48
Member: 109294 Status: Offline Thanks Meter: 22 | No need for ADB. Just install Stock ROM GB_Stock_Safe_v5.tar, flash the file: Overcome_Kernel_v4.0.0.tar so tablet can use the EXT4 partition otherwise with just stock rom is not recognized (do not use repartition option now), and then copy the last Overcome flash directly on the SD - on the first SD partition. Filename of Overcome flash I used for my GT-P1000 was: Overcome_7_Series_v4.1.0_NoWipe.zip. The three partitions on SD are easy to make using Minitool Partition Wizard Home Edition. All three partitions must be set to be primary partitions. Then install file Overcome_7_Series_v4.1.0_NoWipe.zip using the Install Zip from external/internal SD card - command from recovery. Reboot to system and wait up to 4 minutes. But now there is a problem with camera - error : Turn off USB storage before using camera" - I gotta find a solution for that. Cheers! |
Internal Aerial for 7110 | 8310-GUY | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 13 | 02-17-2003 21:07 |
water damaged 5110 | gsmxc | Nokia Hardware & Hardware Repair | 5 | 10-18-2001 16:15 |
3210 *water damaged* no reception | pks | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-28-2001 12:09 |
nokia 6150 internal modem | mottile | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-21-2001 00:14 |
How to open 3210 without damaging? | Kane | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-06-2000 16:41 |
