Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
10-07-2015, 08:55 | #31 (permalink) |
No Life Poster Join Date: Oct 2010 Location: India Age: 31
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | First mount system and data from mount menu in recovery. |
The Following User Says Thank You to Rahul_Bhutani For This Useful Post: |
10-29-2015, 13:16 | #37 (permalink) | |
Junior Member Join Date: Oct 2015
Member: 2475126 Status: Offline Thanks Meter: 0 | Quote:
let me explain it better My problem was the finger print is not working, i forgot the backup password, the device is not connected to internet and the usb debug is not enabled, so this tutorial can save me? | |
10-29-2015, 23:20 | #38 (permalink) |
Junior Member Join Date: Aug 2015
Member: 2450347 Status: Offline Thanks Meter: 0 | Some different kinds of Locks he's saying it will work unless factory reset protection has been enabled (a simple forum search for FRP would have revealed that). Sometimes I find google search of gsmhosting yields better results. here's a related post (I can't post links yet): search "how-remove-screen-lock-s6-edge-new-version-g925fxxu2coh8-1998005-post11327212" I'm in the same situation but more out of curiosity than necessity on my tmoibile s6 edge with android 5.1.1 (of6 firmware). Fingerprint screen lock enabled & also backup password but I want to remove fingerprint password and login to the S6 Edge without factory reset (I want to keep settings / data), I also don't want to trip Samsung's KNOX (**** bootloader control to void your hardware warranty). Lastly, I would like to flash custom recovery with Odin (not sure if I can do this without having root but I would rather keep the device stock and simply remove the fingerprint / password screen lock. So bottom line, you are confusing Samsung's Account Lock (FRP to avoid theft) with finger print lock. If Reactivation Lock is enabled you can't use Odin to flash custom recovery (to my VERY limited knowledge, unless maybe doing battery pull and risking softbrick?) So in short, search that other post I referenced and make sure the Samsung Reactivation lock on your phone is not enabled so you can flash and gain root if necessary (to delete system files through adb to remove fingerprint / password lock). It takes a bit of patience searching to get used to basic concepts; it's just time consuming but nothing too difficult with basic reading and comprehension skills. There are different kinds of locks: Samsung Account Lock (Reactivation Lock): You can check to see if this has been enabled by booting into recovery menu on phone by powering on while holding power + up volume + home buttons at the same time. Than there is Google Account Lock (search forums for OTG settings bypass). Then there is a Screen lock (fingerprint & backup password). Goodluck, we're both in the same boat! |
11-02-2015, 16:24 | #40 (permalink) |
No Life Poster Join Date: Sep 2013 Location: The Hell Age: 31
Member: 2033150 Status: Offline Thanks Meter: 624 | if there is any way for sony or htc to remove with out ADB will be good ,coz any way to unlock bootloader for this devices will wipe data ---- DevX |
12-12-2015, 21:03 | #45 (permalink) |
No Life Poster Join Date: May 2010 Location: FLAT EARTH
Member: 1295624 Status: Offline Thanks Meter: 152 | m919 done ok mount system mount data adb devices adb shell cd data/system rm /data/system/locksettings.db rm /data/system/locksettings.db-wal rm /data/system/locksettings.db-shm Last edited by bhiret; 12-12-2015 at 21:09. |
The Following User Says Thank You to bhiret For This Useful Post: |
