Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
03-15-2019, 17:47 | #61 (permalink) | |
Freak Poster Join Date: May 2017 Location: USA
Member: 2718897 Status: Offline Thanks Meter: 49 | Quote:
Sent from my SM-N960U using Tapatalk | |
The Following User Says Thank You to elliwigy For This Useful Post: |
09-09-2019, 17:17 | #63 (permalink) | |
No Life Poster Join Date: Mar 2010 Location: Unknown
Member: 1274304 Status: Offline Sonork: 100.1617965 Thanks Meter: 195 | Quote:
09-09-2019, 17:31 | #64 (permalink) |
Member: 1274304 Status: Offline Sonork: 100.1617965 Thanks Meter: 195 | What could be the problem here ? G930V Data Bits: 7 Stop Bits: 1 Timeout: OFF XON/XOFF: OFF CTS handshaking: OFF DSR handshaking: OFF DSR sensitivity: OFF DTR circuit: ON RTS circuit: ON Status for device CON: ---------------------- Lines: 40 Columns: 110 Keyboard rate: 31 Keyboard delay: 1 Code page: 437 íδíδíδíδíδíδíδíδíδíδíδíδíδíδíδíδíδíδíδ Input Port Number[1~300,x:Exit]:34 34 Start Recovery. emmcdl.exe -p COM34 -f prog_ufs_firehose_8996_ddr.elf -MemoryName ufs -SetActivePartition 1 -x rawprogram0.xml -x rawprogram1.xml -x rawprogram2.xml -x rawprogram3.xml Version 2.10 Downloading flash programmer: prog_ufs_firehose_8996_ddr.elf Successfully open flash programmer to write: prog_ufs_firehose_8996_ddr.elf Expecting SAHARA_END_TRANSFER but found: 0 !!!!!!!! WARNING: Flash programmer failed to load trying to continue !!!!!!!!! Programming UFS device using SECTOR_SIZE=4096 <?xml version = "1.0" ?><data><configure MemoryName="ufs" ZLPAwareHost="1" SkipStorageInit="0" SkipWrite="0" MaxPayloadSizeToTargetInBytes="1048576"/></data> What could be the problem here ? |
10-27-2019, 00:44 | #68 (permalink) | |
Freak Poster Join Date: Jan 2011 Location: Manila Age: 37
Member: 1493085 Status: Offline Sonork: n/a Thanks Meter: 92 | Quote:
hi.. thanks for share. please teach us, how to make this file | |
01-13-2020, 00:42 | #71 (permalink) |
Junior Member Join Date: Sep 2017 Location: Lahore, PK
Member: 2758068 Status: Offline Thanks Meter: 0 | ahmed mohmed 7274 [/QUOTE] Can I use G935a file (that you have provided here) on a G935v that's a verizon variant? Or I just simply replace its files with the same files derived from G935v's stock firmware? If I am okay to use your provided file then which stock firmware would I need to flash on my device? 935A U5 Or 935v U5? |
03-12-2020, 22:42 | #72 (permalink) |
No Life Poster Join Date: Nov 2006 Location: . Age: 35
Member: 400280 Status: Offline Thanks Meter: 83 | i have A920F in qualcomm hs usb device after flash combination file... anyone have files .xml for unbrick or what can i Do? i have easy jtag but not have UFS BGA socket... please socket |
The Following User Says Thank You to Medusin For This Useful Post: |
