Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 08-19-2016, 10:44   #1 (permalink)
axecom's Avatar
Member: 1424719
Sonork: 100.1619833
Thanks Meter: 2,563
Universal Samsung Galaxy s6 s7 note 5 note 7 FRP bypass for all Samsung devices
Universal Samsung FRP Bypass
As per users report, Make sure that all Protected Smart card Softwares are disconnected While using this software, because this might Block Or Deactivate the smart-card.
Here are the steps to remove factory reset protection / Google previously synced account lock from your Samsung device.
1.Download and installRealTerm program
2.Download and copy com.rootjunky.frpbypass-1.0.apk to the device micro sdcard or download once into the device.
3.Start phone and connect to WIFI also plug into the computer with your usb cable.
4.Start RealTerm on your pc and under pisplay check the box HALF DUPLEX
5.Right click on my computer and select manage once it opens click device manager then modems
6.Under modems you should see a Samsung device. right click it then select properties
7.Once the properties window opens select modem tab and see what port it is on like com5 for an example
8.Now that you know the com port number close all device manager windows and open RealTerm again
9.Under the ports tab in RealTerm enter your port number then click change.
10.Next, click the send tab. you will need to send these two commands with the Send ASCII button
11.First at+creg?\r\n
12.Then atd1234;\r\n
13.Look at your phone and the dailer will pop up.
14.Now watch the video below to see the rest of the steps and please comment below on your success or failures. thanks
NOTE: If you dont have a SDcard and are getting the sparse ERROR in es file explorer then you can buy a OTG flash drive and load the FRPbypass.apk to it from your computer then plug it into the phone. once plugged in navigate to it in es file explorer and install the frp bypass app that way. You can also put this address into your ES file Explorer app https://www.androidfilehost.com/?fid=24665542585483676
Here is a video Tutorial
http://www.youtube.com/watch?v=ggRhkme9FC0
Another Video:
http://forum.gsmhosting.com/vbb/f777...ethod-2124681/
Tested devices:
J 5 2016
J710F |2016| Android 6.0.1
A310f
A510f
J700T1 Versión: 6.0.1
J320F/DS
j700 2016
j710gn
j710FN
G935fxxu1apc8
g935k
g935w8
Source:RootJunky.com | Learning how to hack your Android device
The Following 173 Users Say Thank You to axecom For This Useful Post:
Old 08-19-2016, 14:29   #2 (permalink)
mak1983's Avatar
Member: 1704666
Sonork: 100.1652565
Thanks Meter: 157
this step working all samsung mobile sir
The Following 11 Users Say Thank You to mak1983 For This Useful Post:
Old 08-19-2016, 14:36   #3 (permalink)
axecom's Avatar
Member: 1424719
Sonork: 100.1619833
Thanks Meter: 2,563
Working on Galaxy s6 s7 note 5 note 7.
U can test if other models are working!
The Following 13 Users Say Thank You to axecom For This Useful Post:
Old 08-19-2016, 15:21   #4 (permalink)
Member: 2613418
Sonork: 100.1677044
Thanks Meter: 7
WoooooW
working 100%
now i can remove google account on samsung J 5 2016
thanks bro
The Following 7 Users Say Thank You to HermicGsm For This Useful Post:
Old 08-19-2016, 16:03   #5 (permalink)
Member: 2477800
Thanks Meter: 5
not working S5 G900f 6.0.1
The Following 4 Users Say Thank You to derekh48 For This Useful Post:
Old 08-19-2016, 17:18   #6 (permalink)
Member: 212839
Thanks Meter: 11
Very good explained
thx very good video very clearly.
greetings from Belgium
ps it works samsung S7
The Following User Says Thank You to pietpiraat For This Useful Post:
Old 08-19-2016, 17:30   #7 (permalink)
Member: 2586923
Sonork: 100.1582347
Thanks Meter: 9
Hi to all,
Information to all. Please when use this programme Deattach all boxes. Otherwise Boxes card will get demage. Becarefull
Thanks
Br, Raja
The Following 6 Users Say Thank You to gsmmultiple For This Useful Post:
Old 08-19-2016, 17:49   #8 (permalink)
Member: 1294926
Sonork: 100.1608183
Thanks Meter: 126
FRP |Google Account| Removed Successfully on J710F |2016| Android 6.0.1.
Thanks To All.
The Following User Says Thank You to Agadir__Gsm For This Useful Post:
Old 08-19-2016, 19:03   #9 (permalink)
KrzychuG's Avatar
Member: 25996
Thanks Meter: 253
Not on all. On G389F (Xcover 3 VE) it doesn't since there's no such entry in contacts (for snapbiz). You can still use another method tho ;-)
The Following User Says Thank You to KrzychuG For This Useful Post:
Old 08-19-2016, 20:10   #10 (permalink)
Member: 76937
Thanks Meter: 11
dont work j700m 6.0.1
after command at no see dial pop up in my phone
The Following 2 Users Say Thank You to Danilo_cel For This Useful Post:
Old 08-20-2016, 01:23   #11 (permalink)
Member: 913311
Thanks Meter: 6
World weakest protect. Like icloud upgrade need.
The Following User Says Thank You to mng_gamer For This Useful Post:
Old 08-20-2016, 01:33   #12 (permalink)
Member: 469257
Thanks Meter: 34
it doesn't work on j200m
The Following User Says Thank You to adrian_1_ For This Useful Post:
Old 08-20-2016, 07:45   #13 (permalink)
Member: 1403677
superb one (y)
successfully unlocked FRP in A310f..
Old 08-20-2016, 08:59   #14 (permalink)
Member: 58331
Thanks Meter: 5
Works flawlessly with A510f
Old 08-20-2016, 09:38   #15 (permalink)
axecom's Avatar
Member: 1424719
Sonork: 100.1619833
Thanks Meter: 2,563
Please post your tested devices here to update the original thread.
Post model and version.
The Following User Says Thank You to axecom For This Useful Post:
Page generated in 0.25805 seconds with 9 queries
