Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
05-16-2018, 07:51 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Location: kolkatta
Member: 1204828 Status: Offline Sonork: 123456 Thanks Meter: 64 | Hot news sony xperia r1 pluse g2299 frp USE UMT GSM AND GO TO MISCELLANEOUS AFTER GO QC FRP RESET Port : Fastboot Interface Baud Rate : Not Applicable Device : Generic Operation : Qualcomm FRP Reset Searching for Device in FastBoot Mode... OK Reading Information... OK FastBoot Ver. : 0.5 Product : QC_REFERENCE_PHONE Warranty : Yes Bootloader : Unlocked Removing FRP Lock... Done Operation Finished. Elapsed Time: 00:02 [Module Ver. 4.8] Log Saved to Logs\180516_121612.log USE volume DOWN BUTTON AND CONNECET USB CABLE FOR FastBoot Mode IF YOU LIKE THEN PRESS THX BUTTON |
The Following 8 Users Say Thank You to a f s a r For This Useful Post: |
10-27-2018, 18:25 | #3 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
WhAt did u use UMT GSM do at 1st? I can see that FRP as been reset by UMT GSM then what do we need UMT qcfire for again? PLEASE EXPLAIN WELL. THANKS IN ADVANCE | |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
11-16-2018, 09:13 | #5 (permalink) | |
No Life Poster Join Date: Aug 2012 Location: Bali-Indonesia
Member: 1800628 Status: Offline Thanks Meter: 940 | Quote:
if u have UMT box or dongle open UMT GSM exe. go to Miscellaneous tab Tick QC FRP Reset enter device to fastboot mode. | |
The Following User Says Thank You to Deni's For This Useful Post: |
02-28-2019, 14:06 | #7 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1394487 Status: Offline Sonork: [email protected] Thanks Meter: 2 | thnx afsar bhai thnx i don sony g2299 frp unlock |
07-18-2019, 13:23 | #8 (permalink) |
Freak Poster Join Date: Aug 2017 Location: Tamilnadu
Member: 2749644 Status: Offline Sonork: 100.1678692 Thanks Meter: 47 | Operation : Format FS Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM73) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1F00400 [8937] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [3] Device may possibly not boot with this loader. Preparing Loader...Done Sending Loader [8937]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8937, eMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : SONY G2199 [msm8937] [G2199] Software : S000008_171207, S000008_171207 [2017年 12月 07日 星期四 15:44:31 CST] Android Ver. : 7.1.2 Patch Level : 2017-12-01 Formatting userdata [SafeMode]...Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 4.5 done with qc fire |
The Following User Says Thank You to ismailcnr For This Useful Post: |
