03-15-2018, 00:02 | #1 (permalink) |
Banned Join Date: Apr 2013 Location: Dubai
Member: 1925987 Status: Offline Sonork: dearlex Thanks Meter: 130 | Download Infinix clone copy Firmware (flash file) How To Flash Infinix clone copy? MediaTek devices are being used and become popular massively you should understand about flashing and have precise knowledge and understanding about flashing MTK chipset, therefore, you should know some important points before the start... Backup your previous data info. Unzip Downloaded Flash File. Download Smartphone (SP) Flash Tool From @here. Download Mediatek (MTK) Update Android USB Cable Driver. Load Scatter From Download File in Smartphone (SP) Flash Tool. Charge Battery Minimum 50% Up. Setup Android USB Cable Vcom Driver. Press Flash Start Button. Insert USB Cable & Wait For Flash Done. Follow the How-to Flash Manual to Flash the Firmware on your Infinix A88 Device. Follow Detailed Guidelines Readme Once: [*] Take a Backup: If you are going to flash the above Firmware on your Infinix A88 device, then take a backup of everything as because your personal data will be deleted after flashing the stock ROM. [*] The firmware shared on this page is officially released by the company and helps you to recover your device if you ever got bootloop, software error, update error, hanging and dead issue. HERE IS THE FIRMWARE COLLECTION LINKS Infinix A88 Flashing Solution Original Firmware (New flash file) Infinix Hot V2 Pac Firmware (flash file) Infinix A8900 Stock Firmware -Marvell (flash file) Infinix M8 Stock Firmware (flash file) Infinix Hot V4 MT6592 Stock Firmware (flash file) INFINIX X552 CLONE Stock Firmware (flash file) Infinix X509 Huawei Clone stock Firmware (flash file) Infinix AL68 Stock Firmware (flash file) Infinix P2 Stock Firmware (flash file) Infinix X557 Hot 4 Clone Stock Firmware (flash file) Infinix X601 Note 3 Clone Stock Firmware (flash file) Infinix K1 aka X551 Clone Stock Firmware (flash file) Infinix K1 aka X551 Clone Stock Firmware (flash file) Infinix Hot V4 MT6735M Stock Firmware (flash file) Infinix Hot V3 MT6735M Stock Firmware (flash file) Infinix F818 stock Firmware (flash file) Infinix V3800 Stock Firmware (flash file) Infinix X1 Stock Fimrware (flash file) Infinix F98 Stock Firmware (flash file) Infinix X557 SpreadTrum Pac Firmware (flash file) Firmware Fixed Below Issues Pattern Lock solution. Password Lock Problem Fixed. Privacy Lock Solution. Application Lock Solution. Screen Lock Problem Fixed. FRP Lock (Google Account Lock) (Type Email & Password & Press Next) Problem Fixed. Hang On Logo Problem Fixed. Dead phone Recovery. Unfortunately, Any Apps has Been Stoped. Heat Problem Fixed. Auto On Off Problem Solution. White Screen Problem Solution. Blank OR Black Screen Problem Fixed. What are Ram and Rom? Check here:* |
11-20-2018, 15:44 | #4 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
Admin should act on this | |
05-09-2019, 17:10 | #6 (permalink) |
Junior Member Join Date: Mar 2019 Location: gulu
Member: 2901958 Status: Offline Thanks Meter: 9 | Model Name : s10c_q28 Model Brand : XLTEL Model Device: s10c_q28 AndrVersion : 6.0 BaseBand CPU: S10C_Q28 CompileDate : 1/19/2018 11:43:33 AM Project Ver : Android_6.0_V10 Model Ext : TECNO-J8 help me with that file |
