Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones > Android based chinese phones
Old 03-03-2017, 00:18   #1 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 11,110
[Guide] How to Root Easily Generic CHINA Phone
Download KingoRoot from Here, Kingo_Apk Root by using mobile data/ WiFi, or iRoot download from Here.
How to Root your device by PC with KingoRoot or iRoot exe
Step 1)You’ll want to ensure that your device is fully charged before you begin.
Step 2)You’ll also need to turn on USB debugging, as well as OEM Unlocking.
Step 3)Open Settings on your device. If  you do not see Developer Options toward the bottom of the Settings screen on your device, follow these steps to activate them.
Step 4)About Phone and find the Build Number.
Step 5)Build Number seven times and the Developer Options will appear on the main page of the Settings.
Step 6)Back key to see the Developer Options.
Step 7)Developer Options.
Step 8)Check to enable USB Debugging.
Step 9)Check to enable OEM Unlocking.
Step 10)run the program on your PC and connect your Android to your PC with a USB cord.
Step 11)The program should detect your device and a message asking if you’d like to root will appear.
Step 12)Select “root” and then hang tight. Kingo will only take a few minutes to grant super user privileges.
How to Root by KingoRoot Apk without PC
Step 1: Free download KingoRoot.apk. ...
Step 2: Install KingoRoot.apk on your device. ...
Step 3: Launch "Kingo ROOT" app and start rooting. ...
Step 4: Waiting for a few seconds till the result screen appear.
Step 5: Succeeded or Failed.
You’ll can see the video tutorial how to root with the three(3) different way Here KingoRoot , Kingo_Apk & iRoot Video.
Open selected Software & flow there software direction & do that your set will be successfully Root.
If I get about Android 6.0.1 properly root solution than its will be added in this post.
__________________
Use Search Button to get Instant Result | Follow Forum Rules
Avoid Spams in the forum to prevent ban your account.
Last edited by ...:::::NP™:::::...; 03-03-2017 at 02:48. Reason: Easy procedure added
The Following 21 Users Say Thank You to ...:::::NP™:::::... For This Useful Post:
Old 03-07-2017, 08:47   #2 (permalink)
Member: 2692691
Exclamation Rooting Failed
plz any one can help me. I am unable to root my. Lava iris 870 mt6735 6.0 marshmallow
i have tried kingroot. kingoroot. iroot. but. faaaaaiileedddd. failed
plz help
The Following User Says Thank You to hamzasajjad123 For This Useful Post:
Old 03-07-2017, 09:04   #3 (permalink)
Moderator
Member: 1162626
You can try with (CWM) procedure or to night, I will be arrange for you.
__________________
The Following 6 Users Say Thank You to ...:::::NP™:::::... For This Useful Post:
Old 03-07-2017, 09:04   #4 (permalink)
Moderator
Member: 1162626
ClockworkMOD (CWM) in all MediaTek Android Device | Working 100%
Requirements :
A MediaTek android device (MT65XX)
USB Chord.
Windows PC/Laptop.
Download ADB Drivers : ADB Drivers.
Download MTK Droid Tools for Windows : MTK Droid Tools for Windows.
Video tutorial :- How To Flash ClockworkMod (CWM) Recovery on Any MediaTek (MT65xx) Android Device
1. Download necessary files from above links.
2. Install the downloaded PDANet to your computer. It contains ADB Drivers.
3. Turn on your android device and connect it to your computer using USB Chord. (Make sure to Enable USB Debugging, go to Phone Settings — Developer Options — Enable USB Debugging.)
4. From your computer, open MTK Droid Tools that you have downloaded above and extract it to your desired location.
5. Open MTK Droid Tools.exe from the extracted folder (Run as administrator). Wait for the tool to detect your device. (If UBIFS warning appeared in the status message, this process will not work for you. Only ext4 supported.). Notice on the bottom-left part of the tool, a YELLOW color indicator means that your android device is does not have root shell yet. If it is GREEN already,
6. Click ROOT button to enable root shell your device. Wait for the progress bar on the Status, see your phone to Grant Superuser access. If the color indicator turns GREEN, then you have successfully enabled root shell for your device.
7. Now, select the Root, Backup, Recovery tab and and further choose To Use Boot From Phone from the selections. Click Recovery and Boot, a message prompt will appear “To make CWM recovery automatically”, click YES.
8. Wait for the tool to build the CWM recovery and another prompt will appear “install patched boot to phone?” select NO, wait a little bit more and another prompt will appear again “install created recovery to phone”, now select YES.
9. When the tool ask you to reboot your phone to recovery, click Yes and it will reboot to CWM recovery shortly. Check out your new custom recovery.
Congratulations! You now have Installed ClockworkMod custom recovery on your MediaTek android device. You can now enjoy apps that requires Superuser rights, mods and ROMs that requires flashing from CWM.
Source ==> devs-lab
__________________
Last edited by ...:::::NP™:::::...; 03-08-2017 at 00:08. Reason: (CWM) procedure added
The Following 10 Users Say Thank You to ...:::::NP™:::::... For This Useful Post:
Old 03-14-2017, 09:05   #5 (permalink)
Member: 2670074
How to root Android V 6.00?
The Following User Says Thank You to Adnan-Okapia For This Useful Post:
Old 03-15-2017, 08:38   #6 (permalink)
Moderator
Member: 1162626
You can try with post #4
Send from my SM-G928F using Tapatalk
__________________
The Following 3 Users Say Thank You to ...:::::NP™:::::... For This Useful Post:
Old 07-28-2017, 13:57   #7 (permalink)
Member: 2738865
x700pro
any body have a Qmobile x700pro root file with flash driver
Old 10-09-2017, 23:24   #8 (permalink)
Member: 2678630
Hi my friend how root G-raid android 6.0.1
Old 10-25-2017, 20:35   #9 (permalink)
Member: 2767807
hi need kingaroot plz
Old 11-27-2017, 02:49   #10 (permalink)
Member: 2782970
How to hard reset forgot pattern or password my phone myT1DTV
Old 12-23-2017, 08:12   #11 (permalink)
Member: 2659474
Sonork: w.m.t.malshan
Thanks Meter: 3
also can root by mobojenie tool
Old 01-07-2018, 15:45   #12 (permalink)
Member: 2797274
Question need help
hello every one i would ask you help about a phone named funker r452 !
he's blocked on android logo, how to flash it ? thank you
Old 02-09-2018, 07:47   #13 (permalink)
Member: 2809311
Device: SLA-AL00 problem with installing play store
Old 06-06-2018, 14:09   #14 (permalink)
Member: 2836441
Smile rooting android phone
I tried to root infinix Note 2 x572 running android 7 (nougat) but couldn't root both with kingoroot and iroot for pc.......whats wrong????????
Old 07-15-2019, 15:18   #15 (permalink)
Member: 2918315
Thank you Very Helpful kingo root worked on 1 of my phones!!!
The Following User Says Thank You to Bperry195669 For This Useful Post:
Page generated in 0.20878 seconds with 8 queries
