Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones > Android based chinese phones
Old 05-23-2013, 08:05   #1 (permalink)
Member: 376471
Sonork: 100.1608095
Thanks Meter: 107
Smile SPD Android Factory Flash Files...
Dear Member...
I am starting this thread to share factory flash files for SPD Phones.
Please others try to share their factory flash files for other members....
The Following 2 Users Say Thank You to ashamsu For This Useful Post:
Old 05-23-2013, 09:02   #2 (permalink)
Member: 629256
Thanks Meter: 5
need you help
forum who have this tool and help you file your 6820 Spreadtrum CHIP okay.[IMG][IMG]http://http://nx5.*****.com/b1.s37.d4/a76be187aff151db47a5617f19595031_55804845.02.jpg?r and=0.39505345816724[/IMG][/IMG]
The Following 3 Users Say Thank You to hieuphonevn For This Useful Post:
Old 05-23-2013, 09:13   #3 (permalink)
Member: 376471
Sonork: 100.1608095
Thanks Meter: 107
N9300_6820_2.3.5_C909_hteng_s2_en_V02
Here is my first share....
SPD Android N9300 Galaxy S3 Mini,
6820_2.3.5_C909_hteng_s2_en_V02 flash files.....
N9300 Galaxy S3 Mini__6820_2.3.5_C909_hteng_s2_en_V02.rar
Build Properties attached....
Old 05-23-2013, 14:17   #4 (permalink)
Member: 1363430
Sonork: Use Skype
Thanks Meter: 22
thanks for your share
The Following User Says Thank You to hychan37 For This Useful Post:
Old 05-24-2013, 03:09   #5 (permalink)
bencebacsi's Avatar
Member: 829361
Thanks Meter: 107
This is not a factory .pac file, but some kind of backup. Did you flashed it ever? I'm affraid it's useless. The non-yaffs2 partitions have to be truncated before flashing and the system.img seems to be not perfectly created. A phone won't boot after flashing this.
The Following User Says Thank You to bencebacsi For This Useful Post:
Old 05-24-2013, 04:00   #6 (permalink)
Member: 1494304
Sonork: 100.1606186
Thanks Meter: 108
how can we use that fw if write flash is still not supported by any box
do you have a software of flasher of spd android?
Old 05-24-2013, 08:27   #7 (permalink)
Member: 376471
Sonork: 100.1608095
Thanks Meter: 107
Dear Member...
u can flash this file in spd factory flasher that is in Research Download.
The file are not in *.pac format, but u can create pac file with these files in research downloader.
Example is in this link....
http://forum.gsmhosting.com/vbb/8964717-post26.html
In the example they used bin format file.We are going to use file which i shared here............
Later i will share pac file that...........
Note:
Members please share also your factory files created by you, which are not available in the internet for many models...
The Following 4 Users Say Thank You to ashamsu For This Useful Post:
Old 05-24-2013, 12:22   #8 (permalink)
bencebacsi's Avatar
Member: 829361
Thanks Meter: 107
I'm sorry but I'm quite experienced in using Spreadtrum's ResearchDownload software. I tried to use your uploaded backup, but some files have to be truncated by a hex editor before flashing or the flashing process will stop due size error. The system.img is still not working. I'm not just talking but I've tried to flash your files and they don't work.
Btw, here is the latest Spreadtrum flasher: ResearchDownload_R2.9.7001
Here are some working .pac files:
Feiting_A7100_6820_2.3.5_c910_hteng_s5_en_4.0_v01
Feiting_N9300_C909_HT_EN_V04_20121017
Feiting_N9300_C909_JF_EN_v03-235_20121120
S5830i_20121006_c909_JF_EAHC_V12
S5830i_20121120_c909_JF_EN_v03-235
The Following 2 Users Say Thank You to bencebacsi For This Useful Post:
Old 05-24-2013, 13:55   #9 (permalink)
Member: 376471
Sonork: 100.1608095
Thanks Meter: 107
Dear Member...
thanks for interest int his thread.
So, do u have pac files for S7562 clone...
Old 05-24-2013, 20:18   #10 (permalink)
bencebacsi's Avatar
Member: 829361
Thanks Meter: 107
I don't have any more factory pac files. They are very rare unfortunately. I have some pac files created by me, but I couldn't test them yet, so I won't provide them. I think that's very important to provide carefully tested firmwares only because a bad file can brick the phones of other users. That means somebody may lost his/her value.
Old 05-25-2013, 00:17   #11 (permalink)
Member: 169234
Thanks Meter: 10
Thx for files, i flashed all ok but phone go white screen, any solution bro?
Old 05-25-2013, 16:25   #12 (permalink)
bencebacsi's Avatar
Member: 829361
Thanks Meter: 107
You should flash the same version what you had originally. Different versions may contain different LCD drivers not compatible each other.
Old 05-25-2013, 17:53   #13 (permalink)
Member: 1879830
Sonork: 1111
so,how to make .pac file with research download ? research download can made .pac file? i have many .img file and i dont know how to install ,so can i change .img to .pac ? thank fri
The Following User Says Thank You to aungmyoswe For This Useful Post:
Old 05-26-2013, 02:09   #14 (permalink)
bencebacsi's Avatar
Member: 829361
Thanks Meter: 107
Yes, research download can make pac files but you have to load all images separately. Then click on the 'Packet' button.
Old 05-26-2013, 05:43   #15 (permalink)
Member: 1879830
Sonork: 1111
thank fri,so there is any tutorial to make .pac file ? thank fri
Page generated in 0.25039 seconds with 9 queries
