01-19-2014, 08:03 | #16 (permalink) |
Freak Poster Join Date: Jul 2011 Location: Sri Lanka Age: 34
Member: 1615710 Status: Offline Sonork: 100.1647890 Thanks Meter: 260 | I am Happy to see this thread in Sticky aira I am Happy to see this thread in Sticky aira. Soon you will see My Final Short finding Guide post Here. This will be the Most wanted Tutorial in This Section. That means you wll learn How to Find Full Short in a mobile phone. Wbr, N.C.Erepola ..::SriLanka::.. |
The Following 4 Users Say Thank You to N.C.Erepola For This Useful Post: |
01-19-2014, 14:49 | #17 (permalink) |
Member: 1615710 Status: Offline Sonork: 100.1647890 Thanks Meter: 260 | How to find none Heating Shorts in Mobile Phones Have a nice time mates. Today I am going to Present you the Final Guide of this thred.. That is what you all asked. The sprit of short finding mission. How To Find None Heating Short(Full Short) on a Mobile Phone What We Need? Analog Multimeter or Valid Schematic of Faulty mobile How To Find This Short? Please keep in mind this is the way that I use my self. This method I am using from a long time. You also can try this and get in to the success in Short solving. 1.First of all Put your Multimeter to X10. and make 0 ohm adjets. 2.Check all the Capacitors on the mobile PCB as shown in Picture.. Here you have to Put Red test prob on Vbat Pin and Black Test Prob on all Capacitors data side in PCB. Mark every cap that shown the Pointer to 0 ohm like above Picture.. The caps What we Need.... look at the Pointer of Multimeter.... Caps that we don't Care.... ( Carefully look at the Pointer of multimeter) Take a marker and Put a dot on each Capasitors what we need. They are the Vcaps. If these capasitors are leaked they make full Short on your mobile. How To remove This Short ? easy..... Carefully remove marked caps one by one while checking short on mobile. Like this I reomve one cap then I check shorting on Phone.. Oh still there is full short again I remove onother one... ah haaaa.... bingoooo... When I check shorting There is no Shorting..... What does this mean? The Cap I removed was Leaked one and it was the reson to the Sort of mobile.. So I think Now you can understand how to do this... Remove all marked Vcaps one by one untill you see the short removed.. Thats it. If you check the Mobiles Schematic you will easy find what are these V caps and how they are situating on a schematics. Find Red marked cap on Nokia 1110 RH-70 PCB if you check this with multimeter it will show as a Vcap.. Look at the Schematic one side to Vbat other side to GND Some technicians using wrong methods. Not checking with Multimeter just remove big caps. This is Wrong. The size of cap is not not important. Just check schematic or use MM. Carefully look at marked caps. Some are small some are big. but all are Vcaps... See the Schematic proof Hope you will understand this method and use to your repairing... Any questions make your comments. thank you all. Wbr. N.C.Erepola ..::SriLanka::.. |
The Following 10 Users Say Thank You to N.C.Erepola For This Useful Post: |
01-19-2014, 18:43 | #18 (permalink) |
No Life Poster Join Date: Oct 2009 Location: srilanka Age: 39
Member: 1133072 Status: Offline Thanks Meter: 505 | in my experience i think not need this . because we cant check parell cap with this method. also some cap short only with high ampiere, and if some cap fully short surely it get heat, but with fully short M/B we cant give 3.8V or 4V. need start with 0.1v and step by step power up. in last step before cut off power supply if short came from capacitor need heat up it, i used this easy way to find short from capasistor. but i dont khow i using correct method or not i have repaid lot of phone using this method. |
The Following User Says Thank You to .::Gsm_Srilanka::. For This Useful Post: |
01-21-2014, 14:48 | #19 (permalink) | |
Member: 1615710 Status: Offline Sonork: 100.1647890 Thanks Meter: 260 | Quote:
01-22-2014, 19:31 | #20 (permalink) | |
Member: 1133072 Status: Offline Thanks Meter: 505 | Quote:
no i challenge this is not 100% success method, but some time work, cant get 100%. i think u need more experience to understand this, seniors can understand what i say. also i hate fake solution. | |
01-23-2014, 07:03 | #21 (permalink) |
Member: 1615710 Status: Offline Sonork: 100.1647890 Thanks Meter: 260 | This solution all about leaked caps. and full short mobile that does not heat up!! please read carefully befor post. I think you must learn to read English first. |
01-29-2014, 06:13 | #22 (permalink) | |
No Life Poster Join Date: Jun 2008 Location: Wish i was on Mars Age: 40
Member: 789089 Status: Offline Sonork: 100.1617*** Thanks Meter: 267 | Quote:
Hi .::Gsm_Srilanka::., I nice to know there are good critics out here, but it would be nice if u could explain in detail, how you methods works. what you have done is given us the idea in a few words, looking forward to know your method in detail. br frenzy | |
12-16-2014, 23:30 | #27 (permalink) | |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | Quote:
And , you are talking about 100% testing caps ?? What about caps that are faulty and will not get heat or visible as damaged ones. There are few ways to check caps , he is telling his way and at last he is doing gr8 job. If you want to help other members open own thread. So stop make mass on other PPL threads | |
01-25-2015, 08:26 | #28 (permalink) |
Major Poster Join Date: Aug 2014 Location: bhubaneswar
Member: 2242234 Status: Offline Thanks Meter: 8 | yess certainly, Put power to your mobile using DC power Supply if your phone full shorted give 0-1.5v to phone. if normal short, 3.8v to 4.2v is ok. Carefully find out if any part or IC heating. if some one heats, remove it and apply 3R to it. (Re solder, Re ball, Replace) |
The Following User Says Thank You to nisar akhtar For This Useful Post: |
01-29-2015, 22:02 | #29 (permalink) |
Junior Member Join Date: Dec 2014 Location: kuwait
Member: 2320348 Status: Offline Thanks Meter: 0 | in my experience i think not need this . because we cant check parell cap with this method. also some cap short only with high ampiere, and if some cap fully short surely it get heat, but with fully short M/B we cant give 3.8V or 4V. need start with 0.1v and step by step power up. in last step before cut off power supply if short came from capacitor need heat up it, i used this easy way to find short from capasistor. but i dont khow i using correct method or not i have repaid lot of phone using this method. I did not understand how to chek samsung galaxy phones which are dead please tell me...!! |
02-20-2015, 23:13 | #30 (permalink) | |
Junior Member Join Date: Mar 2014
Member: 2142857 Status: Offline Thanks Meter: 3 | Quote:
The Following 2 Users Say Thank You to Phonezone1 For This Useful Post: |
