Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help |
04-05-2017, 06:42 | #3 (permalink) | |
No Life Poster Join Date: Jul 2010 Location: chennai, india
Member: 1354113 Status: Offline Thanks Meter: 669 | Quote: plz upload screen short because any risk with mobile | |
The Following User Says Thank You to kumar008 For This Useful Post: |
04-05-2017, 07:40 | #6 (permalink) | |
No Life Poster Join Date: Apr 2016 Location: OneTheWay
Member: 2554807 Status: Offline Thanks Meter: 612 | Quote:
04-05-2017, 20:23 | #14 (permalink) |
Junior Member Join Date: May 2005 Location: Valparaiso Age: 44
Member: 143368 Status: Offline Thanks Meter: 28 | 1. Install "MotoService 3.0.4 2. After installation, perform the following procedures: The. Go to "C: \ Program Files (x86) \ Motorola \ MotoService" (default installation location) 3. Rename "Motoweb.dll" dll to Motoweb2.dll. W Then go to "MotoService" for the first time and close. 4. Go to "C: \ ProgramData \ Motorola \ MotoService" and rename the file "MotoServiceOptions.json" for MotoServiceOptions2.json. Y. Then edit the MotoServiceOptions2.json file (right-click Put it with the notebook). 5. Edit in line 13 the following name (":: offlinemode: false"), place "Offlinemode": true, save as MotoServiceOptions.json, close and open The program normally done this will free the side menus. 6. Turn the unit off and then on again in "FASTBOOT" mode (POWER + VOLUME -), select "FACTORY MODE" and press Power. computer 7. Open the "MotoService" program, go to "Options" - "Port Settings", On the screen, the device will select the number you want to place. Press "Assing" and "Done" 8. In the menu select "Power Test", this will be done on the device port will appear Once again, "Tower Test" again press this option, after this a window will open and Press "Yes" 9. Remove the appliance from the mains and turn it on again in FACTORY MODE and The power button again connects to the computer, which Enable USB debugging check the option and ok. 10. Open the Adb command prompt and perform the second procedure of the old devices (G2, G3) by entering the following command. 11. adb devices 12. adb shell content insert --url content: // settings / secure --bind First Name: s: user_setup_complete --bind value: s: 1 13. Turn the device off and on and unlock |
The Following 8 Users Say Thank You to wincel For This Useful Post: |
