Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Android based
Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help
Old 08-21-2017, 03:09   #46 (permalink)
Member: 1898890
Thanks Meter: 10
Originally Posted by ranjithsonic View Post
power test error. tried version 2.1.2, 3.0.4, same issue.
after click power test mobile turn off.
http://forum.gsmhosting.com/vbb/f672.../#post12644014
Old 08-21-2017, 16:56   #47 (permalink)
gsm reqest's Avatar
Member: 1399206
Sonork: reqest
Thanks Meter: 113
my phone same problem
Old 08-24-2017, 14:25   #48 (permalink)
Member: 806651
Sonork: gowda123
motoservice user username and password
Old 10-05-2017, 18:13   #49 (permalink)
Member: 143368
Thanks Meter: 28
motoservice 3.1.6
https://mega.nz/#!kxxwRThJ!3ZKSD-ny5...84euns90mYWcIo
Old 10-15-2017, 11:41   #50 (permalink)
Crazy Poster
Member: 2419215
Thanks Meter: 5
Originally Posted by wincel View Post
1. Install "MotoService 3.0.4
2. After installation, perform the following procedures:
The. Go to "C: \ Program Files (x86) \ Motorola \ MotoService" (default installation location)
3. Rename "Motoweb.dll" dll to Motoweb2.dll.
W Then go to "MotoService" for the first time and close.
4. Go to "C: \ ProgramData \ Motorola \ MotoService" and rename the file
"MotoServiceOptions.json" for MotoServiceOptions2.json.
Y. Then edit the MotoServiceOptions2.json file (right-click
Put it with the notebook).
5. Edit in line 13 the following name (":: offlinemode: false"), place
"Offlinemode": true, save as MotoServiceOptions.json, close and open
The program normally done this will free the side menus.
6. Turn the unit off and then on again in "FASTBOOT" mode (POWER +
VOLUME -), select "FACTORY MODE" and press Power.
computer
7. Open the "MotoService" program, go to "Options" - "Port Settings",
On the screen, the device will select the number you want to place.
Press "Assing" and "Done"
8. In the menu select "Power Test", this will be done on the device port will appear
Once again, "Tower Test" again press this option, after this a window will open and
Press "Yes"
9. Remove the appliance from the mains and turn it on again in FACTORY MODE and
The power button again connects to the computer, which
Enable USB debugging check the option and ok.
10. Open the Adb command prompt and perform the second procedure of the old devices
(G2, G3) by entering the following command.
11. adb devices
12. adb shell content insert --url content: // settings / secure --bind
First Name: s: user_setup_complete --bind value: s: 1
13. Turn the device off and on and unlock
Not working on june security. plz check
Old 10-15-2017, 22:57   #51 (permalink)
Member: 2732970
Not working in june patch
The Following User Says Thank You to jessejgm For This Useful Post:
Old 10-21-2017, 11:08   #52 (permalink)
Member: 2770230
Thanks Meter: 3
I can't follow the guide, some thing are not clear
Old 12-04-2017, 09:59   #53 (permalink)
Member: 2121706
Thanks Meter: 3
Cannot find
"C: \ ProgramData \ Motorola \ MotoService" and rename the file "MotoServiceOptions.json" for MotoServiceOptions2.json.
suggestions?
Old 08-25-2018, 10:38   #54 (permalink)
Member: 1998299
Thanks Meter: 16
Upgrade
Only upgrade to motoservice 3.1.6 an do what wincel wrote
Page generated in 0.16213 seconds with 9 queries
