Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Android based
Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help
Old 04-05-2017, 05:57   #1 (permalink)
Member: 143368
Thanks Meter: 28
Hot !!! Remove frp 7.0-7.1 motorola
https://mega.nz/#!gJdSQBrD!oaZWActrG...Hpp1aPVfmo-ZZU
CHILE
The Following 12 Users Say Thank You to wincel For This Useful Post:
Old 04-05-2017, 06:24   #2 (permalink)
Member: 1492930
Thanks Meter: 63
sir plzzzzzzzz give me video.
Old 04-05-2017, 06:42   #3 (permalink)
Member: 1354113
Thanks Meter: 669
Originally Posted by wincel View Post
this file wich format r u tested file
plz upload screen short because
any risk with mobile
The Following User Says Thank You to kumar008 For This Useful Post:
Old 04-05-2017, 07:02   #4 (permalink)
Member: 143368
Thanks Meter: 28
0% risk
in YouTube modo of use
motoservice
Old 04-05-2017, 07:15   #5 (permalink)
Member: 143368
Thanks Meter: 28
https://www.youtube.com/watch?v=wPljJSlO0Ms
https://www.youtube.com/watch?v=8h5VZMRo_ZU
Last edited by MyGSM World; 04-05-2017 at 11:04. Reason: Other Forum Link Removed.
Old 04-05-2017, 07:40   #6 (permalink)
Nishan_Raja's Avatar
Member: 2554807
Thanks Meter: 612
how its works vedio proof
https://www.youtube.com/watch?v=uQnJ...ture=*********
Old 04-05-2017, 09:20   #7 (permalink)
Gsmbizz's Avatar
Member: 745672
Thanks Meter: 555
It is fake solution you cant use moto tool without username and pass..
Old 04-05-2017, 11:59   #8 (permalink)
Member: 1354113
Thanks Meter: 669
u have moto tool plz share
Old 04-05-2017, 13:23   #9 (permalink)
perfect1's Avatar
Member: 511749
Thanks Meter: 335
Its Real.. But Share Tool Motorola here For frp remove..
Old 04-05-2017, 15:35   #10 (permalink)
kzafquiel's Avatar
Member: 1318721
Thanks Meter: 166
Check it
Frp done
Remote service
ht t ps: //youtu. be /lAYp DI4js v4
Old 04-05-2017, 16:58   #11 (permalink)
Member: 143368
Thanks Meter: 28
Replace these files in folder "C: \ ProgramData \ Motorola \ Moto Service"
The Following User Says Thank You to wincel For This Useful Post:
Old 04-05-2017, 17:14   #12 (permalink)
Member: 143368
Thanks Meter: 28
Frp Motorola V7.0 & V7.1
motoservice 3.0.4
Old 04-05-2017, 19:29   #13 (permalink)
Member: 797068
Thanks Meter: 75
instalation ok, but used program?
Old 04-05-2017, 20:23   #14 (permalink)
Member: 143368
Thanks Meter: 28
1. Install "MotoService 3.0.4
2. After installation, perform the following procedures:
The. Go to "C: \ Program Files (x86) \ Motorola \ MotoService" (default installation location)
3. Rename "Motoweb.dll" dll to Motoweb2.dll.
W Then go to "MotoService" for the first time and close.
4. Go to "C: \ ProgramData \ Motorola \ MotoService" and rename the file
"MotoServiceOptions.json" for MotoServiceOptions2.json.
Y. Then edit the MotoServiceOptions2.json file (right-click
Put it with the notebook).
5. Edit in line 13 the following name (":: offlinemode: false"), place
"Offlinemode": true, save as MotoServiceOptions.json, close and open
The program normally done this will free the side menus.
6. Turn the unit off and then on again in "FASTBOOT" mode (POWER +
VOLUME -), select "FACTORY MODE" and press Power.
computer
7. Open the "MotoService" program, go to "Options" - "Port Settings",
On the screen, the device will select the number you want to place.
Press "Assing" and "Done"
8. In the menu select "Power Test", this will be done on the device port will appear
Once again, "Tower Test" again press this option, after this a window will open and
Press "Yes"
9. Remove the appliance from the mains and turn it on again in FACTORY MODE and
The power button again connects to the computer, which
Enable USB debugging check the option and ok.
10. Open the Adb command prompt and perform the second procedure of the old devices
(G2, G3) by entering the following command.
11. adb devices
12. adb shell content insert --url content: // settings / secure --bind
First Name: s: user_setup_complete --bind value: s: 1
13. Turn the device off and on and unlock
The Following 8 Users Say Thank You to wincel For This Useful Post:
Old 04-06-2017, 08:51   #15 (permalink)
Member: 2506794
Sonork: 100.1675120
Thanks Meter: 118
how to use..and how to remove frp lock video guide please.
Page generated in 0.19919 seconds with 9 queries
