Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Android based
Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help
Old 09-26-2019, 14:30   #1 (permalink)
sagarjais's Avatar
Member: 2355125
Thanks Meter: 52
Moto X4 XT1900-2 No bootable A/B slot Failed to boot linux
Moto X4 XT1900-2 No bootable A/B slot Failed to boot linux, falling Back to fastboot
fastboot reason: Fall Through from normal boot mode
i have flashed this phone with these 2 files Successfully but after flashing it reboots automatically 4-5 times then returns to this bootloader screen.
help me out Developers Team
Scrrenshots are here
https://drive.google.com/open?id=1MY...uTWpr7esQbCzYW
Old 10-09-2019, 10:31   #2 (permalink)
fofesz's Avatar
Member: 22869
Thanks Meter: 132
same problem here with X1941-4 Moto One
Tried to downgrade, failed to write boot, after 1 time was flashed & booted. Now A/B slot error.
Lenovo Moto Smart Assistant's rescue function fail:
This device is not supported.
Bootloader is locked.
Any idea?
Old 10-09-2019, 13:00   #3 (permalink)
sagarjais's Avatar
Member: 2355125
Thanks Meter: 52
Any idea?
yes i have repaired it successfully
just post getvar info of your device i'll help you solve it out.
Old 10-09-2019, 14:49   #4 (permalink)
fofesz's Avatar
Member: 22869
Thanks Meter: 132
happy to hear that sagarjais
didnt have time to play more with this, just updated fastboot.exe
fastboot getvar all
INFOversion: 0.5
INFOversion-bootloader: MBM-2.1-deen_retail-2ddc041-190826
INFOproduct: deen
INFOboard: deen
INFOsecure: yes
INFOhwrev: PVT1
INFOradio: 7
INFOstorage-type: emmc
INFOemmc: 64GB SAMSUNG RH64AB RV=08 PV=05 FV=0000000000000005
INFOram: 4GB SAMSUNG LP3 DIE=8Gb M5=01 M6=06 M7=00 M8=5F
INFOcpu: MSM8953
INFOserialno: ZL5229xxxx
INFOcid: 0x0032
INFOchannelid: 0x00
INFOuid: 3CFE31E700000000000000000000
INFOsecurestate: oem_locked
INFOiswarrantyvoid: no
INFOmax-download-size: 534773760
INFOreason: Volume down key pressed
INFOimei: 359548091xxxxxx
INFOmeid:
INFOdate: 10-25-2018
INFOsku: XT1941-4
INFOcarrier_sku: XT1941-4
INFObattid: SB18C30734
INFOiccid:
INFOcust_md5:
INFOmax-sparse-size: 268435456
INFOcurrent-time: "Tue Aug 20  9:17:29 UTC 2019"
INFOro.build.fingerprint[0]: motorola/deen/deen_sprout:9/PPKS29
INFOro.build.fingerprint[1]: .68-16-36-7/8c3bf:user/release-key
INFOro.build.fingerprint[2]: s
INFOpoweroffalarm: 0
INFOro.build.version.full[0]: Blur_Version.39.401.27.deen.retai
INFOro.build.version.full[1]: l.en.US
INFOro.build.version.qcom: LA.UM.7.6.r1-02500-89xx.0
INFOversion-baseband: M8953_16.15.02.23R DEEN_APACDSDS_CUST
INFOkernel.version[0]: Linux version 3.18.115-perf-ge7150b7-041
INFOkernel.version[1]: 57-gc8b6600 (hudsoncm@ilclbld66) (gcc ve
INFOkernel.version[2]: rsion 4.9.x 20150123 (prerelease) (GCC)
INFOkernel.version[3]: ) #1 SMP PREEMPT Mon Aug 26 21:16:22 CDT
INFOkernel.version[4]:  2019
INFOsbl1.git: MBM-2.1-deen_retail-b314434-190826
INFOrpm.git: MBM-2.1-deen_retail-80327a1-190826
INFOtz.git: MBM-2.1-deen_retail-a495796-dirty-190826
INFOdevcfg.git: MBM-2.1-deen_retail-a495796-dirty-190826
INFOkeymaster.git: MBM-2.1-deen_retail-a495796-190826
INFOcmnlib.git: MBM-2.1-deen_retail-a495796-190826
INFOcmnlib64.git: MBM-2.1-deen_retail-a495796-190826
INFOprov.git: MBM-2.1-deen_retail-a495796-dirty-190826
INFOaboot.git: MBM-2.1-deen_retail-2ddc041-190826
INFOfrp-state: protected (77)
INFOro.carrier: reteu
INFOcurrent-slot: _b
INFOrunning-boot-lun: 0
INFOrunning-slot: _b
INFOslot-suffixes: _a,_b
INFOslot-count: 2
INFOslot-successful:_a: No
INFOslot-successful:_b: No
INFOslot-bootable:_a: No
INFOslot-bootable:_b: Yes
INFOslot-retry-count:_a: 0
INFOslot-retry-count:_b: 6
all: listed above
finished. total time: 0.044s
Is this the error?
INFOslot-count: 2
Old 10-09-2019, 15:26   #5 (permalink)
sagarjais's Avatar
Member: 2355125
Thanks Meter: 52
fastboot getvar all
INFOversion: 0.5
INFOproduct: deen
INFOboard: deen
INFOsecure: yes
INFOhwrev: PVT1
INFOradio: 7
INFOcpu: MSM8953
INFOcid: 0x0032
INFOchannelid: 0x00
INFOmeid:
INFOsku: XT1941-4
INFOiccid:
INFOcust_md5:
INFOslot-count: 2
all: listed above
Is this the error?
INFOslot-count: 2
Here is your firmware
flash all the files seperately using fastboot commands one by one
DEEN_RETAIL_9.0_PPKS29.68-16-36-7_cid50_subsidy-DEFAULT_regulatory-DEFAULT_CFC.xml.zip
Best Regards
Sagar Jaiswal
Press Thanks If Helped
Old 10-10-2019, 08:02   #6 (permalink)
fofesz's Avatar
Member: 22869
Thanks Meter: 132
still not booting, even flashing one by one
which version of fastboot you are using?
The Following User Says Thank You to fofesz For This Useful Post:
Old 10-10-2019, 12:35   #7 (permalink)
sagarjais's Avatar
Member: 2355125
Thanks Meter: 52
i am using Mfastboot V2
and fb commands are below
fastboot oem fb_mode_set
fastboot flash partition gpt.bin
fastboot flash bootloader bootloader.img
fastboot flash logo logo.bin
fastboot flash boot boot.img
fastboot flash recovery recovery.img
fastboot flash dsp adspso.bin
fastboot flash oem oem.img
fastboot flash system system.img_sparsechunk.0
fastboot flash system system.img_sparsechunk.1
fastboot flash system system.img_sparsechunk.2
fastboot flash system system.img_sparsechunk.3
fastboot flash system system.img_sparsechunk.4
fastboot flash system system.img_sparsechunk.5
fastboot flash system system.img_sparsechunk.6
fastboot flash system system.img_sparsechunk.7
fastboot flash system system.img_sparsechunk.8
fastboot flash modem NON-HLOS.bin
fastboot erase modemst1
fastboot erase modemst2
fastboot flash fsg fsg.mbn
fastboot erase cache
fastboot erase userdata
fastboot erase customize
fastboot erase clogo
fastboot oem fb_mode_clear
fastboot reboot
Old 10-10-2019, 15:25   #8 (permalink)
Cheater -Don't Deal with him-
Member: 1728299
Thanks Meter: 7
fastboot reboot
Motorola X4 XT1900-2 (Sterling Blue, 64GB)
use this tool works perfect
Old 10-10-2019, 15:48   #9 (permalink)
Mobile-Lab's Avatar
Member: 10028
Sonork: n/a
Thanks Meter: 840
try flashing this firmware:
https://mirrors.lolinet.com/firmware...LT_CFC.xml.zip
Old 10-11-2019, 06:25   #10 (permalink)
sagarjais's Avatar
Member: 2355125
Thanks Meter: 52
Originally Posted by Mobile-Lab View Post
His device version is RETAIL not RETEU
so kindly check the info before posting
Best Regards
Sagar Jaiswal
The Following User Says Thank You to sagarjais For This Useful Post:
Old 10-11-2019, 15:27   #11 (permalink)
Mobile-Lab's Avatar
Member: 10028
Sonork: n/a
Thanks Meter: 840
Best Regards
Sagar Jaiswal
..and now what?
Old 10-12-2019, 06:32   #12 (permalink)
sagarjais's Avatar
Member: 2355125
Thanks Meter: 52
..and now what?
So you do flash firmware according to carrier info instead of build number which is
Old 10-14-2019, 21:03   #13 (permalink)
fofesz's Avatar
Member: 22869
Thanks Meter: 132
hello guys,
no difference between RETAIL or RETEU flashing, both accepted by phone
Found something strange, after flashing but before reboot, getvar all shows:
flashing DEEN_RETAIL_9.0_PPKS29.68-16-36-7....
(bootloader) slot-bootable:_a: Yes
(bootloader) slot-bootable:_b: Yes
(bootloader) slot-retry-count:_a: 7
(bootloader) slot-retry-count:_b: 0
fastboot reboot
getvar all
(bootloader) slot-bootable:_a: No
(bootloader) slot-bootable:_b: No
so far not found the solution, anyone can repair remotely please send PM
Old 01-29-2022, 01:17   #14 (permalink)
Member: 2382052
Thanks Meter: 1,511
no a/b slot
Best Regards
Sagar Jaiswal
hello can u help me
:\Program Files (x86)\Minimal ADB and Fastboot>fastboot getvar all
(bootloader) version: 0.5
(bootloader) version-bootloader: MBM-2.1-deen_retail-6f8d34a-190128
(bootloader) product: deen
(bootloader) board: deen
(bootloader) secure: yes
(bootloader) hwrev: PVT1
(bootloader) radio: 2
(bootloader) storage-type: emmc
(bootloader) emmc: 64GB SAMSUNG RH64AB RV=08 PV=05 FV=0000000000000005
(bootloader) ram: 4GB SAMSUNG LP3 DIE=8Gb M5=01 M6=06 M7=00 M8=5F
(bootloader) cpu: MSM8953
(bootloader) serialno: ZL5228FXC9
(bootloader) cid: 0x0032
(bootloader) channelid: 0x29
(bootloader) uid: AE64A4A600000000000000000000
(bootloader) securestate: oem_locked
(bootloader) iswarrantyvoid: no
(bootloader) max-download-size: 534773760
(bootloader) reason: Fall-through from normal boot mode
(bootloader) imei: 3555460907
(bootloader) meid:
(bootloader) date: 09-18-2018
(bootloader) sku: XT1941-5
(bootloader) carrier_sku: XT1941-5
(bootloader) battid: SB18C30734
(bootloader) iccid:
(bootloader) cust_md5:
(bootloader) max-sparse-size: 268435456
(bootloader) current-time: "Sun Dec 16 17: 4:59 UTC 2018"
(bootloader) ro.build.fingerprint[0]: motorola/deen/deen_sprout:9/PPKS29
(bootloader) ro.build.fingerprint[1]: .68-16-21-2/99791:user/release-key
(bootloader) ro.build.fingerprint[2]: s
(bootloader) poweroffalarm: 0
(bootloader) ro.build.version.full[0]: Blur_Version.39.221.3.deen.retail
(bootloader) ro.build.version.full[1]: .en.US
(bootloader) ro.build.version.qcom: LA.UM.7.6.r1-02500-89xx.0
(bootloader) version-baseband: M8953_16.15.02.19R DEEN_LATAM_CUST
(bootloader) kernel.version[0]: Linux version 3.18.115-perf-g9f9181a (hu
(bootloader) kernel.version[1]: dsoncm@ilclbld67) (gcc version 4.9.x 201
(bootloader) kernel.version[2]: 50123 (prerelease) (GCC) ) #1 SMP PREEMP
(bootloader) kernel.version[3]: T Thu Dec 27 09:26:21 CST 2018
(bootloader) sbl1.git: sbl1.git
(bootloader) rpm.git: rpm.git
(bootloader) tz.git: tz.git
(bootloader) devcfg.git: devcfg.git
(bootloader) keymaster.git: keymaster.git
(bootloader) cmnlib.git: cmnlib.git
(bootloader) cmnlib64.git: cmnlib64.git
(bootloader) prov.git: prov.git
(bootloader) aboot.git: MBM-2.1-deen_retail-6f8d34a-190128
(bootloader) frp-state: protected (77)
(bootloader) ro.carrier: openmx
(bootloader) current-slot:
(bootloader) running-boot-lun: 0
(bootloader) running-slot:
(bootloader) slot-suffixes: _a,_b
(bootloader) slot-count: 2
(bootloader) slot-successful:_a: No
(bootloader) slot-successful:_b: No
(bootloader) slot-retry-count:_a: 0
all: listed above
finished. total time: 0.445s
Page generated in 0.36065 seconds with 8 queries
