Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help |
11-15-2016, 22:42 | #1 (permalink) |
Junior Member Join Date: Nov 2016
Member: 2649529 Status: Offline Thanks Meter: 0 | Need Help to Unlock Moto E XT1526 Sprint I own the Moto E XT1526 offered by my aunt. She had Sprint mobile operator. I live in Morocco, and the phone does not pick up the network. He asks me the pin code, he recognizes the sim card. So, I think I need to unlock the phone. I tried some methods found on YouTube. But it did not work for me. Can you help me please? I have already search in this forum without find a solution. I hope to find a solution in this forum. Thank's in advance. |
11-16-2016, 10:56 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Marking * # * # 4636 # * # * will give you the option to switch to gsm networks. Put the sim of another company and wait a few minutes and see that the option appears. * # * # 4636 # * # *, set preferred network type: TD-SCDMA and GSM You can also do this: 1. With the chip inside you slide the top bar of your phone and select the sim icon that will appear "NO SERVICE". 2. You go to "MORE OPTIONS" 3. Select the "MAS" button in the upper right corner and select the option "MOBILE NETWORKS" 4. Where it says "TYPE OF PREFERRED NETWORK" select "3G" since by default LTE appears and therefore does not raise signal. 5. You get out the CHIP and execute the code * # * # 4636 # * # * and select the type of network you want, you leave the menu and METES THE SIM and go. |
The Following User Says Thank You to gcceleghg For This Useful Post: |
11-16-2016, 15:33 | #3 (permalink) |
Member: 2649529 Status: Offline Thanks Meter: 0 | Thank's for helping! I tried this method, but it doesn't work. I can not select : TD-SCDMA and GSM when I do it, the phone select : CDMA auto (PRL). I tried with TD-SCDMA, GSM ans Lte. But no change. When I reboot the phone or when I go back to menu switch to gsm networks, he returns to CDMA auto (PRL). I don't think he save the changes. More help please, thanks in advance. |
11-16-2016, 16:22 | #4 (permalink) | |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
Tested on an XT1526 from Sprint, which did not grab GSM coverage in any way. Adb reboot bootloader Fastboot erase modemst1 Fastboot erase modemst2 fastboot reboot These commands eliminate all configuration of the modem and start the phone with the modem "clean" just insert the SIM and grab Full signal. ************************************************** ****** Or you can try this: Try putting the computer in plane mode and entering the commands in this order: adb shell Pm clear com.android.providers.telephony Settings put global preferred_network_mode 9 Settings put global preferred_network_mode1 9 Settings put global preferred_network_mode2 9 Then reboot and take it out of the way. Then we dial * # * # 4636 # * # * We selected lte gsm auto prl Without closing this menu we remove the airplane mode And full signal | |
The Following 3 Users Say Thank You to gcceleghg For This Useful Post: |
11-16-2016, 16:26 | #5 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Permanent Process: Unlock the Bootloader Install KingoRoot When the finished device, authorize "adb" to root access. Finally, connect to a root console: (surnia / osprey / etc) ./adb shell shell @ surnia_cdma: / $ su surnia_cdma root @: / # And there run: pm clear com.android.providers.telephony Thus, they are clean configurations phone, restart the terminal reboot or adb reboot And again execute the above procedure: settings put global preferred_network_mode 9 settings put global preferred_network_mode1 9 settings put global preferred_network_mode2 9 To verify, you can request the information menu: * # * # 4636 # * # * (4636 = I N F O) And there, in "Network information" seeking radio mode by default (Default: TD-SCDMA, LTE, CDMA, EvDO GSM / WCDMA) |
11-16-2016, 21:05 | #9 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | unlock bootloader and flash with another rom ,in my case i flash one from telus XT1527_SURNIA_RETCA-TELUS_6.0_MPI24.65-39_cid14_subsidy-TELUS_CFC.xml work fine ,after that i unlock with gcpro key |
11-16-2016, 22:12 | #10 (permalink) | |
Just follow this link: https://accounts.motorola.com/ssoaut...-your-device-b | |
06-21-2017, 19:14 | #12 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | this worked for mine: Tested on an XT1526 from Sprint, which did not grab GSM coverage in any way. Adb reboot bootloader Fastboot erase modemst1 Fastboot erase modemst2 fastboot reboot These commands eliminate all configuration of the modem and start the phone with the modem "clean" just insert the SIM and grab Full signal. but only temporary, off on and need to do it again |
The Following User Says Thank You to mrfixit For This Useful Post: |
08-06-2017, 07:58 | #14 (permalink) | |
Crazy Poster Join Date: Jun 2015 Location: Dhaka
Member: 2419215 Status: Offline Thanks Meter: 5 | Quote:
