03-14-2017, 08:40 | #4292 (permalink) |
Major Poster Join Date: Jan 2017 Location: turkey Age: 37
Member: 2673822 Status: Offline Thanks Meter: 7 | tnx octopus team Welcome to Octoplus/Octopus Box LG Software version 2.6.0 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM12 Selected model: D855 Reading info... Model ID: LG-D855 IMEI: 351********** Android version: 6.0 Battery level: 63% SW Version: D85530b Mode: Emergency Initializing flash...OK SW version: LGD855AT-00-V30b-GLOBAL-TMO-MAR-17-2016-16G+0 Android version: 6.0 LAF Version: 1.1 Product ID: IMEI: 351********** Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "D85530e_00_0927.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing tz...OK Writing boot...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing factory...OK Writing system...OK Writing cust...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.6.0 Software version. |
The Following User Says Thank You to mojtabaghanidel For This Useful Post: |
03-14-2017, 20:09 | #4294 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Sindhu Desh Age: 37
Member: 199814 Status: Offline Thanks Meter: 1,960 | MS428 FRP Done [QUOTE][QUOTE] Checking data...OK Platform: LG Qualcomm Selected port: COM139 Selected model: MS428 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LGMS428 IMEI: 355221-08-094984-8 Android version: 6.0.1 Battery level: 39% SW Version: MS42810f Mode: Normal Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Resetting FRP Lock... Step 1...OK Step 2...OK Step 3...OK Resetting FRP lock successfully completed! Performed by 2.6.0 Software version. |
The Following User Says Thank You to asadnow2k For This Useful Post: |
03-15-2017, 09:30 | #4295 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Lg e445 flashing (auto app download/virus/hanging) solved -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM12 Selected baudrate: 921600 Selected model: E445 Selected USB connection type Please, disconnect battery and connect cable...OK Phone found. CPU name: MT6575 CPU revision: 8A00.CB00.E201.0000 Setting power state...OK Prepairing loader...OK Sending loader...OK Synchronizing with loader... Loader version: 3.2.132 Detecting flash chip...OK Detecting EMMC flash chip...OK Reading info...OK Opening "LG E445 V10F_00.oct"... Writing Firmware... Formating filesystem...OK Unlocking Bootloader...OK Writing FILE_INFO...OK Writing MBR...OK Checking partition...OK Writing EBR1...OK Writing EBR2...OK Writing EBR3...OK Writing UBOOT...OK Writing BOOTIMG...OK Writing RECOVERY...OK Writing SEC_RO...OK Writing LOGO...OK Writing PERSIST...OK Writing CUST...OK Writing ANDROID...OK Writing CACHE...OK Writing USRDATA...OK Checking partition...OK Writing __NODL...OK Finalizing...OK Writing firmware done! Performed by 2.5.5 Software version. |
The Following User Says Thank You to .::THE ROCK::. For This Useful Post: |
03-15-2017, 14:13 | #4296 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | LG D385 Flashing Code: Checking data...OK Platform: LG Qualcomm Selected port: COM120 Selected model: D385 Reading info... Model ID: LG-D385 IMEI: 000000-00-000000-0 Android version: 4.4.2 Battery level: 24% SW Version: D38510a Mode: Emergency Initializing flash...OK SW version: LGD385AT-00-V10a-OP1-SP-JUL-23-2014+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: PT5602141523118LU IMEI: 352483-06-432144-3 Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "D38510d_00.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing rpm...OK Writing tz...OK Writing sdi...OK Writing aboot...OK Writing rpmb...OK Writing tzb...OK Writing abootb...OK Writing persist...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing factory...OK Writing sbl1b...OK Writing cust...OK Writing system...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.5.9 Software version. |
The Following User Says Thank You to Tanha0321 For This Useful Post: |
03-15-2017, 14:13 | #4297 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | LG F320k Gmail Reset Code: Checking data...OK Platform: LG Qualcomm Selected port: COM68 Selected model: F320K Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-F320K IMEI: 356457-05-297576-2 Android version: 5.0.1 Battery level: 31% SW Version: CloudyG2 3.0 Mode: Emergency Initializing flash...OK SW version: LGF320KAT-00-V30d-KT-KR-JAN-07-2015+0 Android version: 5.0.1 LAF Version: 1.0 Product ID: SM08S140307000796 IMEI: 356457-05-297576-2 Target operator: OPEN Hardware: rev_10 Resetting Screen Lock...OK Resetting screen lock successfully completed! |
03-15-2017, 14:15 | #4298 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | LG D802 Gmail Reset Code: Checking data...OK Platform: LG Qualcomm Selected port: COM109 Selected model: D802 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)). Reading info... Model ID: LG-D802 IMEI: 000000-00-000000-0 Android version: 4.4.2 Battery level: 65% SW Version: D80220b Mode: Emergency Initializing flash...OK SW version: LGD802AT-00-20b-OPEN-CN-MAR-16-2014+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: SM06S130829001176 IMEI: 358635-05-953894-3 Target operator: OPEN Hardware: rev_10 Resetting Screen Lock...OK Resetting screen lock successfully completed! Performed by 2.5.5 Software version. |
03-15-2017, 18:13 | #4299 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Ukraine Age: 44
Member: 75408 Status: Offline Thanks Meter: 1,190 | Success unlock LG U8380: Code: Please reconnect battery and press "Power ON" Phone found Chip ID: 01030071 Hardware CID: 41 Mcert: A1_DB2000_41_RED Phone authorization: BROWN Sending preloader...OK Sending start loader...OK Sending main loader...OK FLASHLOADER: 50223 1439 LLECXC1325414_FLASHLOADER R3V Flash ID: 890D Flash type: Intel RD38F4050L0YT IMEI: 355646-00-123xxxx Sending main flashpreloader...OK Sending flashpreloader...OK Sending loader...OK CERTLOADER: 040318 1450 LLECXC1325413_CERTLOADER R3J Sending afterloader 1...OK Sending afterloader 2...OK Reading "CheckSum" block...OK Reading "SIM2G" block...OK Reading "PhoneSPLock" block...OK Reading "DrivecServiceProviderLock" block...OK Patching "CheckSum" block...OK Patching "SIM2G" block...OK Patching "PhoneServiceProviderLock" block...OK Patching "DrivecServiceProvider" block...OK Writing "CheckSum" block...OK Writing "SIM2G" block...OK Writing "PhoneServiceProviderLock" block...OK Writing "DrivecServiceProviderLock" block...OK Phone successfully unlocked Disconnected. |
The Following User Says Thank You to Dr_Wolodya For This Useful Post: |
03-16-2017, 11:07 | #4300 (permalink) |
No Life Poster Join Date: Jul 2005 Location: In My PC Age: 46
Member: 165971 Status: Offline Thanks Meter: 65 | k121 unlocked ok Code: Welcome to Octoplus/Octopus Box LG Software version 2.6.0 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM158 Selected model: K121 Reading info... Model ID: LG-K121 IMEI: 356541-07-308014-8 Android version: 5.1.1 Battery level: 79% SW Version: K12110f Trying to enable Diagnostics ports... Found model LGK121AT: ÿh `n at port COM158 Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "K121_356541073080148_16-03-2017_10-53-56.qcn" Do you want to create security backup? Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "K121_356541073080148_16-03-2017_11-01-15.SEC" Switching to Normal mode... Found model LGK121AT: ÿh `n at port COM158 Writing security area...OK Rebooting phone... Found model LGK121AT: ÿh `n at port COM158 Phone successfully unlocked! Please, reboot the phone manually. Performed by 2.6.0 Software version. |
The Following User Says Thank You to bendou For This Useful Post: |
03-16-2017, 18:46 | #4301 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | lg vs980 write flash done Code: Checking data...OK Platform: LG Qualcomm Selected port: COM41 Selected model: VS980 Reading info... Mode: Emergency Initializing flash...OK SW version: VS9803AA_01 Android version: 5.0.2 LAF Version: 1.1 Product ID: PT02S140129003100 IMEI: 990002-59-429866-1 Target operator: VZW Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "VS98039A_05_2OCTOPUS.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing boot...OK Writing tz...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing system...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.5.1 Software version. |
03-16-2017, 18:48 | #4302 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | lg d802 screen lock remove done Code: Welcome to Octoplus/Octopus Box LG Software version 2.5.1 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM202 Selected model: D802 Reading info... Model ID: LG-D802 IMEI: 000000-00-000000-0 Android version: 4.4.2 Battery level: 90% SW Version: D80220b Mode: Emergency Initializing flash...OK SW version: LGD802AT-00-20b-OPEN-CN-MAR-16-2014+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: BS05S130903004345 IMEI: 354198-06-392796-0 Target operator: OPEN Hardware: rev_10 Performed by 2.5.1 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM202 Selected model: D802 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)). Reading info... Model ID: LG-D802 IMEI: 000000-00-000000-0 Android version: 4.4.2 Battery level: 90% SW Version: D80220b Mode: Emergency Initializing flash...OK SW version: LGD802AT-00-20b-OPEN-CN-MAR-16-2014+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: BS05S130903004345 IMEI: 354198-06-392796-0 Target operator: OPEN Hardware: rev_10 Resetting Screen Lock...OK Resetting screen lock successfully completed! Performed by 2.5.1 Software version. |
03-16-2017, 18:50 | #4303 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | ld d851 remove gmail done Code: Welcome to Octoplus/Octopus Box LG Software version 2.5.1 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM41 Selected model: D851 Reading info... Model ID: Unknown IMEI: 014065-00-292817-1 Android version: 4.4.2 Battery level: 83% SW Version: LGD851-V10r-ISR Mode: Emergency Initializing flash...OK SW version: LGD851AT-00-V10r-TMO-US-OCT-22-2014-32G+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: BS03S140822000322 IMEI: 014065-00-292817-1 Target operator: VTR Hardware: rev_10 Performed by 2.5.1 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM41 Selected model: D851 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)). Reading info... Model ID: Unknown IMEI: 014065-00-292817-1 Android version: 4.4.2 Battery level: 84% SW Version: LGD851-V10r-ISR Mode: Emergency Initializing flash...OK SW version: LGD851AT-00-V10r-TMO-US-OCT-22-2014-32G+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: BS03S140822000322 IMEI: 014065-00-292817-1 Target operator: VTR Hardware: rev_10 Resetting Screen Lock...OK Resetting screen lock successfully completed! Performed by 2.5.1 Software version. |
03-16-2017, 18:51 | #4304 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Lg ls980 write flash done Code: Welcome to Octoplus/Octopus Box LG Software version 2.5.1 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM41 Selected model: LS980 Reading info... Model ID: LG-D802 IMEI: 354198-06-189659-7 Android version: 4.4.2 Battery level: 100% SW Version: D80220c Mode: Emergency Initializing flash...OK SW version: LGD802AT-00-20c-OPEN-COM-JUN-25-2014+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: YE03S140221000417 IMEI: 354198-06-189659-7 Target operator: OPEN Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "LS980ZV8_13.51097SPRINT.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing boot...OK Writing tz...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing system...OK Writing cache...OK Writing userdata...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.5.1 Software version. |
The Following User Says Thank You to maanarman For This Useful Post: |
03-16-2017, 18:51 | #4305 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Lg Ls990 Write Flash Done Code: Welcome to Octoplus/Octopus Box LG Software version 2.5.1 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM41 Selected model: LS980 Reading info... Model ID: LG-LS980 IMEI: 990002-52-752780-6 Android version: 4.2.2 Battery level: 17% SW Version: LS980ZV7 Mode: Emergency Initializing flash...OK SW version: LS980ZV7_01 Android version: 4.2.2 LAF Version: 1.0 Product ID: YE03S140401004616 IMEI: 990002-52-752780-6 Target operator: OPEN Hardware: rev_10 Performed by 2.5.1 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM41 Selected model: LS980 Reading info... Model ID: LG-LS980 IMEI: 990002-52-752780-6 Android version: 4.2.2 Battery level: 17% SW Version: LS980ZV7 Mode: Emergency Initializing flash...OK SW version: LS980ZV7_01 Android version: 4.2.2 LAF Version: 1.0 Product ID: YE03S140401004616 IMEI: 990002-52-752780-6 Target operator: OPEN Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "LS980ZV8_13.51097SPRINT.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing boot...OK Writing tz...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing system...OK Writing cache...OK Writing userdata...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.5.1 Software version. |
Post here successfully unlocked a2 phones | 3lsheikh | SETool2 | 10 | 03-04-2011 02:48 |
Successfully Unlock Z240 Phone Freeze | jhepoy_org | UST Pro II | 13 | 12-02-2009 06:03 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 0 | 11-29-2008 14:13 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 2 | 11-26-2008 11:54 |
PB2 - Successfully unlocked LG phones CU/KU ... | DOUHAL | PolarBox 3 | 72 | 11-05-2008 18:21 |
