03-28-2018, 16:20 | #5131 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Great India
Member: 1615596 Status: Offline Sonork: 100.160704? Thanks Meter: 760 | D380 Successfully done. Code: Welcome to Octoplus/Octopus Box LG Software version 2.8.0 Connecting to server support.octoplusbox.com:82...OK Authorizing...OK -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM9 Selected model: D380 Reading info... Could not detect mode! Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM238 Selected model: D380 Reading info... Mode: Emergency Initializing flash...OK SW version: LGD380AT-00-V10e-AME-XX-APR-18-2016+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: CT68S140526002309 IMEI: 354106-06-173793-5 Target operator: GLOBAL Hardware: rev_11 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "D38010d_00.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing rpm...OK Writing tz...OK Writing sdi...OK Writing aboot...OK Writing rpmb...OK Writing tzb...OK Writing abootb...OK Writing persist...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing factory...OK Writing sbl1b...OK Writing cust...OK Writing system...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.8.0 Software version. |
The Following User Says Thank You to .::Gsm-Play::. For This Useful Post: |
03-28-2018, 17:48 | #5132 (permalink) |
No Life Poster Join Date: Sep 2013 Location: KERALA, INDIA
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | LG D850 McAfee lock removed successfully LG D850 McAfee lock removed successfully --------------------------------------------------------------------------- 1. Deactivate Kill switch 2. put to download mode 3. Flash the handset Code: Welcome to Octoplus/Octopus Box LG Software version 2.8.0 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: D850 To perform Kill Switch operation do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint.Failed! Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: D850 To perform Kill Switch operation do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint.OK Sending loader...OK Connecting to server ...OK Initializing device...OK Deactivating Kill Switch...OK Please, reconnect the battery, put the phone in download mode manually and re-flash the phone. Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM506 Selected model: D850 Reading info... Model ID: LG-D850 IMEI: 014065-00-196598-4 Android version: 5.0.1 Battery level: 94% SW Version: D85021r Mode: Emergency Initializing flash...OK SW version: LGD850AT-00-V21r-310-410-AUG-17-2015+0 Android version: 5.0.1 LAF Version: 1.1 Product ID: HD59S140809004298 IMEI: 014065-00-196598-4 Target operator: ATT Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "lgd850at-01-v10f-310-410-oct-15-2014+0.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing tz...OK Writing boot...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing factory...OK Writing system...OK Writing cache...OK Writing userdata...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.8.0 Software version. |
The Following User Says Thank You to technomak For This Useful Post: |
03-29-2018, 07:32 | #5133 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | M250Y Reset FRP Successfully Done Just in Seconds M250Y Reset FRP Successfully Done Just in Seconds: Welcome to Octoplus/Octopus Box LG Software version 2.8.0 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM324 Selected baudrate: 0 Selected model: M250Y Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM712 Mode: Emergency Initializing flash...OK Model ID: LG-M250Y SW version: LGM250YAT-00-V10c-ZAF-XX-JUN-09-2017+0 LAF Version: 1.1 Product ID: VS04S170826004365 IMEI: Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 3000000000000-1 Bluetooth address: 10:F1:F2:A9:AA:A5 Wi-Fi MAC address: 10:F1:F2:2E:B9:68 SPC: 000000 -------------------------------------------------------------------------------- Reset FRP operation for M250Y will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Resetting FRP Lock... Writing loader...OK Writing userdata...OK Formating encrypt...OK Restoring loader...OK Resetting FRP lock successfully completed! Rebooting phone... To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.8.0 Software version. Last edited by Octopus box; 03-29-2018 at 08:17. |
The Following User Says Thank You to alamgarh For This Useful Post: |
03-29-2018, 22:25 | #5134 (permalink) |
No Life Poster Join Date: Jan 2018
Member: 2802156 Status: Offline Thanks Meter: 173 | H918 frp off successfully using july 17 10p fw & test sw Platform: LG Qualcomm Selected port: COM225 Selected model: H918 Reading info... Could not detect mode! Performed by 2.8.0.7 Software version. Connecting to server support.octoplusbox.com:82...OK Authorizing...OK -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM225 Selected model: H918 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Mode: Emergency Initializing flash...OK SW version: LGH918AT-01-V10p-310-260-JUL-17-2017-ARB01+0 Android version: 7.0 LAF Version: 1.1 Product ID: HD60S161124002820 IMEI: XXXXXXXXXXXXXXXXXXXXX Target operator: TMO Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... Resetting FRP lock successfully completed! Performed by 2.8.0.7 Software version. Can safely downgrade to 10P BUT NOT BELOW!! Link to H918 10P firmware DO NOT ATTEMPT TO CROSSFLASH https://drive.google.com/file/d/0B2q...R4OGV1M3M/view USE LG UP WHEN FLASHING TO AVOID BRICK - Use the Update/Upgrade setting Last edited by Octopus box; 03-30-2018 at 05:55. |
The Following User Says Thank You to gsm_service4u For This Useful Post: |
03-30-2018, 04:36 | #5135 (permalink) |
Freak Poster Join Date: Nov 2014 Location: venezuela
Member: 2299654 Status: Offline Thanks Meter: 25 | Unlock Done LG K20 TP260 T-mobile... By Octoplus Searching for USB diagnostic port... Found diagnostic port: COM8 Reading info... IMEI: 355265-xx-xxxxxx-xx Initializing Android Debug Bridge...OK Searching for a phone. Please wait... Selected model: TP260 Detected phone model: LG-TP260 Firmware compiled date: Thu Mar 16 18:09:30 KST 2017 Android version: 7.0 (NRD90U) SIM 1: absent Checking root access... Device is already rooted. ------------------------------------------------------------------------------------------- Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: Authorizing...OK Checking balance...OK Checking operation...OK Your balance: ------------------------------------------------------------------------------------------- Sending device information... Sending exploit...OK Executing exploit...OK Sending data to server... Calculating. Please, wait...OK Unlocking... Phone successfully unlocked! Rebooting device... ------------------------------------------------------------------------------------------- Last edited by Octopus box; 03-30-2018 at 06:04. |
The Following User Says Thank You to loganvp94 For This Useful Post: |
03-30-2018, 06:21 | #5136 (permalink) |
Member: 2299654 Status: Offline Thanks Meter: 25 | Unlock Done.. LG M210 T-Mobile... By Octoplus Searching for USB diagnostic port... Found diagnostic port: COM13 Reading info... IMEI: 353661-xx-xxxxxx-x Initializing Android Debug Bridge...OK Searching for a phone. Please wait... Selected model: M210 Detected phone model: LG-M210 Firmware compiled date: Thu Dec 21 09:33:14 KST 2017 Android version: 7.0 (NRD90U) SIM 1: absent ------------------------------------------------------------------------------------------- Searching for USB diagnostic port... Found diagnostic port: COM13 Reading info... IMEI: 353661-xx-xxxxxx-x Initializing Android Debug Bridge...OK Searching for a phone. Please wait... Selected model: M210 Detected phone model: LG-M210 Firmware compiled date: Thu Dec 21 09:33:14 KST 2017 Android version: 7.0 (NRD90U) SIM 1: absent Checking root access... Device is already rooted. ------------------------------------------------------------------------------------------- Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: xxx Authorizing...OK Checking balance...OK Checking operation...OK Your balance: xxx ------------------------------------------------------------------------------------------- Sending device information... Sending exploit...OK Executing exploit...OK Sending data to server... Calculating. Please, wait...OK Unlocking... Phone successfully unlocked! Rebooting device... Last edited by Octopus box; 03-30-2018 at 06:35. |
03-30-2018, 17:26 | #5137 (permalink) |
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | LG G4 LS991 FRP successfully removed Code: Welcome to Octoplus/Octopus Box LG Software version 2.8.0 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM530 Selected model: D850 Reading info... Model ID: LGLS991 Incompatible model ID! IMEI: 350305-26-000000-4 Android version: 5.1 Battery level: 23% SW Version: LS991ZV6 Mode: Emergency Initializing flash...OK SW version: LGLS991AT-00-ZVB-SPR-US-MAR-14-2016+02_02 Android version: 6.0 LAF Version: 1.1 Product ID: YE07S151104004227 IMEI: 357355-06-641123-9 Target operator: SPR Hardware: rev_10 Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM530 Selected model: LS991 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... IMEI: 350305-26-000000-4 Android version: 5.1 Battery level: 23% SW Version: LS991ZV6 Mode: Emergency Initializing flash...OK SW version: LGLS991AT-00-ZVB-SPR-US-MAR-14-2016+02_02 Android version: 6.0 LAF Version: 1.1 Product ID: YE07S151104004227 IMEI: 357355-06-641123-9 Target operator: SPR Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... Resetting FRP lock successfully completed! Performed by 2.8.0 Software version. Last edited by Octopus box; 03-31-2018 at 11:16. |
03-31-2018, 08:35 | #5138 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | K430TR Repair IMEI successfully done Checking data...OK Platform: LG MTK Selected port: COM25 Selected baudrate: 921600 Selected model: K430TR Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM120 Mode: Emergency Initializing flash...OK Model ID: LG-K430TR SW version: LGK430TRAT-00-V11b-TUR-XX-DEC-21-2017+0 LAF Version: 1.1 Product ID: CH32S160701000348 IMEI: 357xxx-xx-121xxx-x Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI A: 357xxx-xx-xxxxxx-x IMEI B: 350xx5-xx-0x0xx0-1 Bluetooth address: D0:13:FD:9E:F97 Wi-Fi MAC address: 60:E3:AC:F5:AF:E3 -------------------------------------------------------------------------------- Fixing IMEI A... New IMEI A: 35xx81-xx-010xxx-x Reading security area...OK Backup saved to "K430TR_35438xxxxxxxxxx_31-03-2018_10-30-40.EEP" Patching security...OK Writing security area...OK Performed by 2.7.3 Software version. Last edited by Octopus box; 03-31-2018 at 11:18. |
The Following User Says Thank You to orhan5 For This Useful Post: |
03-31-2018, 15:38 | #5139 (permalink) |
No Life Poster Join Date: Oct 2006 Location: india
Member: 368923 Status: Offline Thanks Meter: 85 | lg ls755 successfully unlocked ok thx octopus team ,set is successfully unlocked ,thx a lot. Welcome to Octoplus/Octopus Box LG Software version 2.8.0 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM65 Selected baudrate: 115200 Selected model: LS755 Selected USB connection type Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable) Phone found at port COM449 Mode: Emergency Initializing flash...OK Model ID: LGLS755 SW version: LS755ZVA_03 LAF Version: 1.1 Product ID: CD23S170704002986 IMEI: 359820-0000000000 Target operator: SPR Hardware: rev_11 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 359820-0000000000 Bluetooth address: 88:36:5F:293:BF Wi-Fi MAC address: 88:36:5F:AD:4A:F8 SPC: 130551 -------------------------------------------------------------------------------- Reading Carrier...OK Unlocking...OK Writing Carrier...OK Phone successfully unlocked! Performed by 2.8.0 Software version. |
The Following User Says Thank You to sunnny For This Useful Post: |
03-31-2018, 18:17 | #5140 (permalink) |
Insane Poster Join Date: Mar 2015
Member: 2361634 Status: Offline Thanks Meter: 36 | LG-K373 Unlock successfully done Welcome to Octoplus/Octopus Box LG Software version 2.8.0 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM184 Selected model: K373 Reading info... Model ID: LG-K373 IMEI: 354XXX-XX-XXXXXX-7 Android version: 6.0 Battery level: 79% SW Version: K37320r Mode: Normal Firmware compiled date: Jan 31 2018 Firmware compiled time: 19:00:00 Firmware released date: Feb 12 2018 Firmware released time: 16:52:27 SW Version: MPSS.JO.1.0.c5.7-00034-M8909EAAAANVZM- 1.109812.1.134009.1 IMEI: 354XXX-XX-XXXXXX-7 SPC: 000000 Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM184 Selected model: K373 Reading info... Model ID: LG-K373 IMEI: 354XXX-XX-XXXXXX-7 Android version: 6.0 Battery level: 81% SW Version: K37320r Mode: Normal Firmware compiled date: Jan 31 2018 Firmware compiled time: 19:00:00 Firmware released date: Feb 12 2018 Firmware released time: 16:52:27 SW Version: MPSS.JO.1.0.c5.7-00034-M8909EAAAANVZM- 1.109812.1.134009.1 IMEI: 354XXX-XX-XXXXXX-7 SPC: 000000 Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "K373_354XXXXXXXXXXX7_31-03-2018_11-40-02.qcn" Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "K373_35XXXXXXXXXXX7_31-03-2018_11-45-32.SEC" Writing security area...OK Switching to Normal mode... Found model LGK373AT* ÿh `° at port COM184 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Phone successfullyununlocked! Rebooting phone... Performed by 2.8.0 Software version. Last edited by Octopus box; 04-01-2018 at 16:31. |
The Following User Says Thank You to conroybar2 For This Useful Post: |
04-02-2018, 09:51 | #5141 (permalink) |
Freak Poster Join Date: Jul 2016
Member: 2604648 Status: Offline Thanks Meter: 346 | LG-H900 Unlock successfully dOne Code: Checking data...OK Platform: LG Qualcomm Selected port: COM80 Selected model: H900 Reading info... Model ID: LG-H900 IMEI: 353074-07-231163-0 Android version: 6.0 Battery level: 100% SW Version: H90021z Mode: Normal Firmware compiled date: Dec 25 2016 Firmware compiled time: 23:00:00 Firmware released date: Feb 21 2017 Firmware released time: 10:50:02 SW Version: MPSS.BO.2.5.c10.1-00024-M8992FAAAANAZM- 1.56599.1.82359.1 IMEI: 353074-07-231163-0 SPC: 000000 Unlocking... Skip Read/Write QCN Do you want to create security backup? Writing security area...OK Rebooting phone... Found model LGH900AT: ÿe at port COM80 Phone successfully unlocked! Rebooting phone... Performed by 2.8.0 Software version. |
The Following User Says Thank You to buffer2k11 For This Useful Post: |
04-02-2018, 10:45 | #5142 (permalink) |
No Life Poster Join Date: Feb 2016 Location: GREAT Country Pakistan
Member: 2537939 Status: Offline Sonork: 100.1670350 Thanks Meter: 708 | LG-VS986 FRP Remove successfully done Welcome to Octoplus/Octopus Box LG Software version 2.8.0 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM295 Selected model: VS985 Reading info... Model ID: VS986 Incompatible model ID! IMEI: 357903-06-346058-2 Android version: 6.0 Battery level: 50% SW Version: VS9862AA Mode: Emergency Initializing flash...OK SW version: VS9862AA_08 Android version: 6.0 LAF Version: 1.1 Product ID: YE04S160323003993 IMEI: 357903-06-346058-2 Target operator: VZW Hardware: rev_10 Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM295 Selected model: H810 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: VS986 IMEI: 357903-06-346058-2 Android version: 6.0 Battery level: 50% SW Version: VS9862AA Mode: Emergency Initializing flash...OK SW version: VS9862AA_08 Android version: 6.0 LAF Version: 1.1 Product ID: YE04S160323003993 IMEI: 357903-06-346058-2 Target operator: VZW Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... Resetting FRP lock successfully completed! Performed by 2.8.0 Software version. Last edited by Octopus box; 04-02-2018 at 11:15. |
The Following User Says Thank You to lerner_ For This Useful Post: |
04-02-2018, 13:42 | #5143 (permalink) |
No Life Poster Join Date: Feb 2003 Location: In the dark side ;) Age: 44
Member: 21508 Status: Offline Thanks Meter: 186 | LG M700 Reset FRP successfully done Welcome to Octoplus FRP Tool v.1.2.0 Platform: LG Selected model: M700 Put the phone into EDL mode: 1. Attach testpoint as shown in Help manual; 2. Connect USB cable; 3. Release testpoint after 3-5 seconds. Searching for a phone. Please wait... Connecting... Sending loaders... Loader send successfuly. Reconnecting... Checking request.. Reading partition... Reading info... Brand: lge Model: LG-M700 Device: mh Platform: msm8937 Android version: 7.1.1 Display ID: NMF26X Searching for signatures... Resetting FRP lock.. Rebooting phone Backup saved as LG_M700_02-04-2018_13-35-59.dump file FRP lock is successfully reseted! Performed by 1.2.0 Software version. Last edited by Octopus box; 04-02-2018 at 13:47. |
The Following User Says Thank You to equinoks For This Useful Post: |
04-02-2018, 21:27 | #5144 (permalink) |
Crazy Poster Join Date: Nov 2011
Member: 1695191 Status: Offline Thanks Meter: 42 | LG M210 successfully unlocked by NIMAGA Code: Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: nimaga Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Sending exploit...OK Executing exploit...OK Sending data to server...OK Calculating. Please Wait...OK Unlocking... Phone successfully unlocked! Rebooting phone... Performed by 2.8.0 Software version. Last edited by Octopus box; 04-03-2018 at 05:48. |
The Following User Says Thank You to NIMAGA For This Useful Post: |
04-03-2018, 03:31 | #5145 (permalink) |
Insane Poster Join Date: Sep 2014 Location: UNITED STATES Age: 37
Member: 2266076 Status: Offline Sonork: Propery Thanks Meter: 19 | LG-H910 V20 AT&T imei repair Done 7.0 Checking data...4/2/2018 10:22:54 PM > OK Platform: LG Qualcomm Selected port: COM58 Selected model: H910 Reading info... Model ID: LG-H910 IMEI: 000000-00-000000-0 Android version: 7.0 Battery level: 29% SW Version: 4/2/2018 10:22:56 PM > H91010t Mode: Normal Firmware compiled date: May 22 2017 Firmware compiled time: 05:00:00 Firmware released date: Dec 20 2017 Firmware released time: 12:55:23 SW Version: 4/2/2018 10:22:56 PM > MPSS.TH.2.0.1.c3-00045-M8996FAAAANAZM-1 Bluetooth address: 04:1B:6D:17:47:26 Wi-Fi MAC address: A8:B8:6E:7D:1E:62 SPC: 000000 Fixing IMEI... New IMEI A: 351746-08-XXXXX-6 Finalizing...4/2/2018 10:22:57 PM > OK IMEI successfully fixed! Rebooting phone... Performed by 2.8.0 Software version. |
The Following User Says Thank You to Repaircell For This Useful Post: |
Post here successfully unlocked a2 phones | 3lsheikh | SETool2 | 10 | 03-04-2011 02:48 |
Successfully Unlock Z240 Phone Freeze | jhepoy_org | UST Pro II | 13 | 12-02-2009 06:03 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 0 | 11-29-2008 14:13 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 2 | 11-26-2008 11:54 |
PB2 - Successfully unlocked LG phones CU/KU ... | DOUHAL | PolarBox 3 | 72 | 11-05-2008 18:21 |
