12-31-2018, 15:38 | #5866 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Ukraine Age: 44
Member: 75408 Status: Offline Thanks Meter: 1,190 | LG D724 success reset PIN lock code using "Reset Screen Lock" Code: Checking data...OK Platform: LG Qualcomm Selected port: COM1084 Selected model: D724 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-D724 IMEI: 354705-06-830667-5 Android version: 5.0.2 Battery level: 55% Mode: Emergency Initializing flash...OK Platform: msm8226 SW version: LGD724AT-00-V20b-CIS-XX-AUG-18-2015+0 Android version: 5.0.2 LAF Version: 1.1 Product ID: HD58S141117003961 IMEI: 354705-06-830667-5 Target operator: GLOBAL Hardware: rev_10 Resetting Screen Lock...OK Resetting screen lock successfully completed! Performed by 2.9.1 Software version. Last edited by Octopus box; 01-01-2019 at 08:37. |
The Following User Says Thank You to Dr_Wolodya For This Useful Post: |
12-31-2018, 15:42 | #5867 (permalink) |
No Life Poster Join Date: Jan 2012 Location: YOUR HEART
Member: 1712884 Status: Offline Thanks Meter: 857 | D295 FLASH successfully done Code: Welcome to Octoplus/Octopus Box LG Software version 2.9.1 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM663 Selected model: D295 Reading info... Mode: Emergency Initializing flash...OK Platform: msm8610 SW version: LGD295AT-00-V10c-AME-XX-DEC-23-2014+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: BS08S150302000011 IMEI: xxxxxxxxxxxxxxxx Target operator: GLOBAL Hardware: rev_10 Opening "d29510e_00.kdz"...OK Firmware version: D29510n Firmware model: LG-D295 Firmware type: 0100 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Prepairing firmware...OK Selecting firmware partitions...OK Selected default partitions! Setting options...OK Do you want to format User Data? Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing 1/30 PrimaryGPT_0.bin...OK Writing 2/30 modem_8192.bin...OK Writing 3/30 sbl1_139264.bin...OK Writing 4/30 rpm_141312.bin...OK Writing 5/30 tz_142336.bin...OK Writing 6/30 sdi_143360.bin...OK Writing 7/30 aboot_144384.bin...OK Writing 8/30 rpmb_148480.bin...OK Writing 9/30 tzb_149504.bin...OK Writing 10/30 abootb_150528.bin...OK Writing 11/30 persist_204800.bin...OK Writing 12/30 laf_270336.bin...OK Writing 13/30 boot_319488.bin...OK Writing 14/30 recovery_364544.bin...OK Writing 15/30 factory_475136.bin...OK Writing 16/30 sbl1b_581632.bin...OK Writing 17/30 cust_655360.bin...OK Writing 18/30 system_770048.bin...OK Writing 19/30 system_1036984.bin...OK Writing 20/30 system_1298352.bin...OK Writing 21/30 system_1561272.bin...OK Writing 22/30 system_1822640.bin...OK Writing 23/30 system_2085560.bin...OK Writing 24/30 system_2346928.bin...OK Writing 25/30 system_2609848.bin...OK Writing 26/30 system_2871216.bin...OK Writing 27/30 system_3134136.bin...OK Writing 28/30 system_3395504.bin...OK Writing 29/30 system_3653632.bin...OK Writing 30/30 BackupGPT_7633920.bin...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.9.1 Software version. Last edited by Octopus box; 01-01-2019 at 08:42. |
The Following User Says Thank You to Moh3en.pc For This Useful Post: |
01-01-2019, 07:52 | #5868 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | LG G3 (D855) FLASH successfully done Code: Welcome to Octoplus/Octopus Box LG Software version 2.9.1 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM668 Selected model: D855 Reading info... Model ID: LG-D855 IMEI: XXXXXXXXXXXXXXXX Android version: 5.0 Battery level: 85% Mode: Emergency Initializing flash...OK Platform: msm8974 SW version: LGD855AT-00-V21a-AME-XX-OCT-20-2015-16G+0 Android version: 5.0 LAF Version: 1.1 Product ID: YE01S141118001590 IMEI: XXXXXXXXXXXXXXXXXX Target operator: GLOBAL Hardware: rev_10 Opening "D85530e_00_0927.kdz"...OK Firmware version: LGD855AT-00-V30o-GLOBAL-COM-SEP-27-2016+0 Firmware model: LG-D855 Firmware type: 0100 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Prepairing firmware...OK Selecting firmware partitions...OK Selected default partitions! Setting options...OK Do you want to format User Data? Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing 1/38 PrimaryGPT_0.bin...OK Writing 2/38 modem_32768.bin...OK Writing 3/38 sbl1_163840.bin...OK Writing 4/38 dbi_165888.bin...OK Writing 5/38 aboot_167936.bin...OK Writing 6/38 rpm_172032.bin...OK Writing 7/38 tz_174080.bin...OK Writing 8/38 boot_196608.bin...OK Writing 9/38 persist_229376.bin...OK Writing 10/38 recovery_294912.bin...OK Writing 12/38 laf_393216.bin...OK Writing 13/38 factory_655360.bin...OK Writing 14/38 system_720896.bin...OK Writing 15/38 system_984136.bin...OK Writing 16/38 system_1249088.bin...OK Writing 17/38 system_1508424.bin...OK Writing 18/38 system_1512328.bin...OK Writing 19/38 system_1773376.bin...OK Writing 20/38 system_2032712.bin...OK Writing 21/38 system_2036616.bin...OK Writing 22/38 system_2297664.bin...OK Writing 23/38 system_2557000.bin...OK Writing 24/38 system_2560904.bin...OK Writing 25/38 system_2821952.bin...OK Writing 26/38 system_3081288.bin...OK Writing 27/38 system_3085192.bin...OK Writing 28/38 system_3346240.bin...OK Writing 29/38 system_3608384.bin...OK Writing 30/38 system_3870528.bin...OK Writing 31/38 system_4132672.bin...OK Writing 32/38 system_4394816.bin...OK Writing 33/38 system_4656960.bin...OK Writing 34/38 system_4915200.bin...OK Writing 35/38 system_4918264.bin...OK Writing 36/38 cust_6193152.bin...OK Writing 37/38 cust_6455296.bin...OK Writing 38/38 BackupGPT_30776320.bin...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.9.1 Software version. Last edited by Octopus box; 01-01-2019 at 08:39. |
01-01-2019, 08:02 | #5869 (permalink) |
No Life Poster Join Date: Jul 2014 Location: Nowshera
Member: 2217500 Status: Offline Sonork: 100.1597179 Thanks Meter: 326 | LG-K200F unlock successfully done Checking data...OK Platform: LG Qualcomm Selected port: COM26 Selected model: K200MT Reading info... Model ID: LG-K200F IMEI: 358935-07-069922-3 Android version: 6.0.1 Battery level: 76% SW Version: K20010a Mode: Normal Firmware compiled date: Jun 10 2016 Firmware compiled time: 00:00:00 Firmware released date: Aug 8 2016 Firmware released time: 13:07:42 SW Version: MPSS.JO.1.0.c5.7-00028-M8909EAAAANVZM-1.59782.1 IMEI: 358935-07-069922-3 SPC: 000000 Unlocking... Skip Read/Write QCN Do you want to create security backup? Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Detecting writing method...OK Reading security area...OK Backup saved to "K200MT_358935070699223_01-01-2019_11-58-28.SEC" Switching to Normal mode... Found model LGK200FA: ÿh `š at port COM26 Writing security area...OK Rebooting phone... Found model LGK200FA: ÿh `š at port COM26 Phone successfully unlocked! Rebooting phone... Performed by 2.8.9 Software version. Last edited by Octopus box; 01-01-2019 at 08:37. |
The Following User Says Thank You to ximasim For This Useful Post: |
01-01-2019, 11:03 | #5870 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | LG G3 (D855) FLASH successfully done Code: Welcome to Octoplus/Octopus Box LG Software version 2.9.1 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM674 Selected model: D855 Reading info... Model ID: LG-D855 IMEI: XXXXXXXXXXXXXX Android version: 6.0 Battery level: 86% Mode: Emergency Initializing flash...OK Platform: msm8974 SW version: LGD855AT-00-V30b-GLOBAL-COM-DEC-17-2015-16G+0 Android version: 6.0 LAF Version: 1.1 Product ID: PT03S140626004057 IMEI: XXXXXXXXXXXXXX Target operator: GLOBAL Hardware: rev_10 Opening "D85530e_00_0927.kdz"...OK Firmware version: LGD855AT-00-V30o-GLOBAL-COM-SEP-27-2016+0 Firmware model: LG-D855 Firmware type: 0100 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Prepairing firmware...OK Selecting firmware partitions...OK Selected default partitions! Setting options...OK Do you want to format User Data? Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing 1/38 PrimaryGPT_0.bin...OK Writing 2/38 modem_32768.bin...OK Writing 3/38 sbl1_163840.bin...OK Writing 4/38 dbi_165888.bin...OK Writing 5/38 aboot_167936.bin...OK Writing 6/38 rpm_172032.bin...OK Writing 7/38 tz_174080.bin...OK Writing 8/38 boot_196608.bin...OK Writing 9/38 persist_229376.bin...OK Writing 10/38 recovery_294912.bin...OK Writing 12/38 laf_393216.bin...OK Writing 13/38 factory_655360.bin...OK Writing 14/38 system_720896.bin...OK Writing 15/38 system_984136.bin...OK Writing 16/38 system_1249088.bin...OK Writing 17/38 system_1508424.bin...OK Writing 18/38 system_1512328.bin...OK Writing 19/38 system_1773376.bin...OK Writing 20/38 system_2032712.bin...OK Writing 21/38 system_2036616.bin...OK Writing 22/38 system_2297664.bin...OK Writing 23/38 system_2557000.bin...OK Writing 24/38 system_2560904.bin...OK Writing 25/38 system_2821952.bin...OK Writing 26/38 system_3081288.bin...OK Writing 27/38 system_3085192.bin...OK Writing 28/38 system_3346240.bin...OK Writing 29/38 system_3608384.bin...OK Writing 30/38 system_3870528.bin...OK Writing 31/38 system_4132672.bin...OK Writing 32/38 system_4394816.bin...OK Writing 33/38 system_4656960.bin...OK Writing 34/38 system_4915200.bin...OK Writing 35/38 system_4918264.bin...OK Writing 36/38 cust_6193152.bin...OK Writing 37/38 cust_6455296.bin...OK Writing 38/38 BackupGPT_30776320.bin...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.9.1 Software version. |
01-01-2019, 17:35 | #5871 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | lg k350z FLASH successfully done Code: Checking data...OK Platform: LG MTK Selected port: COM1 Selected baudrate: 921600 Selected model: K350Z Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM686 Mode: Emergency Initializing flash...OK Model ID: LG-K350Z Platform: mt6735 Android version: 6.0 SW version: LGK350ZAT-00-V10a-AME-XX-MAR-23-2016+0 LAF Version: 1.1 Product ID: YE01S160628000565 IMEI: XXXXXXXXXXXXXXXXXXX Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI A: XXXXXXXXXXXXXXXX IMEI B: XXXXXXXXXXXXXXXX Bluetooth address: 60:E3:AC:83:E0:71 Wi-Fi MAC address: 60:E3:AC:E9:84:CB -------------------------------------------------------------------------------- Opening "K350Z10h_00_0124.kdz"...OK Firmware version: LGK350AT-00-V13v-GLOBAL-COM-JAN-24-2018+0 Firmware model: LG-K350 Prepairing firmware... Selecting firmware partitions...OK Selected default partitions!OK Setting options...OK Reading partitions...OK Do you want to format User Data? Formating USERDATA...OK Formating ENCRYPT...OK Writing 1/45 preloader_0.bin...OK Writing 2/45 pgpt_0.bin...OK Writing 3/45 lk_91136.bin...OK Writing 4/45 laf_99328.bin...OK Writing 5/45 boot_157696.bin...OK Writing 6/45 recovery_190464.bin...OK Writing 7/45 logo_256000.bin...OK Writing 8/45 secro_314368.bin...OK Writing 9/45 tee1_343040.bin...OK Writing 10/45 tee2_353280.bin...OK Writing 11/45 cust_451584.bin...OK Writing 12/45 factory_556032.bin...OK Writing 13/45 efuse_711680.bin...OK Writing 14/45 system_786432.bin...OK Writing 15/45 system_1049600.bin...OK Writing 16/45 system_1053696.bin...OK Writing 17/45 system_1313792.bin...OK Writing 18/45 system_1573888.bin...OK Writing 19/45 system_1577984.bin...OK Writing 20/45 system_1838080.bin...OK Writing 21/45 system_2098176.bin...OK Writing 22/45 system_2102272.bin...OK Writing 23/45 system_2362368.bin...OK Writing 24/45 system_2622464.bin...OK Writing 25/45 system_2626560.bin...OK Writing 26/45 system_2886656.bin...OK Writing 27/45 system_3146752.bin...OK Writing 28/45 system_3150848.bin...OK Writing 29/45 system_3410944.bin...OK Writing 30/45 system_3673088.bin...OK Writing 31/45 system_3935232.bin...OK Writing 32/45 system_4197376.bin...OK Writing 33/45 system_4459520.bin...OK Writing 34/45 system_4721664.bin...OK Writing 35/45 system_4983808.bin...OK Writing 36/45 system_5245952.bin...OK Writing 37/45 system_5508096.bin...OK Writing 38/45 system_5770240.bin...OK Writing 39/45 system_6029312.bin...OK Writing 40/45 system_6291456.bin...OK Writing 41/45 system_6294528.bin...OK Writing 42/45 OP_7077888.bin...OK Writing 43/45 OP_7340032.bin...OK Writing 44/45 OP_7602176.bin...OK Formating RCT...OK Finalizing...OK Performed by 2.9.1 Software version. |
01-01-2019, 17:37 | #5872 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | D295 Write Firmware successfully done Code: -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM348 Selected model: D295 Reading info... Model ID: LG-D295 IMEI: XXXXXXXXXXXXXXX Android version: 4.4.2 Battery level: 37% Mode: Emergency Initializing flash...OK Platform: msm8610 SW version: LGD295AT-00-V10e-AME-XX-OCT-27-2015+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: BS06S141119002422 IMEI: XXXXXXXXXXXXXXXX Target operator: GLOBAL Hardware: rev_10 Opening "d29510e_00.kdz"...OK Firmware version: D29510n Firmware model: LG-D295 Firmware type: 0100 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Prepairing firmware...OK Selecting firmware partitions...OK Selected default partitions! Setting options...OK Do you want to format User Data? Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing 1/30 PrimaryGPT_0.bin...OK Writing 2/30 modem_8192.bin...OK Writing 3/30 sbl1_139264.bin...OK Writing 4/30 rpm_141312.bin...OK Writing 5/30 tz_142336.bin...OK Writing 6/30 sdi_143360.bin...OK Writing 7/30 aboot_144384.bin...OK Writing 8/30 rpmb_148480.bin...OK Writing 9/30 tzb_149504.bin...OK Writing 10/30 abootb_150528.bin...OK Writing 11/30 persist_204800.bin...OK Writing 12/30 laf_270336.bin...OK Writing 13/30 boot_319488.bin...OK Writing 14/30 recovery_364544.bin...OK Writing 15/30 factory_475136.bin...OK Writing 16/30 sbl1b_581632.bin...OK Writing 17/30 cust_655360.bin...OK Writing 18/30 system_770048.bin...OK Writing 19/30 system_1036984.bin...OK Writing 20/30 system_1298352.bin...OK Writing 21/30 system_1561272.bin...OK Writing 22/30 system_1822640.bin...OK Writing 23/30 system_2085560.bin...OK Writing 24/30 system_2346928.bin...OK Writing 25/30 system_2609848.bin...OK Writing 26/30 system_2871216.bin...OK Writing 27/30 system_3134136.bin...OK Writing 28/30 system_3395504.bin...OK Writing 29/30 system_3653632.bin...OK Writing 30/30 BackupGPT_7633920.bin...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.9.1 Software version. Last edited by Octopus box; 01-01-2019 at 18:15. |
The Following 2 Users Say Thank You to Moh3en.pc For This Useful Post: |
01-01-2019, 18:10 | #5873 (permalink) | ||
Banned Join Date: Jan 2017 Location: Algeria DZ
Member: 2669781 Status: Offline Thanks Meter: 1,839 | LG-D315_{Screen lock Removal}_Successfully done..''Data Safeguarded'' Full logs of the operation/ Quote:
The Following 2 Users Say Thank You to lyes_albert For This Useful Post: |
01-01-2019, 18:13 | #5874 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | lg D295 FLASH successfully done Code: Welcome to Octoplus/Octopus Box LG Software version 2.9.1 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM694 Selected model: D295 Reading info... Mode: Emergency Initializing flash...OK Platform: msm8610 SW version: LGD295AT-00-V10e-AME-XX-OCT-27-2015+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: BS05S140914001884 IMEI: XXXXXXXXXXXXXXXXXX Target operator: GLOBAL Hardware: rev_10 Opening "d29510e_00.kdz"...OK Firmware version: D29510n Firmware model: LG-D295 Firmware type: 0100 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Prepairing firmware...OK Selecting firmware partitions...OK Selected default partitions! Setting options...OK Do you want to format User Data? Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing 1/30 PrimaryGPT_0.bin...OK Writing 2/30 modem_8192.bin...OK Writing 3/30 sbl1_139264.bin...OK Writing 4/30 rpm_141312.bin...OK Writing 5/30 tz_142336.bin...OK Writing 6/30 sdi_143360.bin...OK Writing 7/30 aboot_144384.bin...OK Writing 8/30 rpmb_148480.bin...OK Writing 9/30 tzb_149504.bin...OK Writing 10/30 abootb_150528.bin...OK Writing 11/30 persist_204800.bin...OK Writing 12/30 laf_270336.bin...OK Writing 13/30 boot_319488.bin...OK Writing 14/30 recovery_364544.bin...OK Writing 15/30 factory_475136.bin...OK Writing 16/30 sbl1b_581632.bin...OK Writing 17/30 cust_655360.bin...OK Writing 18/30 system_770048.bin...OK Writing 19/30 system_1036984.bin...OK Writing 20/30 system_1298352.bin...OK Writing 21/30 system_1561272.bin...OK Writing 22/30 system_1822640.bin...OK Writing 23/30 system_2085560.bin...OK Writing 24/30 system_2346928.bin...OK Writing 25/30 system_2609848.bin...OK Writing 26/30 system_2871216.bin...OK Writing 27/30 system_3134136.bin...OK Writing 28/30 system_3395504.bin...OK Writing 29/30 system_3653632.bin...OK Writing 30/30 BackupGPT_7633920.bin...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.9.1 Software version. |
01-01-2019, 18:22 | #5875 (permalink) | |
Member: 2669781 Status: Offline Thanks Meter: 1,839 | LG-GB130_{Network lock}_Successfully removed.. LG-GB130_{Network lock}_Successfully removed.. Quote:
01-02-2019, 07:05 | #5876 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | D160 FLASH successfully done Code: Welcome to Octoplus/Octopus Box LG Software version 2.9.1 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM50 Selected model: D160 Reading info... Mode: Emergency Initializing flash...OK Platform: msm8610 SW version: LGD160AT-00-V10c-AME-XX-JUL-03-2014+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: BS08S140523001843 IMEI: XXXXXXXXXXXXXXX Target operator: GLOBAL Hardware: rev_10 Opening "D16010c_00.kdz"...OK Firmware version: D16010c Firmware model: LG-D160 Firmware type: 0100 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Prepairing firmware...OK Selecting firmware partitions...OK Selected default partitions! Setting options...OK Do you want to format User Data? Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing 1/30 PrimaryGPT_0.bin...OK Writing 2/30 modem_8192.bin...OK Writing 3/30 sbl1_139264.bin...OK Writing 4/30 rpm_141312.bin...OK Writing 5/30 tz_142336.bin...OK Writing 6/30 sdi_143360.bin...OK Writing 7/30 aboot_144384.bin...OK Writing 8/30 rpmb_148480.bin...OK Writing 9/30 tzb_149504.bin...OK Writing 10/30 abootb_150528.bin...OK Writing 11/30 persist_204800.bin...OK Writing 12/30 laf_270336.bin...OK Writing 13/30 boot_319488.bin...OK Writing 14/30 recovery_364544.bin...OK Writing 15/30 factory_475136.bin...OK Writing 16/30 sbl1b_581632.bin...OK Writing 17/30 cust_589824.bin...OK Writing 18/30 system_704512.bin...OK Writing 19/30 system_971400.bin...OK Writing 20/30 system_1232768.bin...OK Writing 21/30 system_1495688.bin...OK Writing 22/30 system_1757056.bin...OK Writing 23/30 system_2019976.bin...OK Writing 24/30 system_2281344.bin...OK Writing 25/30 system_2544264.bin...OK Writing 26/30 system_2805632.bin...OK Writing 27/30 system_3068552.bin...OK Writing 28/30 system_3329920.bin...OK Writing 29/30 system_3588096.bin...OK Writing 30/30 BackupGPT_7633920.bin...OK Reading partitions...OK Formating RCT...OK Formating MPT...Failed! Finalizing...OK Writing firmware done! Performed by 2.9.1 Software version. Last edited by Octopus box; 01-02-2019 at 07:40. |
01-02-2019, 14:46 | #5877 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | D295 FLASH successfully done Code: Welcome to Octoplus/Octopus Box LG Software version 2.9.1 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM702 Selected model: D295 Reading info... Mode: Emergency Initializing flash...OK Platform: msm8610 SW version: LGD295AT-00-V10e-AME-XX-OCT-27-2015+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: BS06S141130000065 IMEI: XXXXXXXXXXXXXXX Target operator: GLOBAL Hardware: rev_10 Opening "d29510e_00.kdz"...OK Firmware version: D29510n Firmware model: LG-D295 Firmware type: 0100 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Prepairing firmware...OK Selecting firmware partitions...OK Selected default partitions! Setting options...OK Do you want to format User Data? Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing 1/30 PrimaryGPT_0.bin...OK Writing 2/30 modem_8192.bin...OK Writing 3/30 sbl1_139264.bin...OK Writing 4/30 rpm_141312.bin...OK Writing 5/30 tz_142336.bin...OK Writing 6/30 sdi_143360.bin...OK Writing 7/30 aboot_144384.bin...OK Writing 8/30 rpmb_148480.bin...OK Writing 9/30 tzb_149504.bin...OK Writing 10/30 abootb_150528.bin...OK Writing 11/30 persist_204800.bin...OK Writing 12/30 laf_270336.bin...OK Writing 13/30 boot_319488.bin...OK Writing 14/30 recovery_364544.bin...OK Writing 15/30 factory_475136.bin...OK Writing 16/30 sbl1b_581632.bin...OK Writing 17/30 cust_655360.bin...OK Writing 18/30 system_770048.bin...OK Writing 19/30 system_1036984.bin...OK Writing 20/30 system_1298352.bin...OK Writing 21/30 system_1561272.bin...OK Writing 22/30 system_1822640.bin...OK Writing 23/30 system_2085560.bin...OK Writing 24/30 system_2346928.bin...OK Writing 25/30 system_2609848.bin...OK Writing 26/30 system_2871216.bin...OK Writing 27/30 system_3134136.bin...OK Writing 28/30 system_3395504.bin...OK Writing 29/30 system_3653632.bin...OK Writing 30/30 BackupGPT_7633920.bin...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.9.1 Software version. Last edited by Octopus box; 01-02-2019 at 14:53. |
01-03-2019, 05:32 | #5878 (permalink) |
No Life Poster Join Date: Mar 2016 Location: Puerto Rico
Member: 2549748 Status: Offline Thanks Meter: 212 | LS998 (v22a) successfully unlocked by special firmware Code: Welcome to Octoplus/Octopus Box LG Software version 2.9.1 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM72 Selected model: LS998 Reading info... IMEI: 352457-09-180593-3 Android version: 8.0.0 Battery level: 65% Mode: Emergency Initializing flash...OK Platform: msm8998 SW version: LS99822a_01 Android version: 8.0.0 LAF Version: 1.1 Product ID: PT03S180526004614 IMEI: 352457-09-180593-3 Target operator: SPR Hardware: rev_10 Performed by 2.9.1 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM72 Selected model: LS998 Reading info... IMEI: 352457-09-180593-3 Android version: 8.0.0 Battery level: 66% Mode: Emergency Initializing flash...OK Platform: msm8998 SW version: LS99822a_01 Android version: 8.0.0 LAF Version: 1.1 Product ID: PT03S180526004614 IMEI: 352457-09-180593-3 Target operator: SPR Hardware: rev_10 Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Opening "LS998V20a_to_US998V10d_for_unlock.oct"...OK Selecting firmware partitions...OK Selected default partitions! Setting options...OK Do you want to format User Data? Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing PrimaryGPT...OK Writing laf...OK Writing lafbak...OK Writing factory...OK Writing persist...OK Writing system...OK Writing BackupGPT...OK Writing PrimaryGPT...OK Writing xbl...OK Writing BackupGPT...OK Writing PrimaryGPT...OK Writing xbl2...OK Writing BackupGPT...OK Writing PrimaryGPT...OK Writing BackupGPT...OK Writing PrimaryGPT...OK Writing boot...OK Writing recovery...OK Writing recoverybak...OK Writing tz...OK Writing tzbak...OK Writing raw_resources...OK Writing raw_resourcesbak...OK Writing rpm...OK Writing rpmbak...OK Writing hyp...OK Writing hypbak...OK Writing pmic...OK Writing pmicbak...OK Writing devcfg...OK Writing devcfgbak...OK Writing modem...OK Writing sec...OK Writing keymaster...OK Writing keymasterbak...OK Writing cmnlib...OK Writing cmnlibbak...OK Writing cmnlib64...OK Writing cmnlib64bak...OK Writing apdp...OK Writing msadp...OK Writing abl...OK Writing ablbak...OK Writing logfs...OK Writing storsec...OK Writing storsecbak...OK Writing BackupGPT...OK Writing PrimaryGPT...OK Writing BackupGPT...OK Writing PrimaryGPT...OK Writing BackupGPT...OK Finalizing...OK Writing firmware done! Performed by 2.9.1 Software version. Last edited by Octopus box; 01-03-2019 at 05:55. |
The Following User Says Thank You to reyxito For This Useful Post: |
01-03-2019, 10:44 | #5879 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | H960A Reset FRP successfully done Code: Welcome to Octoplus/Octopus Box LG Software version 2.9.1 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM708 Selected model: H960A Reading info... Mode: Emergency Initializing flash...OK Platform: msm8992 SW version: LGH960AAT-00-V30a-AME-XX-JUL-26-2017+0 Android version: 7.0 LAF Version: 1.1 Product ID: YE01S160211003346 IMEI: xxxxxxxxxxxxxxxxxx Target operator: GLOBAL Hardware: rev_10 Performed by 2.9.1 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM708 Selected model: H960A Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-H960A IMEI: 356210-07-058674-3 Android version: 6.0 Battery level: 91% Mode: Emergency Initializing flash...OK Platform: msm8992 SW version: LGH960AAT-00-V30a-AME-XX-JUL-26-2017+0 Android version: 7.0 LAF Version: 1.1 Product ID: YE01S160211003346 IMEI: xxxxxxxxxxxxxxxxx Target operator: GLOBAL Hardware: rev_10 Reset FRP operation for H960A will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method...OK Resetting FRP Lock... Writing loader... Step 1... Step 2... Step 3... Step 4... Step 5... Step 6... Step 7... Step 8... Step 9... Step 10...OK Writing userdata...OK Formating encrypt...OK Restoring loader...OK Resetting FRP lock successfully completed! Rebooting phone... To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.9.1 Software version. Last edited by Octopus box; 01-03-2019 at 10:51. |
01-03-2019, 14:27 | #5880 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | LG-K520K Flash & FRP Reset Done Code: Welcome to Octoplus/Octopus Box LG Software version 2.8.9.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1242 Selected model: K520K Reading info... Model ID: LG-K520K IMEI: 358388-07-023057-5 Android version: 6.0.1 Battery level: 7% SW Version: K52010a Mode: Emergency Initializing flash...OK Platform: msm8916 SW version: LGK520KAT-00-V10a-ZAF-XX-MAR-11-2016+0 Android version: 7.0 LAF Version: 1.1 Product ID: CT68S160530001280 IMEI: 358388-07-023057-5 Target operator: GLOBAL Hardware: rev_10 Opening "K52010c_00_1014_Vodafone_6.0.1.kdz"...OK Firmware version: K52010v Firmware model: LG-K520 Firmware type: 0100 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Prepairing firmware...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing 1/56 PrimaryGPT_0.bin...OK Writing 2/56 sbl1_1024.bin...OK Writing 3/56 tz_2048.bin...OK Writing 4/56 hyp_3072.bin...OK Writing 5/56 rpm_4096.bin...OK Writing 6/56 aboot_5120.bin...OK Writing 7/56 sbl1bak_12288.bin...OK Writing 8/56 tzbak_13312.bin...OK Writing 9/56 hypbak_14336.bin...OK Writing 10/56 rpmbak_15360.bin...OK Writing 11/56 abootbak_16384.bin...OK Writing 12/56 persist_53248.bin...OK Writing 13/56 laf_93184.bin...OK Writing 14/56 boot_142336.bin...OK Writing 15/56 recovery_191488.bin...OK Writing 16/56 recoverybak_240640.bin...OK Writing 17/56 sec_295936.bin...OK Writing 19/56 factory_316416.bin...OK Writing 20/56 modem_513024.bin...OK Writing 21/56 cust_688128.bin...OK Writing 22/56 system_892928.bin...OK Writing 23/56 system_1156616.bin...OK Writing 24/56 system_1160632.bin...OK Writing 25/56 system_1421232.bin...OK Writing 26/56 system_1680904.bin...OK Writing 27/56 system_1684920.bin...OK Writing 28/56 system_1945520.bin...OK Writing 29/56 system_2205192.bin...OK Writing 30/56 system_2209208.bin...OK Writing 31/56 system_2469808.bin...OK Writing 32/56 system_2729480.bin...OK Writing 33/56 system_2733496.bin...OK Writing 34/56 system_2994096.bin...OK Writing 35/56 system_3253768.bin...OK Writing 36/56 system_3257784.bin...OK Writing 37/56 system_3518384.bin...OK Writing 38/56 system_3780528.bin...OK Writing 39/56 system_4042672.bin...OK Writing 40/56 system_4304816.bin...OK Writing 41/56 system_4566960.bin...OK Writing 42/56 system_4829104.bin...OK Writing 43/56 system_5091248.bin...OK Writing 44/56 system_5353392.bin...OK Writing 45/56 system_5615536.bin...OK Writing 46/56 system_5877680.bin...OK Writing 47/56 system_6139824.bin...OK Writing 48/56 system_6401968.bin...OK Writing 49/56 system_6660096.bin...OK Writing 50/56 system_6922240.bin...OK Writing 51/56 system_6925304.bin...OK Writing 52/56 OP_7651328.bin...OK Writing 53/56 OP_7913472.bin...OK Writing 54/56 OP_8175616.bin...OK Writing 55/56 OP_8178832.bin...OK Writing 56/56 BackupGPT_30534656.bin...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.8.9.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1242 Selected model: K520K Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-K520K IMEI: 358388-07-023057-5 Android version: 6.0.1 Battery level: 7% SW Version: K52010c Mode: Emergency Initializing flash...OK Platform: msm8916 SW version: LGK520KAT-00-V10v-GLOBAL-COM-OCT-14-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CT68S160530001280 IMEI: 358388-07-023057-5 Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method...OK Resetting FRP Lock...OK Resetting FRP lock successfully completed! If the phone hang on logo or is restarting afetr performing the operation, please re-flash it using the same or higher version of firmware Performed by 2.8.9.8 Software version. Last edited by Octopus box; 01-03-2019 at 14:40. |
The Following User Says Thank You to ..::GMSR::.. For This Useful Post: |
Post here successfully unlocked a2 phones | 3lsheikh | SETool2 | 10 | 03-04-2011 02:48 |
Successfully Unlock Z240 Phone Freeze | jhepoy_org | UST Pro II | 13 | 12-02-2009 06:03 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 0 | 11-29-2008 14:13 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 2 | 11-26-2008 11:54 |
PB2 - Successfully unlocked LG phones CU/KU ... | DOUHAL | PolarBox 3 | 72 | 11-05-2008 18:21 |
