GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
02-22-2019, 19:03 | #1 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2283503 Status: Offline Thanks Meter: 0 | How to solve the problem of Huawei B315s-22 that refuses to connect to Telnet port 23 Dear friends, I have a problem and I hope you will help me to solve it if possible. I have a Huawei Modem Router B315s-22 Model: Huawei B315s-22 Firmware: 21.313.03.00.1006 Web UI Dashboard: 17.100.09.00.03 ipconfig: ======== IPv4 address: 192.168.8.100 Subnet Mask: 255.255.255.0 Default gateway: 192.168.8. The problem is that the modem router does not support activation of telnet telnet calls through the tool E5186 Toolbox 0.9 And through the Ethernet LAN connection. The tool E5186 Toolbox 0.9 is not able to activate telnet and change the settings of the (api / device / mode) API control => API configuration => api / device / mode. The default status and settings of api / device / mode This is: API control => API configuration => api / device / Get mode The answer is this: ==================== <Error> <Code> 100002 </ code> <Message> </ message> </ Error> ====================== and when I try to activate telnet and copy this telnet activation ==================== <Request> <Mode> 2 </ style> <Request /> ==================== In the Write to API area, then I click on API Write directly to He refuses to accept and tells me ============================= <Request> <Mode> 2 </ style> <Request /> Is not valid XML data! ============================= I do not know the meaning of this answer the same problem with the use of PuTTY tool It can not access IP 192.168.8.1 Telnet Port 23 the Telnet Client and Telnet Server they all install installed under My 32-bit Windows 7 Telnet and Activate using the Command Prompt. Despite all this and nothing works Thank you in advance and I'm waiting for your answer |
02-23-2019, 04:21 | #2 (permalink) | |
Freak Poster Join Date: Oct 2018 Location: GSMHOSTING
Member: 2869280 Status: Offline Thanks Meter: 112 | Quote:
update this firmware on router webui option local update after update done you can unlock a modem or use telnet also for use telnet you can use putty software https://drive.google.com/file/d/1og6...ew?usp=sharing | |
