04-08-2019, 08:01 | #1 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,262 | NCK Dongle / Pro Android MTK Module v2.5.9.9 Update Released - [08/04/2019] Qmobile QMobile S9 - Read Info/Simlock/Remove FRP/Factory Reset/Read&Restore NVRam/Flash Firmware. Nokia Nokia 1 - Read Info/Remove FRP/Factory Reset/Read&Restore NVRam/Flash Firmware. Alcatel 8030Y - Read Info/Simlock/Remove FRP/Factory Reset/Read&Restore NVRam/Flash Firmware. Tecno RA6 - Read Info/Simlock/Remove FRP/Factory Reset/Read&Restore NVRam/Flash Firmware. RA6S - Read Info/Simlock/Remove FRP/Factory Reset/Read&Restore NVRam/Flash Firmware. LA7 - Read Info/Simlock/Remove FRP/Factory Reset/Read&Restore NVRam/Flash Firmware. F2 LTE - Read Info/Simlock/Remove FRP/Factory Reset/Read&Restore NVRam/Flash Firmware. F4 - Read Info/Simlock/Remove FRP/Factory Reset/Read&Restore NVRam/Flash Firmware. Camon 11 - Read Info/Simlock/Remove FRP/Factory Reset/Read&Restore NVRam/Flash Firmware. Camon IN2 - Read Info/Simlock/Remove FRP/Factory Reset/Read&Restore NVRam/Flash Firmware. Camon i Ace - Read Info/Simlock/Remove FRP/Factory Reset/Read&Restore NVRam/Flash Firmware. Camon i Sky 2 - Read Info/Simlock/Remove FRP/Factory Reset/Read&Restore NVRam/Flash Firmware. Pop 1S Pro - Read Info/Simlock/Remove FRP/Factory Reset/Read&Restore NVRam/Flash Firmware. -- Added in support RA6 Modem Database, users can use this database to Unlock simlock or Repair IMEI. Acer Iconia One 10(B3-A40) - Read Info/Simlock/Remove FRP/Factory Reset/Read&Restore NVRam/Flash Firmware. Iconia One 10(B3-A30) - Read Info/Simlock/Remove FRP/Factory Reset/Read&Restore NVRam/Flash Firmware. Vivo Y83 Pro - Read Info/Simlock/Remove FRP/Factory Reset/Read&Restore NVRam/Flash Firmware. Y85 - Read Info/Simlock/Remove FRP/Factory Reset/Read&Restore NVRam/Flash Firmware. Y81 - Read Info/Simlock/Remove FRP/Factory Reset/Read&Restore NVRam/Flash Firmware. Y91C - Read Info/Simlock/Remove FRP/Factory Reset/Read&Restore NVRam/Flash Firmware. Added In support Y91C Modem Database, users can use this database to Unlock Simlock or Repair IMEI. Lava Lava Z50 - Read Info/Simlock/Remove FRP/Factory Reset/Read&Restore NVRam/Flash Firmware. Lava Z60 - Read Info/Simlock/Remove FRP/Factory Reset/Read&Restore NVRam/Flash Firmware. Lava Z60E - Read Info/Simlock/Remove FRP/Factory Reset/Read&Restore NVRam/Flash Firmware. Official Website: NCK DONGLE Download from Support Access Software to Access Download Area Link: http://nckdongle.com/DownloadSetup/s...access_New.rar |
The Following 40 Users Say Thank You to Fast Unlocking For This Useful Post: |
04-08-2019, 09:26 | #5 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | This forum have great feature called Search When you will have some free time, try to read this 2 threads. http://forum.gsmhosting.com/vbb/f826...-done-2576948/ http://forum.gsmhosting.com/vbb/f805...olved-2532326/ And...to use database, need to push button "load database" I'am know, button name "load database" can be complicate to understand.....but give a try, you will see after. Is really easy to use. |
The Following 4 Users Say Thank You to orbita For This Useful Post: |
04-08-2019, 12:18 | #9 (permalink) |
Freak Poster Join Date: Feb 2007 Location: thailand
Member: 451521 Status: Offline Thanks Meter: 317 | Y91c Not work Exe version: NCKDongle AndroidMTK 2.5.9.9 Selected model: Vivo Y91C Action: Unlock Reinsert phone battery. Battery must be charged. Keep VOL+ button untill inserting USB cable. Detected : MediaTek PreLoader USB VCOM_V1632 (Android) (COM153) Boot mode: Preloader Phone detected...Please wait BBCHIP: 6765 0 ca00 Using Algo 1. Helio MT6765 phone detected, swithing to helio api Loading Custom Preloader Helio enabled DRAM in First Da: TRUE BBCHIP MT6765 [1]Storage EMMC EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010051443633 : 000000000000000000 EMMC UA SIZE: 0x747c00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x749400000 [29.145 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM158) Phone have OTP partition. [3][Missing imei entry]Warning, nvram posible damaged!!. Reading security, wait... [0]Unlock is not supported for this model [helio]Wait untill phone will start charging. [0]All done. |
04-08-2019, 12:22 | #10 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Sure will not work, you making things wrong. You must dump phone database[exe have this function] and after make unlock using database. I'am answered above to user with RA6 , try to read this threads also. For this cpu unlock is only supported with database, in flash mode it not added and not supported. MT6739, MT6763, MT6765, MT6769 only by this metod can be performed simunlock. p.s. If users will share dumped databases we can add this in support. |
The Following 3 Users Say Thank You to orbita For This Useful Post: |
04-08-2019, 12:43 | #11 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Databases for vivo MT6765_vivo_1814_database.db MT6765_vivo_1820_database.db I'am uploaded in support, so can be downloaded directly. |
