GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
11-30-2016, 08:40 | #18 (permalink) | |
Major Poster Join Date: Jul 2013 Location: Nigeria
Member: 1970813 Status: Offline Sonork: kofi Thanks Meter: 24 | Quote:
The Following User Says Thank You to sech444 For This Useful Post: |
11-30-2016, 19:39 | #19 (permalink) |
Junior Member Join Date: Sep 2007
Member: 592519 Status: Offline Thanks Meter: 0 | it not working Thanks for Ur reply bro, Actually I tried that file earlier from ( and tried 2 more times after seeing Ur post) Ur previous post that usbloader does not suit to e5573cs 609 all the procedure goes smoothly and successfully finally browser doesn't open. So kindly post the right file soon please. |
12-02-2016, 06:24 | #20 (permalink) |
Member: 1970813 Status: Offline Sonork: kofi Thanks Meter: 24 | If ur web browse is not showing ur user interface This is what u need to do, after the bot shot, u have to flash ur e5573cs with E5573cs_Update_21.318.99.03.00 then u use the Update_WEBUI_17.100.15.01.356_MRE5 then u use E5573cs_Update_21.318.03.00.00 as the last and all ths files are there in the link above. |
12-06-2016, 10:15 | #21 (permalink) |
Junior Member Join Date: Dec 2016
Member: 2657317 Status: Offline Thanks Meter: 0 | Hello, I followed your steps but when trying to install the first firmware, it get stock and gives error 16 and error 13 I dont know if theres a way i could get back the stock firmware as the modem is stock now in the flashing stage i.e after installing the bin file and and com ports. Both lights on the modem keeps flashing and the mifi doesnt work anymore, its stock on download mode. please ill like to know a solution to the problem thanks. |
12-06-2016, 14:43 | #22 (permalink) |
Insane Poster Join Date: Jul 2016
Member: 2599387 Status: Offline Thanks Meter: 5 | e5573cs-322 is my dongle. Hi.. after step #18 the update successfull... modem reboots and shows 3 ports in the device manager... Dc-unlocker connects and shows it unlocked. But dont goto homepage...for change apn etc.. Neither works the 192.168.8.1 Do i have to flash to latest firmware after step 18. ? which ver. ? if yes.. link please. Update_WEBUI_17.100.15.01.356_MRE5 is for e5573-609 Regards.. Sorry for my bad english Last edited by s4sajii1; 12-06-2016 at 14:53. |
12-08-2016, 11:26 | #26 (permalink) | |
