01-08-2016, 15:46 | #1 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2512715 Status: Offline Thanks Meter: 0 | Problem with R-sim 10+ in Japan AU no incoming calls I have a problem with R-sim 10+ I have an iphone 6 ios 9.2 carrier locked to Japan Au. I put in TSMI Mode and the selected first option (because with second option, no signal). I can call with out problem , but i canīt get incoming calls or sms. I also check not disturbing option and all is ok. ŋCan anyone hep me to solve? Thank you very much. Best regards. |
02-10-2016, 05:02 | #5 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2529379 Status: Offline Thanks Meter: 0 | I am using 5S locked to Softbank and had the same problem. Finally I solve it by selecting network manually. If you insert NTT Docomo SIM or MVNO SIM using Docomo network, turn off 4G first, then turn off Automatic and select NTT DOCOMO in Network Selection. After that you can turn on 4G. |
12-12-2016, 12:43 | #6 (permalink) |
Junior Member Join Date: Dec 2016
Member: 2659907 Status: Offline Thanks Meter: 0 | Hi, I am also facing same issue, outgoing is working fine but no incoming. Rsim 10+ iPhone 6 JP AU KDDI, iOS 10.1.1 If anyone found any solution please let me know. Thanks, Gaurav |
