Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 01-08-2016, 15:46   #1 (permalink)
Member: 2512715
Problem with R-sim 10+ in Japan AU no incoming calls
Hi guys!
I have a problem with R-sim 10+
I have an iphone 6 ios 9.2 carrier locked to Japan Au. I put in TSMI Mode and the selected first option (because with second option, no signal).
I can call with out problem , but i canīt get incoming calls or sms. I also check not disturbing option and all is ok.
ŋCan anyone hep me to solve?
Thank you very much.
Best regards.
Old 01-08-2016, 16:07   #2 (permalink)
Faheem Anjum's Avatar
Member: 399832
Sonork: Faheem Anjum
Thanks Meter: 24,310
Not test on au but in docomo working without any problem
Old 01-08-2016, 16:28   #3 (permalink)
Member: 2512715
you selected tsmi model and first option also?
Donīt know why is not working ok with japan au. I am using orange 4g sim card.
Thank you!
Old 01-28-2016, 01:10   #4 (permalink)
Member: 2521266
Hi ,
Even I am facing the same issue .
Rsim 10+ , iPhone 6 JP AU KDDI , iOS 9.0
Outgoing calls ok . But incoming calls not working .
Please help in better solutions
Old 02-10-2016, 05:02   #5 (permalink)
Member: 2529379
I am using 5S locked to Softbank and had the same problem.
Finally I solve it by selecting network manually.
If you insert NTT Docomo SIM or MVNO SIM using Docomo network, turn off 4G first, then turn off Automatic and select NTT DOCOMO in Network Selection. After that you can turn on 4G.
Old 12-12-2016, 12:43   #6 (permalink)
Member: 2659907
Hi,
I am also facing same issue, outgoing is working fine but no incoming.
Rsim 10+ iPhone 6 JP AU KDDI, iOS 10.1.1
If anyone found any solution please let me know.
Thanks,
Gaurav
Page generated in 0.13241 seconds with 8 queries
