05-11-2013, 08:09 | #3 (permalink) |
Freak Poster Join Date: Jan 2013 Location: NaGarCoil Age: 32
Member: 1869297 Status: Offline Thanks Meter: 44 | Karbonn A4 Hard Reset 100% Working Solution Press Volume Down Button & Power Button for 5 Seconds. Then It Shows Factory Test Menu Functions. In Here Select the "Clear Flash" Option. U r Done. Now Phone Will be Automaticaly Restarted.Now the Phone is Ready to Use. 100% Tested Solution By Me..... |
The Following User Says Thank You to jegan6300 For This Useful Post: |
08-11-2013, 13:15 | #7 (permalink) |
Freak Poster Join Date: Dec 2011 Location: kathmandu
Member: 1708926 Status: Offline Sonork: 9851036826 Thanks Meter: 22 | Karbonn A4 Hard Reset 100% Working Solution Press Volume Down Button & Power Button for 5 Seconds. Then It Shows Factory Test Menu Functions. In Here Select the "Clear Flash" Option. U r Done. Now Phone Will be Automaticaly Restarted. Now the Phone is Ready to Use. 100% Tested |
The Following User Says Thank You to newstarmobile For This Useful Post: |
09-22-2013, 06:37 | #8 (permalink) |
Junior Member Join Date: May 2009
Member: 1036150 Status: Offline Thanks Meter: 10 | karbonn A4+ hard reset 100000000% 1) pres volume - & power key than select Clear Flash 2) pres volume + & power key Then It Shows Android logo then pres volume - & power key select wipe data/factory reset |
10-17-2013, 23:08 | #9 (permalink) |
Freak Poster Join Date: Jun 2013
Member: 1953087 Status: Offline Thanks Meter: 10 | Press volup & home tuch key & then press power, appear triangle or android logo then press left side call key, then appear 4 option press reset or factory setting and reboot mobile your mobile is ok |
10-18-2013, 09:50 | #10 (permalink) |
No Life Poster Join Date: Mar 2013 Location: NewYork Age: 32
Member: 1900437 Status: Offline Thanks Meter: 113 | Firslty press the volume up key and home key and the power key until an Android logo appears the using the volume up and down key navigate to factory rest and then reboot it that's it your Karbon A4 on working condition !!! |
11-27-2013, 04:21 | #11 (permalink) |
Crazy Poster Join Date: May 2013 Location: DEEP SINGH WALA PUNJAB INDIA Age: 32
Member: 1935857 Status: Offline Thanks Meter: 9 | Karboon a4+ pattern unlock FIRST pRESS vOL UP BOTTON aND pOWER oN OPEN FACTORY MENU THEN SELECT WIPE DATA ANG OK OPEN NEXT MENU SELECT DELETE ALL USER DATA AND REBOOT PHONE AFTER START PHONE PATTERN UNLOCK DONE FINAL SOLUTION TESTED Last edited by ..::Nokian CareŽ::..; 11-29-2013 at 15:30. Reason: no personal contact details.. |
04-24-2014, 06:16 | #12 (permalink) | |
No Life Poster Join Date: Dec 2010 Location: [pujab haryana]
Member: 1481018 Status: Offline Sonork: 100.165460 Thanks Meter: 222 | Quote:
10-29-2014, 10:29 | #13 (permalink) |
No Life Poster Join Date: Dec 2007 Location: DHARAMPUR<GUJRAT>INDIA
Member: 646646 Status: Offline Sonork: 100.1664464 Thanks Meter: 240 | karbonn A4+ hard reset 100000000% 1) pres volume - & power key than select Clear Flash 2) pres volume + & power key Then It Shows Android logo then pres volume - & power key select wipe data/factory reset |
