Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Karbonn
Old 04-09-2013, 10:11   #1 (permalink)
Member: 740188
How To Hard Reset Karbonn A4 [Solution Available Inside]
a4 show patten lock plse help me?
Old 04-21-2013, 08:35   #2 (permalink)
Member: 683989
Thanks Meter: 3
vol up power after home
Old 05-11-2013, 08:09   #3 (permalink)
jegan6300's Avatar
Member: 1869297
Thanks Meter: 44
Karbonn A4 Hard Reset 100% Working Solution
Press Volume Down Button & Power Button for 5 Seconds. Then It Shows Factory Test Menu Functions. In Here Select the "Clear Flash" Option. U r Done. Now Phone Will be Automaticaly Restarted.Now the Phone is Ready to Use. 100% Tested Solution By Me.....
The Following User Says Thank You to jegan6300 For This Useful Post:
Old 05-11-2013, 10:38   #4 (permalink)
sunil1670's Avatar
Member: 1849215
Thanks Meter: 136
use android multi tools by azimbahar
Old 05-30-2013, 05:57   #5 (permalink)
Member: 1881601
Thanks Meter: 17
Thanks are you sure clrear flash sir
Old 07-02-2013, 11:47   #6 (permalink)
jegan6300's Avatar
Member: 1869297
Thanks Meter: 44
Yaa Click the Clear Flash Option.....
100% Working
Old 08-11-2013, 13:15   #7 (permalink)
newstarmobile's Avatar
Member: 1708926
Sonork: 9851036826
Thanks Meter: 22
The Following User Says Thank You to newstarmobile For This Useful Post:
Old 09-22-2013, 06:37   #8 (permalink)
Member: 1036150
Thanks Meter: 10
karbonn A4+ hard reset 100000000%
1) pres volume - & power key than select Clear Flash
2) pres volume + & power key Then It Shows Android logo then pres volume - & power key select wipe data/factory reset
Old 10-17-2013, 23:08   #9 (permalink)
Member: 1953087
Thanks Meter: 10
Press volup & home
tuch key & then press
power, appear
triangle or android
logo then press left
side call key, then
appear 4 option press
reset or factory
setting and reboot
mobile
your mobile is ok
Old 10-18-2013, 09:50   #10 (permalink)
Member: 1900437
Thanks Meter: 113
Firslty press the volume up key and home key and the power key until an Android logo appears the using the volume up and down key navigate to factory rest and then reboot it that's it your Karbon A4 on working condition !!!
Old 11-27-2013, 04:21   #11 (permalink)
Crazy Poster
Member: 1935857
Thanks Meter: 9
Karboon a4+ pattern unlock
FIRST pRESS vOL UP BOTTON aND pOWER oN OPEN FACTORY MENU THEN SELECT WIPE DATA ANG OK OPEN NEXT MENU SELECT DELETE ALL USER DATA AND REBOOT PHONE AFTER START PHONE PATTERN UNLOCK DONE FINAL SOLUTION TESTED
Last edited by ..::Nokian CareŽ::..; 11-29-2013 at 15:30. Reason: no personal contact details..
Old 04-24-2014, 06:16   #12 (permalink)
Sukh007's Avatar
Member: 1481018
Sonork: 100.165460
Thanks Meter: 222
This is 100% ok solution
Old 10-29-2014, 10:29   #13 (permalink)
him82's Avatar
Member: 646646
Sonork: 100.1664464
Thanks Meter: 240
Page generated in 0.28032 seconds with 8 queries
