Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Karbonn
Old 06-14-2014, 12:41   #1 (permalink)
Member: 873465
Thanks Meter: 7
Karbonn A51 Pattern lock / hard reset solution
How to remove karbonn A51 Pattren lock
Old 06-14-2014, 12:46   #2 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
1. Charge the battery 100%.
2. Turn off the phone.
3. Turn ON the device by pressing and holding the VOLUME UP key and the power key together until the phone shortly vibrates.
4. When Android system recovery menu appears, release VOLUME key.
5. Highlight wipe data/Factory reset using volume key.
6. Confirm with Power or Cancel using BACK key.
7. After hard reset is done, highlight reboot system now and confirm your selection.
Note! All data will be deleted!
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 09-08-2014, 07:15   #3 (permalink)
Member: 1283254
Thanks Meter: 3
Alex
not work in my set only see recovery system logo
Old 10-18-2014, 08:24   #4 (permalink)
Member: 2178660
A 51 Karboon hard reset key not work bro please help ...
Old 11-08-2014, 13:13   #5 (permalink)
ATHI's Avatar
Member: 667142
Sonork: +919655528882
Thanks Meter: 2,495
please any one help me A 51 Karboon hard reset
Old 12-19-2014, 06:29   #6 (permalink)
Member: 2300952
Thanks Meter: 2
not working please help
give me 100% solution
Old 04-20-2015, 18:16   #7 (permalink)
Crazy Poster
Member: 1005791
Sonork: Vikas kumar
Thanks Meter: 13
karbonn a51 unlock
gpg dragon is best,spd,format only user data ,done
Old 05-25-2015, 11:01   #8 (permalink)
Member: 1870489
Sonork: 100.1663831
Thanks Meter: 483
here ur sulitoin bro kindly check it
Old 06-11-2015, 10:23   #9 (permalink)
Member: 2403317
Kabonn A51 pattern unlock any one help plez without tool and box
Old 06-11-2015, 10:36   #10 (permalink)
Super Moderator
MyGSM World's Avatar
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Dear Friend,
Here It's, Karbonn A51 Hard Reset Method/Solution, Use Without Any Box & Without Any Risk.
http://forum.gsmhosting.com/vbb/10825463-post2.html
http://forum.gsmhosting.com/vbb/10779228-post4.html
Post Result Please.
The Following User Says Thank You to MyGSM World For This Useful Post:
Old 09-10-2015, 15:55   #11 (permalink)
Member: 788435
Sonork: 100.1672438
Thanks Meter: 26
karbonn a51 how the hard reset
Old 09-10-2015, 16:37   #12 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Dear Friend,
There Is No Way For Hard Reset To Karbonn A51.
Use This Version Flash Tool : ResearchDownload - R2.9.7005
And Use Any Version Flash File : DOWNLOAD
First Select Flash File Any Version By Load Packet Then Click On Settings & Deselect All Files From Main Page.
Only Select UserDate. Then Click On OK
Last On Click On Start Downloading.
You'll See "Passed" With Green Colour In Flash Tool.
Old 10-09-2015, 11:25   #13 (permalink)
renginokia's Avatar
Member: 1392433
Sonork: 100.1650669
Thanks Meter: 90
some model 51 flashing,hand format box not support use flash tool,but same model support hand format or box many time am tested........
Old 10-09-2015, 15:43   #14 (permalink)
rainbow12's Avatar
Member: 1096472
Thanks Meter: 26
I m agree with u bro
Old 10-09-2015, 18:22   #15 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Dear Friends,
There Is Two Model & Many Versions For A51 & A51+.
Hard Reset Only Work On A51Plus, Not Work On A51.
A51Plus Have MediaTek & A51 Have SpreadTrum CPU.
Page generated in 0.24807 seconds with 8 queries
