06-14-2014, 12:41 | #1 (permalink) |
Insane Poster Join Date: Sep 2008 Location: Rajsthan {Merta Raod} Age: 45
Member: 873465 Status: Offline Sonork: [email protected] Thanks Meter: 7 | Karbonn A51 Pattern lock / hard reset solution |
06-14-2014, 12:46 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | 1. Charge the battery 100%. 2. Turn off the phone. 3. Turn ON the device by pressing and holding the VOLUME UP key and the power key together until the phone shortly vibrates. 4. When Android system recovery menu appears, release VOLUME key. 5. Highlight wipe data/Factory reset using volume key. 6. Confirm with Power or Cancel using BACK key. 7. After hard reset is done, highlight reboot system now and confirm your selection. Note! All data will be deleted! BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
09-08-2014, 07:15 | #3 (permalink) | |
Insane Poster Join Date: Apr 2010 Location: Tikapur - Kailali, NEPAL
Member: 1283254 Status: Offline Thanks Meter: 3 | Quote:
not work in my set only see recovery system logo | |
06-11-2015, 10:36 | #10 (permalink) | |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Quote:
Here It's, Karbonn A51 Hard Reset Method/Solution, Use Without Any Box & Without Any Risk. http://forum.gsmhosting.com/vbb/10825463-post2.html http://forum.gsmhosting.com/vbb/10779228-post4.html Post Result Please. | |
The Following User Says Thank You to MyGSM World For This Useful Post: |
09-10-2015, 16:37 | #12 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, There Is No Way For Hard Reset To Karbonn A51. Use This Version Flash Tool : ResearchDownload - R2.9.7005 And Use Any Version Flash File : DOWNLOAD First Select Flash File Any Version By Load Packet Then Click On Settings & Deselect All Files From Main Page. Only Select UserDate. Then Click On OK Last On Click On Start Downloading. You'll See "Passed" With Green Colour In Flash Tool. |
10-09-2015, 11:25 | #13 (permalink) |
No Life Poster Join Date: Sep 2010 Location: KERALA,INDIA
Member: 1392433 Status: Offline Sonork: 100.1650669 Thanks Meter: 90 | some model 51 flashing,hand format box not support use flash tool,but same model support hand format or box many time am tested........ |
10-09-2015, 18:22 | #15 (permalink) | |
There Is Two Model & Many Versions For A51 & A51+. Hard Reset Only Work On A51Plus, Not Work On A51. A51Plus Have MediaTek & A51 Have SpreadTrum CPU. | |
