06-02-2015, 14:15 | #3451 (permalink) |
No Life Poster Join Date: Nov 2010 Location: THE MOBILE SHOP
Member: 1432329 Status: Offline Sonork: 100.1615863 Thanks Meter: 1,626 | LOGS---- Module Ver. : 2.8 Com Port : COM29 : Qualcomm HS-USB Diagnostics 9004 (COM29) Baud Rate : 921600 Device : Alcatel OT-255c Operation : Unlock Port opened. Reading Information... Compile : May 01 2011 15:49:09 Release : Apr 24 2010 23:00:00 Hw Ver. : AL255CMT ESN : 8035233B MEID : A100000861101F BUILD : q1100-SBNAALZ-3375 Int. Ver. : May 10 2011 Setting Download Mode... Download Mode set, Reconnecting... Preparing phone... Sending bootloader... Executing Bootloader... Bootloader running OK. Waiting for reconnect... Reconnect OK Flash Chip : SPANSION S29NS064Nd Chip Size : 8 MB Patching security area... Patching success. Resetting phone... Port closed. Operation finished. Elapsed Time: 00:16 WBR THE MOBILE SHOP |
The Following User Says Thank You to sunilkumar70791 For This Useful Post: |
06-03-2015, 06:38 | #3453 (permalink) |
No Life Poster Join Date: Sep 2013 Location: Kotla Arab Ali Khan(PAK)
Member: 2016954 Status: Offline Thanks Meter: 345 | Y511 SuccessFull flash Flash files count is :11 Action : Firmware update. Selected Huawei: Ascend Y511-U30 Exe version: NCKBox AndroidMTK 1.8.5.2 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM Port (COM18) BBCHIP: MT6572_S00 BBCHIP HW: 0xCA01 BBCHIP SW: 0x0000 SECURE VERSION: 0 Phone detected...Please wait Sending DA agent, please wait... EMMC: (28Gb+4096Mb) HYNIX 0x483447316404 EMMC FW VERSION: 86:00:00:00:00:00:00:00 EMMC CID: 90014A4834473164048601A41B73910F EMMC UA SIZE: 0xe7000000 BOOT STYLE: EMMC BOOT Detecting high speed port, wait...... If driver not installed, install high speed port driver. Detected : MediaTek DA USB VCOM Port (COM26) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Starting flash. Download firmware to flash now... MBR checksum is executing ... EBR1 checksum is executing ... UBOOT checksum is executing ... BOOTIMG checksum is executing ... RECOVERY checksum is executing ... SEC_RO checksum is executing ... LOGO checksum is executing ... ANDROID checksum is executing ... CACHE checksum is executing ... USRDATA checksum is executing ... Wait untill phone will start charging. All done. |
The Following User Says Thank You to GsmKotla For This Useful Post: |
06-03-2015, 17:35 | #3455 (permalink) |
Freak Poster Join Date: Aug 2013
Member: 1995502 Status: Offline Thanks Meter: 139 | Unlocking xperia x10i Unlock procedure started, waiting for phone. Power off phone, keep BACK button and insert usb cable. Keep holding back key untill next prompt. Connecting to the server Please wait.... Send S1 Loader Loader is sent, please wait... Read device info. CXC : 1226-2250 IMEI : 35941903480913 EROM AID : 0001 LOADER AID : 0001 AID TAMP STATE : NOT_TAMPERED SE X10 GROUP - HOLD THE BACK KEY IMEI : 35941903480913 - SE UNLOCK STARTED(2.3). - WAITING USER ACTION - WAITING PHONE Version : 2.3.3 OK. - Phone found, waiting root. - Can take up to 1 min, do not touch phone!!!. If stuck here more then 1 min, reconect usb cable. - ROOT ACCESS OK - SE UNLOCK START Changes made.. - STATUS: OK Wait untill phone full power on. -------------------------- Log saved to: C:\Users\Zvr\Documents\NckDongle\Exe_Logs\35941903 480913_XperiaX104.txt |
The Following User Says Thank You to zvrrr For This Useful Post: |
06-04-2015, 14:23 | #3456 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | riliance d286 unlock done Code: Module Ver. : 2.7 Com Port : COM105 : Qualcomm HS-USB Diagnostics 9004 (COM105) Baud Rate : 921600 Device : Lava D286 (ZTE) Operation : Unlock Opening Port... Reading Information... Compile : Jul 08 2014 17:06:52 Release : Apr 24 2012 05:00:00 Hw Ver. : UP105D13 ESN : 801Axxxx MEID : A0000038EExxxx IMEI : 864498020218401 BUILD : q11x5-CG108-1030 User Code : 0000 SPC : 000000 Setting Download Mode... Download Mode OK, Waiting for Phone... Reconnect OK Preparing Phone... Sending Bootloader... Initializing Bootloader... Initialing Flash Chip... Chip Name : INTEL 512 L18 ADMuxd Chip Size : 64 MB Patching Firmware... Resetting Phone... Port Closed. Operation Finished. Elapsed Time: 00:20 Log saved as \!Log\LOG_15_06_04_18_39_22.log |
The Following User Says Thank You to rehmani For This Useful Post: |
06-05-2015, 13:12 | #3458 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel OneTouch OT-4015X unlock code read done... Selected connection metod: META Mode Exe version: NCKBox AndroidMTK 1.8.5.2 Selected phone: OT-4015X Scanning for presents meta ports... Meta ports not detected, starting brom stage. Phone must be off with battery inside. Please insert USB cable now... Detected(0) : PreLoader USB VCOM (Android) (COM5) Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. META Port Detected[42] Android Gadget VCOM Driver (COM42) Start sync target, waiting responce..... BaseBand CPU : MT6572, E01 SW_VER : MOLY.WR8.W1315.MD.WG.MP.V1.P3 HW_VER : JRDSZZ72_WE_JB3_HSPA_HW Meta mode conected ok, start reading phone.... Phone imei[1] : 866651022956372 Simlock Info : Sim [1] Block1[N] :Locked [remain:10] Code : 0250780017 Block2[NS] :Unlocked Code: 5093398330 Block3[SP] :Unlocked Code: 8245683720 Block4[C] :Unlocked Code: 5296459213 Block5[SIM]:Unlocked Code: 6706259159 ************************************** All done. |
The Following User Says Thank You to razib143 For This Useful Post: |
06-06-2015, 09:02 | #3460 (permalink) |
Insane Poster Join Date: Aug 2010 Location: Bulgaria , Burgas Age: 50
Member: 1357771 Status: Offline Thanks Meter: 40 | alcatel 4010x flash done Flash files count is :11 Action : Firmware update. Selected Alcatel: OT-4010 Exe version: NCKDongle AndroidMTK 2.5.5.1 DA: MTK_AllInOne_DA.bin Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM (Android) (COM6) BBCHIP: MT6575_S01 BBCHIP HW: 0xCB00 BBCHIP SW: 0xE201 SECURE VERSION: 0 Phone detected...Please wait Sending DA agent, please wait... NAND: (4Gb+2048Mb) [Micron] NAND_MT29C4G48MAAHBAAKS_5WT BOOT STYLE : NAND BOOT Detecting high speed port, wait...... If driver not installed, install high speed port driver. Detected : DA USB VCOM Port (COM11) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Download firmware to flash now... UBOOT checksum is executing ... BOOTIMG checksum is executing ... RECOVERY checksum is executing ... SEC_RO checksum is executing ... LOGO checksum is executing ... ANDROID checksum is executing ... CUSTPACK checksum is executing ... USRDATA checksum is executing ... Wait untill phone will start charging. All done. |
06-07-2015, 09:08 | #3462 (permalink) |
Freak Poster Join Date: Mar 2014
Member: 2139591 Status: Offline Thanks Meter: 78 | Alcatel One Touch Unlock Done. Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM Port (COM7) Phone detected...Please wait Sending DA agent, please wait... BBCHIP MT6572_S00 EMMC: (29Gb+4096Mb) UNKNOWN_EMMC_DEVICE EMMC FW VERSION: 12:00:00:00:00:00:00:00 BOOT STYLE : EMMC BOOT Detecting high speed port, wait...... If driver not installed, install high speed port driver. Detected : MediaTek DA USB VCOM Port (COM39) MODEL FW: 4015X-2AE5GB1 Reading security, wait... IMEI[1] : 8666************** SIM [1] Block1(N) : Locked (remain:9) Code : 1504478735 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C) : Unlocked ............... ............... Unlocking target...please wait. Unlock finished. Wait untill phone will start charging. All done. |
The Following User Says Thank You to afnanbangash For This Useful Post: |
06-08-2015, 07:48 | #3463 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2318309 Status: Offline Thanks Meter: 12 | Module Ver. : 2.9 Com Port : COM6 : FC - Application Interface (COM6) Baud Rate : 921600 Device : Huawei EC315 Operation : Unlock Opening Port... Reading Information... Compile : Dec 14 2012 08:15:31 Release : Mar 12 2011 12:00:00 Hw Ver. : SCAUTHZ3 ESN : 8094081C MEID : A00000495***** Hw. Type : EC315-1CE1EC315M Ver.A Firmware : 11.102.59.02.836 Dashboard : HILINK12.001.10.01.836 Calculating Flash Code... Flash Code : 61359704 Reading Lock Status... Lock Status : Locked RUIM Mode : NV Only Unlocking Modem, Please wait... Modem Successfully Unlocked. Setting RUIM Mode to RUIM Only... Scanning for SPC... Error Reading SPC! 0x601 Could not read SPC! Using Default SPC [000000]... SPC Accepted... RUIM Mode : RUIM Only Operation finished. Port Closed. Elapsed Time: 00:01 |
The Following User Says Thank You to cdma9 For This Useful Post: |
06-08-2015, 07:48 | #3464 (permalink) |
Member: 2318309 Status: Offline Thanks Meter: 12 | Module Ver. : 2.9 Com Port : COM6 : FC - Application Interface (COM6) Baud Rate : 921600 Device : Huawei EC315 Operation : Repair NVM Port Opened. Reading Information... Compile : Dec 14 2012 08:15:31 Release : Mar 12 2011 12:00:00 Hw Ver. : SCAUTHZ3 ESN : 8094081C MEID : A00000495DB464 Hw. Type : EC315-1CE1EC315M Ver.A Firmware : 11.102.59.02.836 Dashboard : HILINK12.001.10.01.836 Calculating Flash Code... Flash Code : 61359704 Reading Lock Status... Lock Status : Locked RUIM Mode : NV Only Trying Security Unlock Method 1... Trying Security Unlock Method 2... Repairing NVM Data, Please Wait... Port Closed Operation Finished. Elapsed Time: 00:13 |
06-08-2015, 07:50 | #3465 (permalink) |
Member: 2318309 Status: Offline Thanks Meter: 12 | Module Ver. : 2.9 Com Port : COM6 : FC - Application Interface (COM6) Baud Rate : 921600 Device : Huawei EC315 Operation : Write MEID Port Opened. Reading Information... Compile : Dec 14 2012 08:15:31 Release : Mar 12 2011 12:00:00 Hw Ver. : SCAUTHZ3 ESN : 00000000 MEID : 00000000000000 Hw. Type : EC315-1CE1EC315M Ver.A Firmware : 11.102.59.02.836 Dashboard : HILINK12.001.10.01.836 Calculating Flash Code... Flash Code : 34528025 Reading Lock Status... Lock Status : Locked RUIM Mode : NV Only Trying to Write MEID [A00000495DB464]... Trying Security Unlock Method 1... Trying Security Unlock Method 2... New MEID : A00000495DB464 Operation finished. Port Closed. Elapsed Time: 00:01 |
