02-05-2016, 14:21 | #4381 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Selected connection metod: FLASH Mode Exe version: NCKBox AndroidMTK 1.8.6.4 Selected phone: MT6580 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM92) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6580_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 768 MB DRAM ---------------------------------------------------- EMMC: (29Gb+6144Mb) HYNIX 0x483447326111 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 90014A48344732 : 000000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9c00000 [3.652 GB] Block Size: 512 IMEI marker was found in nvram IMEI[1] from NVRAM: 35560107435XXXX IMEI[2] from NVRAM: 355601074438XXX Reading security, wait... SIM[1]: Block1(N): Locked (remain:5) Code : 87654321 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked SIM[2]: Block1(N): Locked (remain:5) Code : 87654321 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Unlocking target...please wait. Unlock finished. Wait untill phone will start charging. All done. |
02-05-2016, 14:23 | #4382 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Another Wiko Mobile Unlock done.. Selected connection metod: FLASH Mode Exe version: NCKBox AndroidMTK 1.8.6.4 Selected phone: MT6580 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM92) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6580_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 768 MB DRAM ---------------------------------------------------- EMMC: (29Gb+6144Mb) HYNIX 0x483447326111 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 90014A48344732 : 000000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9c00000 [3.652 GB] Block Size: 512 IMEI marker was found in nvram IMEI[1] from NVRAM: 355601074394XXX IMEI[2] from NVRAM: 355601074479XXX Reading security, wait... SIM[1]: Block1(N): Locked (remain:5) Code : 87654321 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked SIM[2]: Block1(N): Locked (remain:5) Code : 87654321 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Unlocking target...please wait. Unlock finished. Wait untill phone will start charging. All done. |
02-05-2016, 18:40 | #4383 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Tecno P5 Flash write done.. Flash files count is :9 Action : Firmware update. Selected 0-By CPU: MT6572_EMMC Exe version: NCKBox AndroidMTK 1.8.6.4 Scenario: Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM4) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6572_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (28Gb+4096Mb) KSI 0x4d4d43303447 EMMC FW VERSION: 58:00:00:00:00:00:00:00 EMMC CID: 7001004D4D4330 : 000000000000000000 EMMC UA SIZE: 0xe6800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe6c20000 [3.606 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM5) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Starting flash. Download firmware to flash now... Wait untill phone will start charging. All done. |
02-05-2016, 18:47 | #4384 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | alcatel 1041a unlock done claro dominican republic EXE VERSION: NCKDongle MTK Tool 1.45 DA version: 5.1428.00.00 USER SELECTION: UNLOCK. MODEL SELECTED: OT-1041A PHONE MUST BE OFF WITH BATTERY INSIDE. Com port opened...Press power on Download DA now...You can release power on Reading model info, wait...... CBR RECORD EXIST. MODEL FROM CBR: 1041A-2BAVDO3 SECRO FROM CBR: X1A60NK0AQ00 Reading imei info, wait...... HARDWARE IMEI: 014222005808948 Backup saved to: C:\Users\MaxCell\Documents\Generic_MTK\alcapid_bac kup\OT-1041A_014222005808948_1041A-2BAVDO3_X1A60NK0AQ00_simlock_backup_02-05-2016-13-43-19.bin Getting phone info .... BaseBand CPU: MT6260_S0000 FLASH TYPE: NOR ID: NOR32Mb+32Mb) [WINBOND] W25Q32BV size: 0x00400000 INT RAM: 416Kb RAM: 32Mb SRAM BOOT STYLE: S_SF_FLASH_BOOT(1031) Phone Succussfully Unlocked. Disconnecting phone :S_DONE(0) ALL DONE. |
02-05-2016, 19:19 | #4385 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Bangladesh
Member: 1092417 Status: Offline Sonork: 100.1645946 Thanks Meter: 45 | Lenovo a328 monkey virus clean done! Code: Exe Version: NCKdongle v17.5 Phone must be on, USB debugging must be enabled. If Phone ask for Allow Usb Debugging, allow. Searching for Device... Device Found Model: Lenovo A328 Version: 4.4.2 Hardware: mt6582 Baseband: MOLY.WR8.W1315.MD.WG.MP.V34.P6, 2014/07/07 14:15 SIM Card: ABSENT CPU: armeabi-v7a Type: GSM IMEI(1): 865676025555229 Type: GSM IMEI(2): 865676025573222 Checking Root Access... If Phone ask for su, allow. root: uid=0(root) gid=0(root) context=u:r:init:s0 Root: Rooted Loading Detection Data... OK Scanning for Malware/Suspicious Files... OK Files Found: 1 Restarting phone.. Operation Finished. |
02-06-2016, 13:21 | #4386 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | Samsung g900t unlock done OTHER BOX FAILLED BUT NCK DONE IT Code: Unlock metod[1]. PHONE SELECTED: SM-G900T Port: SAMSUNG Mobile USB Serial Port (COM101) Build id: MPSS.DI.2.0.1.c2-00062-M8974AAAAANRZM-1.01647286.3416.1 Version info: Nov 10 201414:17:26Jul 29 201407:00:00AAAAANRZ:d IMEI: 353300063448564 Unlocking, wait.... Job done, if phone not restart, restart manually -------------------------- |
02-06-2016, 13:27 | #4387 (permalink) |
Member: 1092417 Status: Offline Sonork: 100.1645946 Thanks Meter: 45 | Symphony xplorer w32 malware cleaned! Code: Exe Version: NCKdongle v17.5 Phone must be on, USB debugging must be enabled. If Phone ask for Allow Usb Debugging, allow. Searching for Device... Device Found Model: Symphony Xplorer W32 Version: 4.2.2 Hardware: mt6572 Baseband: MOLY.WR8.W1315.MD.WG.MP.V1.P10, 2013/10/08 12:21 SIM Card: ABSENT CPU: armeabi-v7a Type: GSM IMEI(1): 352089065260983 Type: GSM IMEI(2): 352089065412535 Checking Root Access... If Phone ask for su, allow. root: uid=0(root) gid=0(root) Root: Rooted BusyBox: Not Installed! Please Install BusyBox! Loading Detection Data... OK Scanning for Malware/Suspicious Files... OK Files Found: 3 Restarting phone.. Operation Finished. |
02-07-2016, 11:27 | #4389 (permalink) | |
No Life Poster Join Date: Apr 2013 Location: Uzbekistan / Bukhara
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 623 | ZTE V815W Flashing done .. . Quote:
02-07-2016, 11:28 | #4390 (permalink) | |
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 623 | Micromax D303 Direct Unlock done ,.. Quote:
02-07-2016, 11:28 | #4391 (permalink) | |
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 623 | UZTE Grand V7 Direct Unlock Done ... Quote:
02-07-2016, 11:29 | #4392 (permalink) | |
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 623 | Oysters T72HM3G Direct Unlock Done... Quote:
02-07-2016, 11:29 | #4393 (permalink) | |
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 623 | UZTE Grand V7 Direct Unlock Done... Quote:
02-07-2016, 11:30 | #4394 (permalink) | |
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 623 | UZTE Grand V 7 Direct Unlock Done .. . Quote:
02-07-2016, 11:32 | #4395 (permalink) | |
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 623 | Oysters Arctic 450 direct unlock done Quote:
