02-07-2016, 11:33 | #4396 (permalink) | |
No Life Poster Join Date: Apr 2013 Location: Uzbekistan / Bukhara
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 623 | Quote:
02-07-2016, 11:34 | #4397 (permalink) | |
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 623 | UZTE Grand V7 IMEI Repair done ... Quote:
02-07-2016, 11:35 | #4398 (permalink) | |
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 623 | Bee Phone Direct unlock done ... Quote:
02-07-2016, 11:36 | #4399 (permalink) | |
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 623 | MTC 972 Unlock Done... Quote:
02-08-2016, 17:24 | #4400 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel OneTouch Pixi 3 Unlock done.. :D Code: Selected connection metod: FLASH Mode Exe version: NCKBox AndroidMTK 1.8.6.4 Selected phone: OT-4013X Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM4) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6572_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) SAMSUNG 0x464a32354142 EMMC FW VERSION: 02:00:00:00:00:00:00:00 EMMC CID: 150100464A3235 : 000000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9880000 [3.649 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM5) Block Size: 512 MODEL FROM PROINFO: 4013X-2AOBGB1 SECRO FROM PROINFO: X5B0CQ00AZ1X IMEI marker was found in nvram OTP ADRESS: 0xffff0200 OTP IMEI[1]: 356257066302908 Reading security, wait... SIM[1]: Block1(N): Locked (remain:10) Code : 0032617534553880 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Unlocking target...please wait. Unlock finished. Wait untill phone will start charging. All done. |
02-08-2016, 18:33 | #4402 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel 5020T Unlock code read done.. :D Code: Selected connection metod: FLASH Mode Exe version: NCKBox AndroidMTK 1.8.6.4 Selected phone: OT-5020T Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : USB Modem Driver (COM97) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6575_S01 BaseBand CPU Secure Version : 05 BaseBand CPU Bootloader Version : 00 ---------------------------------------------------- INT RAM: 128 KB SDRAM ---------------------------------------------------- EMMC: (29Gb+0Kb) MICRON 0x503058585858 EMMC FW VERSION: 10:00:00:00:00:00:00:00 EMMC CID: FE014E50305858 : 000000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9300000 [3.644 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM98) OTP IMEI : 013778002753248 Reading security, wait... SECRO FW : X2L0UM02AB00 NCK: 37460343 : Locked NSCK: 31573000 : Unlocked SPCK: 39950016 : Unlocked SIM: 17575813 : Unlocked If lock counter is 0, make "Format UserData" from exe. Simlock backup already exists, skip save. Wait untill phone will start charging. All done. |
02-08-2016, 18:58 | #4403 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Huawei Y330 Firmware done.. Flash files count is :14 Action : Firmware update. Selected Huawei: Ascend Y330-U01 Exe version: NCKBox AndroidMTK 1.8.6.4 Scenario: Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM92) Phone detected...Please wait Sending DA agent, please wait... BBCHIP MT6572_S00 EMMC FW VERSION: 3c:00:00:00:00:00:00:00 EMMC CID: 45010053454D3034473C6675E0DA917D EMMC UA SIZE: 0xec000000 BOOT STYLE: EMMC BOOT Partitions count: 22 Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM98) Parsing firmware, wait. Send preloader... Download firmware to flash now... All done. |
02-09-2016, 15:05 | #4404 (permalink) |
Freak Poster Join Date: Aug 2013
Member: 1995502 Status: Offline Thanks Meter: 139 | ZTE Blade G malware remove done :) Exe Version: NCKdongle v17.5 Phone must be on, USB debugging must be enabled. If Phone ask for Allow Usb Debugging, allow. Searching for Device... Device Found Model: ZTE Blade G Version: 4.1.2 Hardware: qcom Baseband: Unknown Basedband Not Found! Try Read Info Again After Boot Finished! Possibly Device May Not Have SIM Function! SIM Card: READY CPU: armeabi-v7a Type: GSM IMEI(1): 359765030531706 Checking Root Access... If Phone ask for su, allow. root: uid=0(root) gid=0(root) Root: Rooted Loading Detection Data... OK Scanning for Malware/Suspicious Files... OK Files Found: 23 Restarting phone.. Operation Finished. |
02-09-2016, 16:15 | #4405 (permalink) |
No Life Poster Join Date: May 2012 Location: NCK Team
Member: 1761928 Status: Offline Sonork: 100.1626169 Thanks Meter: 804 | WIKO Lenny 2 with hardlocked fw simlock remove succes Connected mode WITHOUT battery! Code: Selected connection metod: FLASH Mode Exe version: NCKBox AndroidMTK 1.8.6.4 Selected phone: MT6580 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM (Android) (COM12) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6580_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 768 MB DRAM ---------------------------------------------------- EMMC: (29Gb+6144Mb) HYNIX 0x483447326111 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 90014A48344732 : 000000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9c00000 [3.652 GB] Block Size: 512 IMEI marker was found in nvram IMEI[1] from NVRAM: IMEI[2] from NVRAM: Reading security, wait... SIM[1]: Block1(N): Locked (remain:5) Code : 87654321 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked SIM[2]: Block1(N): Locked (remain:5) Code : 87654321 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Unlocking target...please wait. Unlock finished. Wait untill phone will start charging. All done. |
02-10-2016, 09:15 | #4407 (permalink) |
Freak Poster Join Date: May 2008 Location: beawar (rajsthan)
Member: 764695 Status: Offline Sonork: 100.1627861 Thanks Meter: 45 | Zte S165 Efs Right Done [Module Ver. : 3.1 Com Port : COM69 : ZTE CDMA Handset Diagnostics Interface (COM69) Baud Rate : 921600 Device : ZTE S165 Operation : Flash EFS Port opened. Compile : Feb 26 2013 15:53:03 Release : Apr 24 2009 24:00:00 Hw Ver. : V.MTS.S1 ESN : 8003EBAB MEID : A10000xxxxxxxx MemUnlock : Success Build : V.MTS.S165.B04 Detected : S165 User Code : 0000 Setting Download mode... Mode change OK. Waiting for phone... Reconnect OK. Initializing Flash Protocol... Flash Chip : SPANSION S71VS064RB0d Chip Size : 8 MB Flash File : S165 UNLOCK FILE.BIN File Size : 8 MB Writing EFS area... Write EFS finished. Resetting phone... Operation finished Port closed. Elapsed Time: 01:01] |
02-10-2016, 12:32 | #4409 (permalink) | |
Banned Join Date: Nov 2010 Location: :::LONDON:::
Member: 1442994 Status: Offline Thanks Meter: 899 | Meo easy 11...... Quote:
ak' | |
02-10-2016, 13:14 | #4410 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel OneTouch 5015X Pixi 4.5 Direct Unlock done.. Selected connection metod: FLASH Mode Exe version: NCKBox AndroidMTK 1.8.6.4 Selected phone: OT-5017X Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM92) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6735M_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x513732534d42 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010051373253 : 000000000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM98) Block Size: 512 MODEL FROM PROINFO: 5017X-2COBGB2-1 SECRO FROM PROINFO: X1B0CQ01BP10 IMEI marker was found in nvram OTP ADRESS: 0xffff01dc OTP IMEI[1]: 35168907153XXXX Reading security, wait... SIM[1]: Block1(N): Locked (remain:4) Code : 0185831404074443 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Unlocking target...please wait. Unlock finished. Wait untill phone will start charging. All done. |
