02-21-2016, 06:31 | #4441 (permalink) |
No Life Poster Join Date: Dec 2008 Location: MANSEHRA
Member: 921094 Status: Offline Sonork: 100.1603246 Thanks Meter: 326 | Alcatel ot5014x unlock done ALCATEL OT5014X UNLOCK DONE Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM47) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6572_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) HYNIX 0x483447316404 EMMC FW VERSION: 05:00:00:00:00:00:00:00 EMMC CID: 90014A48344731 : 000000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9c00000 [3.652 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM75) Block Size: 512 MODEL FROM PROINFO: 4018X-2GVRGB1 SECRO FROM PROINFO: X8I0CT05AN10 IMEI marker was found in nvram OTP ADRESS: 0xffff0200 OTP IMEI[1]: 864743020921136 Reading security, wait... SIM[1]: Block1(N): Locked (remain:6) Code : 01002846 Block2(NS): Unlocked Block3(SP): Locked (remain:10) Code : 23117949 Block4(C): Unknown[2] Unlocking target...please wait. Unlock finished. Wait untill phone will start charging. All done. |
02-21-2016, 12:22 | #4442 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel Vodafone Smart First 6 Unlock done.. Selected connection metod: FLASH Mode Exe version: NCKBox AndroidMTK 1.8.6.4 Selected phone: Vodafone Smart First 6 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM92) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6572_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) MICRON 0x50314a39344d EMMC FW VERSION: 12:00:00:00:00:00:00:00 EMMC CID: FE014E50314A39 : 000000000000000000 EMMC UA SIZE: 0xe9800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9b00000 [3.651 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM98) Block Size: 512 MODEL FROM PROINFO: V695-2BVDGB2 SECRO FROM PROINFO: X8I0HE00AZ10 IMEI marker was found in nvram OTP ADRESS: 0xffff0200 OTP IMEI[1]: 357773069900877 Reading security, wait... SIM[1]: Block1(N): Locked (remain:5) Code : 16380959 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Unlocking target...please wait. Unlock finished. Wait untill phone will start charging. All done. |
02-22-2016, 13:16 | #4445 (permalink) |
Freak Poster Join Date: Aug 2013
Member: 1995502 Status: Offline Thanks Meter: 139 | LT18 Xperia Arc S unlock done Unlock procedure started, waiting for phone. Attach Testpoint and connect phone with Micro USB cable. Connecting to boot. Port : Forge HS-USB QDLoader 9008 (COM306) Second step... Please wait.... Read device info. CXC : 1234-5769 IMEI : 35850604735997 EROM AID : 0001 LOADER AID : 0001 AID TAMP STATE : NOT_TAMPERED Start unlocking procedure...wait. Step 1 done.. IMEI : 35850604735997 Step 2 done.. - UNLOCKING Step 3 done.. - UNLOCK DONE -------------------------- Log saved to: C:\Users\Zvr\Documents\NckMain\Exe_Logs\3585060473 5997_LT18-XperiaarcS1.txt |
02-22-2016, 13:24 | #4446 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 249 | mtn s620 unlocked Selected connection metod: META Mode Exe version: NCKBox AndroidMTK 1.8.6.4 Selected phone: OT-4010X Scanning for presents meta ports... Meta ports not detected, starting brom stage. Curent Platform: MT6575 Phone must be off with battery inside. Please insert USB cable now... Detected(4) : MediaTek PreLoader USB VCOM (Android) (COM4) Starting META mode, wait... Restarting, wait.... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. META Port Detected[126] MediaTek USB VCOM (Android) (COM126) USB\VID_0BB4&PID_0005&MI_02\6&2F89E49F&0&0002 Start sync target, waiting responce..... BaseBand CPU : MT6572, E01 SW_VER : MOLY.WR8.W1315.MD.WG.MP.V47 HW_VER : HEXING72_CWET_KK_HSPA_HW Phone imei[1] : 352509071131126 Phone imei[2] : 352509071131134 Start direct unlock[SIM1] Direct unlock done Start direct unlock[SIM2] Direct unlock done Clean Boot flag ok. All done. |
02-22-2016, 15:14 | #4447 (permalink) |
Freak Poster Join Date: Dec 2009 Location: Oman+BD
Member: 1194197 Status: Offline Sonork: 100.1671026 Thanks Meter: 185 | Z2 unlock done Now connect phone to PC Injecting Loader. Loader injected ok. Read Phone Info.. Phone Imei : 8600xxx1039xxxx Phone SN : Z2J7NBxxxxxxx786 Phone Firmware : U8510_7V100R001C00B005_E SimLock marker found.. Total markers found : 1 Simlock Status : Locked. Removing SimLocks Please Wait... Read marker : 1 Write marker : 1 All Done. |
The Following User Says Thank You to faruk_patwary For This Useful Post: |
02-22-2016, 15:16 | #4448 (permalink) |
Member: 1194197 Status: Offline Sonork: 100.1671026 Thanks Meter: 185 | mtc 4g unlock done Selected connection metod: FLASH Mode Exe version: NCKDongle AndroidMTK 2.5.5.8 Selected phone: Smart run 4G Download mode: With Battery Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM3) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6752_S01 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x513732534d42 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 150100513732534D42008DE3C673523B EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 Block Size: 512 IMEI marker was found in nvram IMEI[1] from NVRAM: 867700020016xxx If this phone have OTP IMEI, this is normal. Reading security, wait... SIM[1]: Block1(N): Locked (remain:83) Code : xxxxxxxx Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Unlocking target...please wait. Unlock finished. Wait untill phone will start charging. |
02-22-2016, 15:17 | #4449 (permalink) |
Member: 1194197 Status: Offline Sonork: 100.1671026 Thanks Meter: 185 | Selected connection metod: FLASH Mode Exe version: NCKDongle AndroidMTK 2.5.6.0 Selected phone: OT-6012 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : Huawei PreLoader USB VCOM (Android) (COM5) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6572_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) TOSIBA 0x303034474530 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 1101003030344745 : 0000000000000000 EMMC UA SIZE: 0xec000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xec480000 [3.692 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : Huawei DA USB VCOM (Android) (COM6) Block Size: 512 IMEI marker was found in nvram IMEI[1] from NVRAM: fffffffffffffff If this phone have OTP IMEI, this is normal. IMEI[2] from NVRAM: fffffffffffffff If this phone have OTP IMEI, this is normal. Reading security, wait... IMEI[1] : 91146740204 SIM[1]: Block1(N): Locked (remain:218) Code : Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Unlocking target...please wait. Unlock finished. Wait untill phone will start charging. |
02-22-2016, 15:18 | #4450 (permalink) |
Member: 1194197 Status: Offline Sonork: 100.1671026 Thanks Meter: 185 | ot-2045x unlock done USB Connection selected. EXE VERSION: NCKDongle MTK Tool 1.44 Connect phone in boot mode ... USB\VID_0E8D&PID_0003&REV_0100 Com port ok : COM55 Phone detected...Please wait Conected ok with target ... Reopen comport(COM55) BaseBand CPU : MT6276 SW_VER : 2045X_L4GM_V1.4_150709_CAM30_MCP128_64_FM_BT_Y_CH_ SWISSCOM HW_VER : HW01 Meta mode conected ok, start reading phone.... Phone imei[1] : 355626061****** User code(Inactive) : 0000 SIMLOCK INFO[1]: Block1(N) : Locked (remain:5) Code : 18331645 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C) : Unlocked META END OK. All done. |
02-22-2016, 15:18 | #4451 (permalink) |
Member: 1194197 Status: Offline Sonork: 100.1671026 Thanks Meter: 185 | Model Selected : SPH-L720 Detecting phone, wait.... LCD must be on. If phone ask for SU, please allow. If phone ask for auth please confirm. MODEL : SPH-L720 BOARD ID : MSM8960 PLATFORM ID : msm8960 OS VERSION : 4.4.2 BUILD ID : KOT49H BUILD DATE : Tue Jan 28 22:07:34 KST 2014 BUILD VERSION : KOT49H.L720VPUFNAE SOFTWARE VERSION : L720VPUFNAE Phone Subscriber Info: Phone Type = GSM Device ID = 99000439xxxxxxx (GSM)RIL VERSION : Samsung RIL v3.0 (GSM)BASEBAND : L720VPUFNAE (RIL)SERIAL NUMBER : 00000000000 (RIL)SW VERSION : L720VPUFNAE Checking SU: True Checking Root access: True Unlocking please Wait. Unlock Done, Restarting Phone! Total Time: 00:00:15 |
02-22-2016, 15:19 | #4452 (permalink) |
Member: 1194197 Status: Offline Sonork: 100.1671026 Thanks Meter: 185 | Model Selected : SPH-L720 Detecting phone, wait.... LCD must be on. If phone ask for SU, please allow. If phone ask for auth please confirm. MODEL : SPH-L720 BOARD ID : MSM8960 PLATFORM ID : msm8960 OS VERSION : 4.4.2 BUILD ID : KOT49H BUILD DATE : Wed Jul 9 09:09:48 KST 2014 BUILD VERSION : KOT49H.L720VPUFNG2 SOFTWARE VERSION : L720VPUFNG2 Phone Subscriber Info: Phone Type = GSM Device ID = 99000435xxxxxxx (GSM)RIL VERSION : Samsung RIL v3.0 (GSM)BASEBAND : L720VPUFNG2 (RIL)SERIAL NUMBER : 00000000000 (RIL)SW VERSION : L720VPUFNG2 Checking SU: True Checking Root access: True Unlocking please Wait. Unlock Done, Restarting Phone! Total Time: 00:00:15 |
02-22-2016, 18:27 | #4453 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | alcatel ot 6012x flashing done with nck box 6012x flashing ok Code: Flash files count is :16 Action : Firmware update. Selected Alcatel: OT-6012 Exe version: NCKBox AndroidMTK 1.8.6.4 Scenario: Full Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MTK USB Port (COM402) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6572_S00 BaseBand CPU Secure Version : 05 BaseBand CPU Bootloader Version : 00 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) TOSIBA 0x303034473930 EMMC FW VERSION: 10:00:00:00:00:00:00:00 EMMC CID: 11010030303447 : 000000000000000000 EMMC UA SIZE: 0xec000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xec480000 [3.692 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM405) Flash EMMC Algo Start. Starting flash. FORMAT EMMC FLASH : BEGIN: 0xf00000 - LEN: 0xa00000 FORMAT EMMC FLASH : BEGIN: 0x1900000 - LEN: 0xa00000 FORMAT EMMC FLASH : BEGIN: 0x534c0000 - LEN: 0x9200000 FORMAT EMMC FLASH : BEGIN: 0x5c6c0000 - LEN: 0x8bdc0000 Send preloader... Download firmware to flash now... Wait untill phone will start charging. All done. |
02-23-2016, 11:16 | #4454 (permalink) |
Member: 1995502 Status: Offline Thanks Meter: 139 | SM-A300FU factory unlock done :) Unlock metod[1]. PHONE SELECTED: SM-A300FU Port: SAMSUNG Mobile USB Serial Port (COM720) Build id: MPSS.DPM.2.0.c5-00075-M8936FAAAANUZM-1 Version info: Oct 26 201521:10:58May 04 201507:00:00EAAAANVZ:d IMEI: 353974077279569 Unlocking, wait.... Job done, if phone not restart, restart manually -------------------------- Log saved to: logs\SM-A300FU_353974077279569_unlock__1.txt Done. |
The Following User Says Thank You to zvrrr For This Useful Post: |
02-24-2016, 06:58 | #4455 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Phone must be on, USB debugging must be enabled. If Phone ask for SU, allow. Found Device, reading info.. Brand: Huawei Model: HUAWEI Y530-U00 Build ID: HuaweiY530-U00 Platform ID: msm8610 OS version: 4.3 Build version: Y530-U00V100R001C900B512 SU binary present. Starting unlock, wait... Using metod 1. Reading simlock info, wait.... SIMLOCK[0]: Locked SIMLOCK[1]: Unlocked SIMLOCK[2]: Unlocked Unlocking phone.... Write simlock succes. Restarting phone, wait..... If phone not restarted, please restart manually . All done. |
The Following User Says Thank You to wsmobile For This Useful Post: |
