02-17-2016, 11:49 | #4426 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | Code: Exe Version: NCKdongle v17.5 Phone must be on, USB debugging must be enabled. If Phone ask for Allow Usb Debugging, allow. Searching for Device... Device Found Model: Izzycomm Z700II Version: 4.2.2 Hardware: mt8382 Baseband: MOLY.WR8.W1315.MD.WG.MP.V35, 2014/09/03 22:30 SIM Card: ABSENT CPU: armeabi-v7a Type: GSM IMEI(1): 35975805817 Type: GSM IMEI(2): 35975805822 Checking Root Access... If Phone ask for su, allow. root: uid=0(root) gid=0(root) Root: Rooted Loading Detection Data... OK Scanning for Malware/Suspicious Files... OK Files Found: 20 Operation Finished. |
02-17-2016, 12:44 | #4427 (permalink) |
Registered User Join Date: Mar 2010
Member: 1260168 Status: Offline Thanks Meter: 62 | Alcatel IDEA 4010D STUCK ON LOGO repaired successfully Flash files count is :10 Action : Firmware update. Selected Alcatel: OT-4010D Exe version: NCKBox AndroidMTK 1.8.6.4 Scenario: Full Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM19) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6575_S01 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 256 MB DRAM ---------------------------------------------------- NAND: (4Gb+2048Mb) [TOSHIBA] TYBC0A111557KC BOOT STYLE : NAND BOOT Size: 0x20000000 [0.500 GB] BlockSize: 4096 SpareSize: 128 BMT Blocks 80 Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM469) Flash NAND Algo Start. FORMAT NAND FLASH : BEGIN: 0x11980000 - LEN: 0xd200000 Send preloader... Download firmware to flash now... Wait untill phone will start charging. All done |
The Following User Says Thank You to nandkishorgupta For This Useful Post: |
02-17-2016, 15:02 | #4428 (permalink) |
Member: 1260168 Status: Offline Thanks Meter: 62 | Miracle made my phone stuck at logo INFOCUS M260 Privacy Lock But unlock done with NCK Box by selecting Micromax D303 Selected MicroMax:Bolt D303 Exe version: NCKBox AndroidMTK 1.8.6.4 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM19) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6582_S01 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) HYNIX 0x483847316505 EMMC FW VERSION: 07:00:00:00:00:00:00:00 EMMC CID: 90014A48384731 : 000000000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2c00000 [7.293 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM469) Detecting format adress....wait! FORMAT EMMC FLASH : BEGIN: 0x8e320000 - LEN: 0xf000000 FORMAT EMMC FLASH : BEGIN: 0x9d320000 - LEN: 0x1343e0000 Phone can start slow at first power on If phone stuck on logo, perform wipe from recovery. First start can take up to 5 min on some phones. Wait untill phone will start charging. All done. |
02-17-2016, 15:20 | #4429 (permalink) |
Freak Poster Join Date: Aug 2013
Member: 1995502 Status: Offline Thanks Meter: 139 | OT-5020x flashing done Flash files count is :19 Action : Firmware update. Selected Alcatel: OT-5020 Exe version: NCKDongle AndroidMTK 2.5.6.2 Scenario: Full Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM (Android) (COM502) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6575_S01 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (28Gb+4096Mb) HYNIX 0x483447316404 EMMC FW VERSION: 86:00:00:00:00:00:00:00 EMMC CID: 90014A48344731 : 000000000000000000 EMMC UA SIZE: 0xe7000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe7600000 [3.615 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM645) Flash EMMC Algo Start. Starting flash. FORMAT EMMC FLASH : BEGIN: 0x3764c000 - LEN: 0x13900000 FORMAT EMMC FLASH : BEGIN: 0x4af4c000 - LEN: 0x971b4000 Send preloader... Download firmware to flash now... Wait untill phone will start charging. All done. |
02-17-2016, 15:34 | #4430 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Cote d'Ivoire
Member: 841640 Status: Offline Thanks Meter: 86 | ANOTHER ALCATEL OT-4022X ( fire fox) SUCCESFULLY UNLOCKED WITH NCB BOX Selected connection metod: META Mode Exe version: NCKBox AndroidMTK 1.8.6.3 Selected phone: OT-4022X Scanning for presents meta ports... Meta ports not detected, starting brom stage. Curent Platform: MT6572 Phone must be off with battery inside. Please insert USB cable now... Detected(11) : PreLoader USB VCOM Port (COM11) Starting META mode, wait... Restarting, wait.... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. META Port Detected[288] Android Gadget VCOM Driver (COM288) USB\VID_0BB4&PID_0005&MI_02\6&2882BB26&0&0002 Start sync target, waiting responce..... BaseBand CPU : MT6572, E01 SW_VER : MOLY.WR8.W1449.MD.WG.MP.V2.P5 HW_VER : JRDHZZ72_W_FF_HSPA_HW Phone imei[1] : 3576280XXXXXXXX Start direct unlock[SIM1] Direct unlock done Clean Boot flag ok. All done. |
The Following User Says Thank You to lovist2 For This Useful Post: |
02-17-2016, 15:44 | #4431 (permalink) |
Member: 637351 Status: Offline Thanks Meter: 167 | Cosmote Smart_Xceed remove viruses successfullyy Code: Exe Version: NCKdongle v17.5 Phone must be on, USB debugging must be enabled. If Phone ask for Allow Usb Debugging, allow. Searching for Device... Device Found Model: Smart_Xceed Version: 4.2.1 Hardware: mt6589 Baseband: MOLY.WR8.W1248.MD.WG.MP.V6.P32, 2013/09/27 15:41 SIM Card: READY CPU: armeabi-v7a Type: GSM IMEI(1): 3538470479xxxxx Checking Root Access... If Phone ask for su, allow. root: uid=0(root) gid=0(root) Root: Rooted Loading Detection Data... OK Scanning for Malware/Suspicious Files... OK Files Found: 40 Operation Finished. |
02-17-2016, 17:03 | #4432 (permalink) |
Member: 1995502 Status: Offline Thanks Meter: 139 | OT-5020X read codes Selected connection metod: FLASH Mode Exe version: NCKDongle AndroidMTK 2.5.6.2 Selected phone: OT-5020 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM (Android) (COM502) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6575_S01 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (28Gb+4096Mb) HYNIX 0x2058494e5948 EMMC FW VERSION: 16:00:00:00:00:00:00:00 EMMC CID: 90014A2058494E : 000000000000000000 EMMC UA SIZE: 0xe7000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe7600000 [3.615 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM645) OTP IMEI : 863039011028283 Reading security, wait... SECRO FW : X2A0EF03AB00 NCK: 31196644 : Locked NSCK: 33312679 : Unlocked SPCK: 32287568 : Unlocked SIM: 32869207 : Unlocked If lock counter is 0, make "Format UserData" from exe. Simlock saved to : C:\NCK Dongle\AndroidMTK\simlock_backup\_X2A0EF03AB00_bac kup.nsb Wait untill phone will start charging. All done. |
02-18-2016, 14:09 | #4433 (permalink) |
No Life Poster Join Date: Jun 2001 Location: Portugal Age: 48
Member: 4975 Status: Offline Thanks Meter: 612 | OT2004C Unlock Exe Version: NCK BOX v6.2.8 IMEI checksum seems ok Model: OT2004C IMEI: 014253005XXXXXX PID: PMPT1(X7C3CCP2AS00) NCK : 2783985479 NSCK: 1322712675 SPCK: 2371647517 SIM : 0504990006 CORPORATE: 2338881677 |
02-18-2016, 18:42 | #4435 (permalink) |
Junior Member Join Date: Dec 2010
Member: 1478022 Status: Offline Thanks Meter: 1 | PHONE SELECTED: SM-G318H Port: SAMSUNG Mobile USB Modem #9(COM47) Phone Detected. SM-G318H Model: SM-G318H Base: SM-N900 Version: G318HXCU0AOI2/G318HIDE0AOI2/G318HXCU0AOI1/G318HXCU0AOI2 PRD: SM-G318HZKAIDE SN: R21G63MB6FX IMEI: 3598xxxxxxxxxx SIMLOCK:LOCKED Unlocking, wait. Unlock Done. If Phone Ask For Code, Enter 00000000. For check lock use: *#7465625# |
02-19-2016, 15:54 | #4436 (permalink) |
Member: 1995502 Status: Offline Thanks Meter: 139 | Blackberry 8520 unlock Reading data, do not disconnect phone, wait..... Connecting, please wait OS NV : 1984-2000 Hardware ID : 0x8C000F03 OS Version : 4.2.0.122 Pin :26dedc2c Device: BlackBerry 8520 Curve[0x8C000F03] Trying to connect phone Please wait take a while... MEP : MEP-07723-005 PRD : PRD-24811-066 Backup saved in folder backup... Challenge RTAS Signature... [5]Preparing to process... Processing... Calculating succes... Modifying Phone Data... 0 MEP Unlock Done All Done. -------------------------- Log saved to: logs\0x8C000F03_26dedc2c_mep0_1.txt Screenshot by Lightshot |
02-19-2016, 18:24 | #4437 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Selected connection metod: FLASH Mode Exe version: NCKBox AndroidMTK 1.8.6.4 Selected phone: MT6580 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM92) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6580_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 768 MB DRAM ---------------------------------------------------- EMMC: (29Gb+6144Mb) HYNIX 0x483447326111 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 90014A48344732 : 000000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9c00000 [3.652 GB] Block Size: 512 IMEI marker was found in nvram IMEI[1] from NVRAM: 355601074404183 IMEI[2] from NVRAM: 355601074489689 Reading security, wait... SIM[1]: Block1(N): Locked (remain:5) Code : 87654321 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked SIM[2]: Block1(N): Locked (remain:5) Code : 87654321 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Unlocking target...please wait. Unlock finished. Wait untill phone will start charging. All done. Selected connection metod: FLASH Mode Exe version: NCKBox AndroidMTK 1.8.6.4 Selected phone: MT6580 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM92) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6580_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 768 MB DRAM ---------------------------------------------------- EMMC: (29Gb+6144Mb) HYNIX 0x483447326111 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 90014A48344732 : 000000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9c00000 [3.652 GB] Block Size: 512 IMEI marker was found in nvram IMEI[1] from NVRAM: 355601074356102 IMEI[2] from NVRAM: 355601074441607 Reading security, wait... SIM[1]: Block1(N): Locked (remain:5) Code : 87654321 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked SIM[2]: Block1(N): Locked (remain:5) Code : 87654321 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Unlocking target...please wait. Unlock finished. Wait untill phone will start charging. All done. |
02-19-2016, 19:58 | #4438 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel 4010X Unlock code read done.. Selected connection metod: META Mode Exe version: NCKBox AndroidMTK 1.8.6.4 Selected phone: OT-4010X Scanning for presents meta ports... Meta ports not detected, starting brom stage. Curent Platform: MT6575 Phone must be off with battery inside. Please insert USB cable now... Detected(4) : PreLoader USB VCOM Port (COM4) Starting META mode, wait... Restarting, wait.... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. META Port Detected[146] Android Gadget VCOM Driver (COM146) USB\VID_1BBB&PID_4003&MI_02\6&1E060D2B&0&0002 Start sync target, waiting responce..... BaseBand CPU : MT6575 SW_VER : MAUI.11AMDW1150SP.V31.F2.P9.T1 HW_VER : JRDHZZ75_GB2_HW Meta mode conected ok, start reading phone.... Phone imei[1] : 869294016039009 Simlock Info : Sim [1] Block1[N] :Locked [remain:10] Code : 42092625 Block2[NS] :Unlocked Code: 22414252 Block3[SP] :Unlocked Code: 22044082 Block4[C] :Unlocked Code: 21640060 Block5[SIM]:Unlocked Code: 40346075 ************************************** All done. |
02-20-2016, 06:33 | #4439 (permalink) |
Member: 1260168 Status: Offline Thanks Meter: 62 | Micromax E311 Privacy Unlock done Selected MicroMax:Bolt D303 Action : Boot Info. Selected MicroMax:Bolt D303 Exe version: NCKBox AndroidMTK 1.8.6.4 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM19) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6592_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 2 GB DRAM ---------------------------------------------------- EMMC: (117Gb+16384Mb) HYNIX 0x484147326505 EMMC FW VERSION: 07:00:00:00:00:00:00:00 EMMC CID: 90014A48414732 : 000000000000000000 EMMC UA SIZE: 0x3ab800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3ac400000 [14.691 GB] IMEI marker was found in nvram IMEI[1] from NVRAM: 911425153XXXXXX IMEI[2] from NVRAM: 911425154XXXXXX Partition table saved to: Android_MTK\partition_tables\ Wait untill phone will start charging. All done. Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM19) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6592_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 2 GB DRAM ---------------------------------------------------- EMMC: (117Gb+16384Mb) HYNIX 0x484147326505 EMMC FW VERSION: 07:00:00:00:00:00:00:00 EMMC CID: 90014A48414732 : 000000000000000000 EMMC UA SIZE: 0x3ab800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3ac400000 [14.691 GB] Dumping data, wait. Value found, procesing[010c][002c0000] Resetting phone. FORMAT EMMC FLASH : BEGIN: 0xcd000000 - LEN: 0x2dd300000 Phone can start slow at first power on If phone stuck on logo, perform wipe from recovery. First start can take up to 5 min on some phones. All done. |
