09-12-2016, 11:17 | #4876 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | Code: USB Connection selected. EXE VERSION: NCKBox MTK Tool 3.5 Connect phone in boot mode ... USB\Vid_0e8d&Pid_0003&Rev_0100 Com port ok : COM133 Phone detected...Please wait Conected ok with target ... Starting meta mode..... IMEI: 353375073113705 Start read, wait.... Block1(N) : Locked (remain:0) Code : 12345678 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C) : Unlocked Unlock file done Unlock file done Processing done. Unlock done. Clean tmp directory....wait. Clean tmp directory....done. META END OK. All done. |
09-12-2016, 11:52 | #4877 (permalink) |
Freak Poster Join Date: Sep 2001 Location: Negotino
Member: 6517 Status: Offline Thanks Meter: 20 | Cubot Note S MT6580 FRP GOOGLE ACCOUNT BYPASS Exe version: NCKDongle AndroidMTK 2.5.7.0 Selected model: MT6580 Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM16) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6580_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 2 GB DRAM ---------------------------------------------------- EMMC: (116Gb+16384Mb) SAMSUNG 0x513832334d42 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010051383233 : 000000000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : MediaTek DA USB VCOM (Android) (COM8) Checking data....wait! FORMAT EMMC FLASH : BEGIN: 0x4fa0000 - LEN: 0x100000 FRP Reset Done. All done. |
09-12-2016, 13:26 | #4878 (permalink) |
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | MTN SM@RT S620 UNLOCK OK Code: Selected connection metod: FLASH Mode Exe version: NCKBox AndroidMTK 1.8.7.1 Selected model: MT6572_EMMC Action: Unlock Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM (Android) (COM297) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6572_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) TOSIBA 0x303034474530 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 11010030303447 : 000000000000000000 EMMC UA SIZE: 0xec000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xec480000 [3.692 GB] Status: USB_FULL_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM333) IMEI[1]: 352509070732684 IMEI[2]: 352509070732692 Reading security, wait... SIM[1]: Block1(N): Locked (remain:5) Code : 12345678 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked SIM[2]: Block1(N): Locked (remain:5) Code : 12345678 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Unlocking target...please wait. Unlock finished. Wait untill phone will start charging. All done. |
09-12-2016, 13:34 | #4879 (permalink) |
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | MTN SM@RT L860 UNLOCK DONE BY NCKBOX Code: Selected connection metod: FLASH Mode Exe version: NCKBox AndroidMTK 1.8.7.1 Selected model: MT6735M Action: Unlock Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM (Android) (COM297) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6735M_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (56Gb+8192Mb) KSI 0x563130303038 EMMC FW VERSION: 50:00:00:00:00:00:00:00 EMMC CID: 70010056313030 : 000000000000000000 EMMC UA SIZE: 0x1c3000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1c3c00000 [7.059 GB] Status: USB_FULL_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM333) IMEI[1]: 356038071251987 IMEI[2]: 356038071251995 Reading security, wait... Block1(N): Locked (remain:5) Code : 12345678 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Block1(N): Locked (remain:5) Code : 12345678 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Unlocking target...please wait. ALGO[2] Unlock finished. Wait untill phone will start charging. All done. |
09-12-2016, 16:26 | #4881 (permalink) |
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | WIKO GOA FORMAT DONE Code: Action : Format UserData. Selected 0-By CPU:MT6572_EMMC Exe version: NCKBox AndroidMTK 1.8.7.1 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM (Android) (COM37) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6572_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) HYNIX 0x483447316404 EMMC FW VERSION: 05:00:00:00:00:00:00:00 EMMC CID: 90014A48344731 : 000000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9c00000 [3.652 GB] Status: USB_HIGH_SPEED Not need to swith to high speed port, continue with this settings. Detecting format adress....wait! Starting generic userdata format...! FORMAT EMMC FLASH : BEGIN: 0x36340000 - LEN: 0xe200000 FORMAT EMMC FLASH : BEGIN: 0x44540000 - LEN: 0xa41c0000 All done. |
09-13-2016, 07:31 | #4882 (permalink) |
No Life Poster Join Date: Apr 2008 Location: gsmsolution Age: 34
Member: 755480 Status: Offline Sonork: 100.1609798 Thanks Meter: 233 | wikko jimmy unlock done in second Code: Selected connection metod: FLASH Mode Exe version: NCKBox AndroidMTK 1.8.6.7 Selected model: MT6582 Action: Unlock Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM7) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6582_S01 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) HYNIX 0x483447316404 EMMC FW VERSION: 05:00:00:00:00:00:00:00 EMMC CID: 90014A48344731 : 000000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9c00000 [3.652 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : MediaTek DA USB VCOM (Android) (COM94) IMEI[1]: 356196062833997 IMEI[2]: 356196062974494 Reading security, wait... SIM[1]: Block1(N): Locked (remain:5) Code : 87654321 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked SIM[2]: Block1(N): Locked (remain:5) Code : 87654321 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Unlocking target...please wait. Unlock finished. Wait untill phone will start charging. All done. |
09-13-2016, 15:54 | #4884 (permalink) |
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | INFOCUS M808 FORMATING USER DATA AND REOVE FRP DONE Code: Action : Format UserData. Selected 0-By CPU:MT6753 Exe version: NCKBox AndroidMTK 1.8.7.1 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM (Android) (COM37) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6753_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 2 GB DRAM ---------------------------------------------------- EMMC: (117Gb+16384Mb) HYNIX 0x484147326505 EMMC FW VERSION: 07:00:00:00:00:00:00:00 EMMC CID: 90014A48414732 : 000000000000000000 EMMC UA SIZE: 0x3ab800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3ac400000 [14.691 GB] Status: USB_HIGH_SPEED Not need to swith to high speed port, continue with this settings. Detecting format adress....wait! Starting generic userdata format...! FORMAT EMMC FLASH : BEGIN: 0xdc800000 - LEN: 0x19000000 FORMAT EMMC FLASH : BEGIN: 0xf5800000 - LEN: 0x2b4f80000 All done. RESET FRP DONE Code: Exe version: NCKBox AndroidMTK 1.8.7.1 Selected model: MT6753 Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM (Android) (COM37) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6753_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 2 GB DRAM ---------------------------------------------------- EMMC: (117Gb+16384Mb) HYNIX 0x484147326505 EMMC FW VERSION: 07:00:00:00:00:00:00:00 EMMC CID: 90014A48414732 : 000000000000000000 EMMC UA SIZE: 0x3ab800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3ac400000 [14.691 GB] Status: USB_HIGH_SPEED Not need to swith to high speed port, continue with this settings. Checking data....wait! FORMAT EMMC FLASH : BEGIN: 0x17f20000 - LEN: 0x100000 FRP Reset Done. Wait untill phone will start charging. All done. |
09-13-2016, 17:07 | #4885 (permalink) |
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | ALCATEL ORANGE RISE 31 RESET FRP DONE BY NCKBOX Code: Exe version: NCKBox AndroidMTK 1.8.7.1 Selected model: MT6580 Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM (Android) (COM37) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6580_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x464e31324d42 EMMC FW VERSION: 06:00:00:00:00:00:00:00 EMMC CID: 150100464E3132 : 000000000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Status: USB_HIGH_SPEED Not need to swith to high speed port, continue with this settings. Checking data....wait! FORMAT EMMC FLASH : BEGIN: 0x9000000 - LEN: 0x800000 FRP Reset Done. Wait untill phone will start charging. All done. |
09-14-2016, 12:51 | #4887 (permalink) |
Freak Poster Join Date: Dec 2015 Location: Kumasi,Ghana
Member: 2496301 Status: Offline Thanks Meter: 43 | USB Connection selected. EXE VERSION: NCKDongle MTK Tool 1.49 Connect phone in boot mode ... USB\Vid_0e8d&Pid_0003&Rev_0100 Com port ok : COM57 Phone detected...Please wait Conected ok with target ... Reopen comport(COM57) BaseBand CPU : MT6255, E02 SW_VER : MAUI.11B.W12.24.MP.V2.F11 HW_VER : JRDHZ55_W1224_11B_COSMOS_HW Meta mode conected ok, start reading phone.... Phone imei[1] : 869115010633648 User code(Inactive) : 1234 Phone model: OT-V575 SIMLOCK INFO[1] SECRO NAME: XO48FE11 SIMLOCK STATUS: PHONE IS LOCKED NCK: 3362324976 Counter[10/10] NSCK: 3517380737 Counter[10/10] SPCK: 3723874629 Counter[10/10] SIM: 0123882905 CORPORATE: 3742039131 SIMLOCK END META END OK. All done. |
09-14-2016, 15:07 | #4889 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Wiko Jerry Direct Unlock done.. Selected connection metod: META Mode Exe version: NCKBox AndroidMTK 1.8.7.2 Selected model: MT6580 Action: Unlock Scanning for presents meta ports... Meta ports not detected, starting brom stage. Curent Platform: MT6580 Phone must be off with battery inside. Please insert USB cable now... [92]Detected: PreLoader USB VCOM Port (COM92) \\?\usb#vid_0e8d&pid_2000#5&1bbd4c1c&0&8#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [161]META Port Detected: Gadget CDC VCOM Driver (COM161) USB\VID_0E8D&PID_2007\5&1BBD4C1C&0&8 Start sync target, waiting responce..... BaseBand CPU : mt6580,S01 BaseBand CPU : MT6580, E01 SW_VER : MOLY.WR8.W1449.MD.WG.MP.V57.P5 HW_VER : TINNO6580_WE_M_HSPA_HW Phone imei[1] : 3586560738AAAAA Phone imei[2] : 3586560739AAAAA Start direct unlock[SIM1] Direct unlock done Start direct unlock[SIM2] Direct unlock done Clean Boot flag ok. All done. |
09-14-2016, 15:08 | #4890 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel OneTouch Pixi4 Direct Unlock done.. Selected connection metod: FLASH Mode Exe version: NCKBox AndroidMTK 1.8.7.2 Selected model: OT-5010X Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM92) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6580_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x463732324d42 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010046373232 : 000000000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : DA USB VCOM Port (COM98) OTP IMEI: 357651070327910 MODEL FROM PROINFO: 5010X-2AVRGB1 SECRO FROM PROINFO: L5E2CDE3BS10 Reading security, wait... SIM[1]: Block1(N): Locked (remain:7) Code : 0906023597688542 Block2(NS): Unlocked Block3(SP): Locked (remain:10) Code : 5269040028159001 Block4(C): Unlocked Please note, some firmwares can display wrong codes. Some firmwares can be hardlocked. If this happen, perform direct unlock. If direct unlock fail,use reset package from support. If reset package not exist in support,request help in forum. Wait untill phone will start charging. All done. |
