Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 11-28-2013, 15:53   #1 (permalink)
Member: 2073862
Thanks Meter: 3
CA-101 for Nokia 100
Hello, what types of data cable and software are needed to connect a Nokia 100 to a PC for flashing?
Note: CA-101 is displayed on the Nokia 100 service manual but as we can see there is no port for it.
Old 11-28-2013, 16:35   #2 (permalink)
chinnivardan's Avatar
Member: 892484
Sonork: not using
Thanks Meter: 916
this is basic model mobile does not have data cable option
The Following User Says Thank You to chinnivardan For This Useful Post:
Old 11-28-2013, 18:51   #3 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
It's Common Fbus Cable Nokia 100 & 101 Same OR Use Ufc Cable.
WBR.
Arsalan gsm2000.
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post:
Old 11-29-2013, 14:36   #4 (permalink)
Member: 2073862
Thanks Meter: 3
Thanks men. Using an FBUS cable definitely means that I will need a box, right? Can you tell me also about the software/s to be used?
Thanks a lot, I'm hoping for your kind replies.
Old 11-29-2013, 16:04   #5 (permalink)
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
Yes Sure Fbus Cable Use With Nokia Module Boxes Like ATF.Cyclone.Hti Mxboxe.Flash With This OR Userlock Factory Settings What Ever...
WBR.
Arsalan gsm2000.
Old 11-29-2013, 17:01   #6 (permalink)
Member: 2073862
Thanks Meter: 3
Yeah, the phone can be reset using a phone code. But of course we cannot install CFW without using box. Anyway, what unit/brand of ATF can you suggest sir? From what I can see, there are only 2 RJ45 ports on the picture of ATF Lightning from ATF site. Thank you.
Old 12-02-2013, 12:28   #7 (permalink)
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
I Suggest You Buy ATF BIG Box.
WBR.
Arsalan gsm2000.
Old 12-02-2013, 23:20   #8 (permalink)
Member: 300043
Thanks Meter: 360
CA-101 doesn't connect directly to the Nokia 100/101,
rather it (CA-101 cable) is connected via a FBUS flash adapter.
The Following User Says Thank You to LBOZ_GSM For This Useful Post:
Old 12-03-2013, 14:11   #9 (permalink)
Member: 2073862
Thanks Meter: 3
Thanks guys! I see now the phone must be connected using FBus.
Old 12-04-2013, 01:14   #10 (permalink)
7ope's Avatar
Member: 1315205
Thanks Meter: 21
You CAN flash With this
The Following User Says Thank You to 7ope For This Useful Post:
Old 12-04-2013, 14:47   #11 (permalink)
Member: 2073862
Thanks Meter: 3
Hi 7ope, the holes on the cellphone and on the diagram don't seem to match. What do we call that protocol anyway?
Old 12-04-2013, 16:30   #12 (permalink)
Member: 300043
Thanks Meter: 360
7ope, that is a Nokia 110 USB Pinout
bimboxX, search for "Nokia 100 USB Pinout "
Old 12-05-2013, 12:07   #13 (permalink)
Member: 2073862
Thanks Meter: 3
LBOZ_GSM and 7ope, just wow, does that mean I can connect a usb port to the FBUS and then connect directly to my PC? Are there drivers for that?
Anyway, if you have time can you go to my "Questions about Phone Specs" post and try to answer? Thanks a lot!
Page generated in 0.20264 seconds with 9 queries
