GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
03-12-2010, 17:41 | #61 (permalink) |
Insane Poster Join Date: Feb 2010 Location: SLx
Member: 1240703 Status: Offline Thanks Meter: 40 | Again elcapitel and y3kt thanks for the great research =) B.R, VM_Hacker |
The Following 3 Users Say Thank You to VM_Hacker For This Useful Post: |
03-12-2010, 17:55 | #63 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Club-Berry
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | @fr3nsis: now that you have that little nice prog, can you test with several imeis to see if correct nck+spck is given? Just to be 200% sure, i don't have time now to code it, luck |
03-12-2010, 18:12 | #67 (permalink) |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | This post is also dedicated to everyone. Specially with great pride that y3kt and me are Cubans. Regardless of all things, it is a simple example that in our beautiful country are people who are a little above the simple user. It is also a proof that if you show real interest then you can achieve anything... So proud to be Cubans. br elcapitel |
03-12-2010, 18:20 | #68 (permalink) |
Freak Poster Join Date: Nov 2006 Location: morocco Age: 36
Member: 389669 Status: Offline Sonork: 100.1583354 Thanks Meter: 226 | congratulation elcapitel, y3kt, you realy done hard work. now all programmer can release they own zte nck calculation, and for sure same one will release it for free, but please don't kill the market. Br |
03-12-2010, 18:26 | #69 (permalink) |
No Life Poster Join Date: Dec 2009 Location: CIEGO DE AVILA ,CUBA
Member: 1176958 Status: Offline Thanks Meter: 158 | thanks EL CAPITEL YOU ARE THE BEST ...............ARRIBA CUBAAAAAAAAAAAA |
The Following User Says Thank You to yaro_rguez For This Useful Post: |
03-12-2010, 18:31 | #70 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Inside Vb.Net Age: 41
Member: 140822 Status: Offline Sonork: 100.1594493 Thanks Meter: 1,010 | Thanks MR. Capitel "A lo Cubano, botella e' ron, tabaco habano" |
The Following User Says Thank You to josedavido For This Useful Post: |
03-12-2010, 18:40 | #71 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Cardenas. Matanzas. Cuba
Member: 323671 Status: Offline Thanks Meter: 51 | Congratulations my friend. That's for those who thought that in Cuba there was not good. Salu2 |
The Following User Says Thank You to caid2006 For This Useful Post: |
03-12-2010, 19:09 | #73 (permalink) |
No Life Poster Join Date: Aug 2005 Age: 45
Member: 173741 Status: Offline Thanks Meter: 986 | Using y3kt Methode ? you find this nck for this imei !!! @y3kt can u review your methode for found nck for imei posted by Vm_hacker posted also by me before not same nck when we using your methode wish i'm wrong or i have mistake on calcule |
03-12-2010, 19:30 | #74 (permalink) |
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | Using our method you will get from imei 352353026840550 the following: 353026840550 --> sum=41 353026840550 --> first step 000024860404 --> inverse using chart described, second step 688950000000 --> fixed line, third step -------------- 931990600954 --> nck this was done manually, if we compare the nck with the one from VM_Hacker we can see it is the same, so yes, our method seems to be correct, hope you clear your doubts now, luck |
The Following User Says Thank You to y3kt For This Useful Post: |
how to enter code in Zte F870? | mulenga | ZTE | 0 | 02-20-2010 22:56 |
Help To Remove Userlock In Zte F850 | hans salim | Infinity-Box | 1 | 04-14-2008 15:59 |
Phillips C12 Locked to sim (want to use sim in another phone!) | M0rph3u5 | Philips | 1 | 07-02-2003 13:19 |
Someone can to calculate log in *lc format? | partner44 | Phone Unlocking Codes & Maps | 0 | 08-31-2002 08:48 |
